4x4 light stays on - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 05-03-2010, 07:55 AM Thread Starter
curtis_14
4x4 light stays on
I need someones help, does anyone know why my 4x4 light stays on sometimes it blinks, I tryed many times taking it in and out of 4 wheel drive and the light wont go off
2000 2500 4x4
Curtis_14
curtis_14 is offline
post #2 of 9 Old 05-03-2010, 03:20 PM
AC130Ghostrider
AC130Ghostrider's Avatar
When you put it in/out of 4x4, does it actually engage/disengage? I don't know if the light is associated with a code, but it may be worth checking.
AC130Ghostrider is offline
post #3 of 9 Old 05-03-2010, 03:31 PM Thread Starter
curtis_14
goes in and out of 4 wheel drive fine everything seems to work the light just wont go off
post #4 of 9 Old 05-03-2010, 04:19 PM
AC130Ghostrider
I did a little searching and found this:
Since the use of 4WD requires vacuum, a leak, or destruction of the lines can render the 4WD inoperative. However, the lines are fairly well protected, and failures are rare. The vacuum switch is a known weak point. The switch is a little tower on the transfer case with four lines coming from it. The switch is activated by the transfer case when a lever inside the case presses a plunger at the base of the switch. Then, a spring in the switch extends the plunger when the lever is retracted. The problem is that the plunger is rounded to ease the lever's action. This rounded part can be easily jammed inside the switch by the standard gunk in the transfer case. When this happens, the interlock and the 4WD light will not disengage. It is an easy fix by just un screwing the switch and cleaning it, but when it happens, you can feel the extra drag of the front driveshaft and associated parts.
Hope this might help.
post #5 of 9 Old 05-03-2010, 04:31 PM Thread Starter
curtis_14
thanks for the help I clean it up and see if that fixes the problem
post #6 of 9 Old 05-03-2010, 04:50 PM
bigmacdak
MYTYT
bigmacdak's Avatar
Quoted: 1 Post(s)
Your CAD (center axle disconnect) isint disengaging. Check all the vaccum lines on the disconnect, lines leading from the disconnect to the switch on the transfer case & the lines going from the source to the switch. It can be a real PITA to track down a leak. It also could be the modulator getting too weak to pull the fork.
You might also pull the CAD out of the axle tube & check it out. I recently replaced a leaking CAD housing gasket. While I had the CAD out of the axle tube, I gave it a good cleaning & inspected the fork pads just to be on the safe side.
Currently Dodge-less
bigmacdak is offline
post #7 of 9 Old 05-05-2010, 02:20 PM
AC130Ghostrider
Any news on the light? May be useful in the future.
post #8 of 9 Old 05-05-2010, 05:10 PM Thread Starter
curtis_14
got side tracted today i'll update as soon as i find out whats up,
post #9 of 9 Old 05-05-2010, 07:52 PM
Miami_Son
Chrysler faithful
Miami_Son's Avatar
Quoted: 1 Post(s)
The transfer case switch is just one weakness in a poorly designed system. The switch that turns on and off the dash indicator is on the CAD itself, so the transfer case switch is not likely to be your problem. More likely is that the CAD is not disengaging or at least not completely. Better solution is to get rid of all the vacuum system and replace it with a Posi-Loc cable-actuated system. Positive engagement/disengagement, 4WD Lo operation and more peace of mind that when the 4WD system is locked/unlocked, it stays there.
2015 Jeep Grand Cherokee Altitude
2012 Ram 1500 Sport Hemi Crew Cab 4X2
2000 Ram 2500 Laramie Sport V10 Quad Cab 4X4
1996 Jeep Grand Cherokee Laredo 4X4
1989 Jeep Cherokee Laredo 4X4
1986 Jeep CJ7 Laredo 4X4
1979 Dodge Power Wagon 4X4
1975 Dodge Ramcharger 4X4
1974 Plymouth Road Runner
1973 Plymouth Barracuda
1970 Dodge Coronet 440
Miami_Son is offline
    4x4 light stays on flickers hwscowboy 2G Dodge RAM - 4X4 Talk 1 11-19-2009 02:14 PM
    4wd light stays on rustyirn 2G Dodge RAM - 4X4 Talk 4 08-29-2008 03:42 PM
    4WD light stays on? jdgus22 2G Dodge RAM - 4X4 Talk 5 01-29-2006 07:25 PM
    abs light and brake light stays on now salesman 2G Dodge Intrepid - General Talk 1 08-15-2005 10:40 AM
