HID problem? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 33 Old 04-25-2010, 10:45 PM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
HID problem?
okay so here's the thing.. i have a bi-xenon hid kit from twiggy that came off my buddys 05 truck 2 days ago, which were working perfectly fine. we hooked everything up to my truch (which is an 02) and when we turned it on the lights started flashing like they were my hazard lights or something they turned on and off a couple times then i just turned them off.
i plugged my halogen bulbs back in to make sure they still worked and they came on just fine no problems at all.
the other weird thing is we took the kit and hooked it up to another friend's 03 dodge to see if it would work and they did! they weren't flashing or anything just came on and stayed on.. so we just hooked the kit back up to my truck and they started flashing like before
idk what the hell is wrong cuz i mean my stock lights work fine, plugged the kit into my friend's truck everything worked fine, but when i hook it up to my truck the lights flash on and off??? i'm just at a complete loss
:h elp:
B!acK02oUT is offline
post #2 of 33 Old 04-26-2010, 12:45 AM
blackram05
blackram05's Avatar
have the same problem man i just ordered a computer canceller kit. the problem is that the surge of power when you turn on your hids is to big so the computer throughs a flag saying hey there is to much power going to the bulb shut it down. so what the cancellers do is store energy first then starts the hids. but about the other trucks that it works on theres but not yours i just says all trucks are different. but ill get back on here like mid week to let you know how they work. and if you dont wanna wait to hear back the web site to get them is hidcountry.com computer warning cancellers.
Tinted Tails, Painted Headlights, Leveled, Cooper Zeon LTZ Tires, Debadged, 8,000K HID Low Beam, Led Plate Lights/Third Brake,Optima Battery,Stub Antenna, Tinted Windows and Super 44 Dumped After Axle
Black truck club member #190
blackram05 is offline
post #3 of 33 Old 04-26-2010, 01:32 AM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
thats what i was thinking was going on.. there was too much power and it was basically like tripping the breaker so to speak. so you're sure that's what the problem is and that's all i need to fix it? how much do those cancellers cost?
post #4 of 33 Old 04-26-2010, 01:58 AM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
i just looked on hidcountry and couldn't find the cancellers
post #5 of 33 Old 04-26-2010, 06:10 AM
frazier79
Squiddy
frazier79's Avatar
good question.
i just ordered a pair of twiggy's myself. blackram, what year is your truck? i have an 08 and am wondering if i'll need the can bus cancellers too?
2012 2500 ST CC 4x4
Gone, But Never Forgotten -
2008 QCSB 4.7l 6speed manual 4wd
3.92 gears Y Pipe Magnaflow
frazier79 is offline
post #6 of 33 Old 04-26-2010, 06:11 AM
frazier79
Squiddy
frazier79's Avatar
nevermind, clearly '05 is the answer. too early in the morning for tech talk.
2012 2500 ST CC 4x4
post #7 of 33 Old 04-26-2010, 11:12 AM
frazier79
Squiddy
frazier79's Avatar
check ebay, i wish i knew how to insert links, but i'm not that savvy with the internet. type in HID capacitor and you should see plenty of options. there as cheap as 3.99(shipping from china) and as much as 45. i think i'm going with the 17.99 option out of florida. good luck.
2012 2500 ST CC 4x4
post #8 of 33 Old 04-26-2010, 12:28 PM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
i just found out that the kit i have comes with cancellers... so now wtf??
post #9 of 33 Old 04-26-2010, 12:32 PM
AdamRAM06
AdamRAM06's Avatar
resistor?
show me a pic of your kit, if you have one.
2006 Dodge RAM 1500 HEMI Big Horn Quad Cab 4x4 - Cool Vanilla
22x11 Edge Hype Wheels
37-13.5x22 Kumho Road Venture M/T
6in Stage II Pro Comp Lift w/ Rear Trac Bars Upgrade
Dynatech SuperMaxx Headers and High Flow Cats (LOUD)
K&N 77 series intake
AirAid throttle body spacer
Bully Dog Power Programmer
Wireless Load Control
Droid Smart Start
Drilled and Slotted Rotors
JL 13.5 W3v2 Center Console Stealth Box
All Rockford Components, Speakers, and Amps
Kenwood 7" Touch Screen NAV/DVD/IPOD
AdamRAM06 is offline
post #10 of 33 Old 04-26-2010, 12:34 PM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
give me like 10 min i'll go take one and get it on here
post #11 of 33 Old 04-26-2010, 12:40 PM
AdamRAM06
AdamRAM06's Avatar
you mean ballasts?
Droid Smart Start
post #12 of 33 Old 04-26-2010, 12:48 PM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
here's the kit..
post #13 of 33 Old 04-26-2010, 12:56 PM
AdamRAM06
AdamRAM06's Avatar
check all connections for exposed wire. splice if needed.
assemble first, then install.
make sure your engine is RUNNING when you turn them on.
did you use the same ground locations that your buddy did?
that doesn't work let me know, i'll ask my HID guy.
Droid Smart Start
post #14 of 33 Old 04-26-2010, 12:59 PM
AdamRAM06
AdamRAM06's Avatar
if you can lay everything out they way it would be installed on your truck. connect all conections. then take a pic.
fog lights too?
Droid Smart Start
post #15 of 33 Old 04-26-2010, 01:03 PM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
yeah we assembled everything along the outside the truck, just hooked it up to a ground and tried it like that first. did the same thing on my buddy's truck that we tried the kit on and it worked fine on his truck, but they flashed when hooked up to my truck.
we didn't have the truck running though when we tried it on either truck..
post #16 of 33 Old 04-26-2010, 01:06 PM Thread Starter
B!acK02oUT
B!acK02oUT's Avatar
so hook it up outside the truck like i was testing it and take a pic of how it is set up?
and no i dont have a fog kit yet, just the heads right now.
post #17 of 33 Old 04-26-2010, 02:30 PM
AdamRAM06
AdamRAM06's Avatar
yes, and your truck should be running while your HID's are on.
Droid Smart Start
post #18 of 33 Old 04-26-2010, 06:04 PM
WARLOCK
WARLOCK's Avatar
Quoted: 8 Post(s)
shoot, this is easy. The 2 orange things that are hooked back to back are the cancelers. check your connections.
Rusty
DodgeTalk.com
Member #(77)
DodgeTalkAholics #77
RIP
2005 Dodge Magnum R/T
Been Hammered and Diablo Predator.
Pedderized
KSport coil overs
R1 Concept drilled and slotted rotors
To join the Official Dodgetalk Member Map, click
WARLOCK is offline
post #19 of 33 Old 04-26-2010, 06:10 PM
EatonsHEMI
EatonsHEMI's Avatar
I had the same problem. I ended up tying them into a power wire.
2007 RAM 1500 5.7L HEMI 4x4
Mods & Addons
Line-X OtR
Amsoil Gear Oil
WeatherTech Floor Liners
Mopar Rear Wheel Well Liners
Mopar Splash Guards
8000k HID lights in Heads and Fogs *Removed*
Python 991 Security and Remote Start System
EatonsHEMI is offline
post #20 of 33 Old 04-27-2010, 06:33 AM
blackram05
blackram05's Avatar
did you get it to work yet? there do to come in friday so saturday ill install them. but i did see your kit had the cheap verison of the cancellers.
    hid problem 06Megacabman 3G Dodge RAM - General Talk 5 10-15-2009 01:49 PM
    HID problem lilbbro 2G Dodge Avenger - General Talk 5 03-13-2009 08:35 AM
    hid problem orion 3G Dodge RAM - General Talk 1 04-17-2008 07:28 PM
    HELP!! HID problem!! NuERA 3G Dodge RAM - General Talk 6 10-28-2007 02:39 PM
    HID Problem blind829 2G Dodge RAM - General Talk 18 01-03-2007 11:13 AM
