Brake Shudder/Front Passenger side vibration - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 54 Old 04-15-2010, 10:20 AM Thread Starter
rammit98
Hey guys,
I am at the end of my rope on this issue - searched through old posts and I can't find anything that is quite the same.
The issue is, when braking, I have a lightly pulsing brake pedal as well as a shudder on the front passenger side of the truck (I can watch the hood vibrate on that side while braking).
I have new stainless braided brake lines, speed bleeders on new calipers (freshly bled), freshly rebuilt rear drums, cross-drilled slotted rotors, ceramic pads, just replaced unit bearings, 1 yr old ball joints across the front. The rear doesn't seem to be the problem - when braking with the emergency brake only, there is no shudder. I don't really know where to go from here... how do you diagnose a bad master/slave cylinder? Are there any other issues which could cause this problem? I checked the alignment with a tape measure from front to front and rear to rear of front tires, and it seems fine. Truck tracks in a straight line when driving and doesn't really wander. Pulls slightly to the left when braking, but I think that a pad is worn unevenly... have a new set to swap in, but this problem has been happening since before my last brake job.
Any ideas or suggestions???
1998 Ram 1500 Sport 4X4 Quad Cab 130,000 Miles
5.2L - 1 5/8" Equal Length Headers, Copper Gaskets, Mopar M1 Intake Manifold, RActive Air Intake, 52mm Polished Throttle Body, SCT TUNED!
- Mopar Performance Cap and Rotor, MSD Super Conductor 8.5mm wires, Summit Digital CD Ignition and Coil, Autolite 3923s
- Harland Sharp 1.7 Roller Rockers, Custom Polished Aluminum Valve Covers
- MagnaFlow Cat, Flowmaster 40 Series Split Rear
- Rough Country 3" Suspension Lift, 1" TGC coil spacers, Custom Lower Control Arms, 3" Body Lift, Poly Bushings (all around), Skyjacker Track Bar
- 33" BFG All-Terrain TA/KO on 15X10 Mickey Thompson Classic II, Summit Cross-Drilled Slotted Rotors, Russell Stainless Braided Brake Lines
- Bushwacker Fender Flares
- TransGo Shift Kit, PermaCool Tranny Cooler
- 180* T-stat, Stainless Upper & Lower Radiator Hoses
The Money Pit List
- Nerf Bars
- 4.56 Ring & Pinions
- Electric Fans & Aluminum Shroud
- March Underdrive Pulleys
- Powermaster 170 Amp Alternator, Dual Battery Box
- Powertrax No-Slip (out back), Maybe an ARB (up front)
- -AN Cooling, Heating, Fuel Lines
- Lift 'er Again
rammit98 is offline
post #2 of 54 Old 04-15-2010, 11:29 AM
jmsteelers11
jmsteelers11's Avatar
Well the pulsating would be warped rotors. I can imagine a "shudder" possibly coming from the dust shield rubbing against the rotor on the inside of the tire. Its thin metal fairly flexible and can be bent back. Jack the truck up and spin the tire see if you hear anything hitting, And also wobble the tire while in the air to check for bad bearings. Hard tellin from what you described, check suspension components look for anything out of the ordinary. Good luck.
01 Ram 1500 4x4
Regular Cab Short bed
Off Road Package
Silver
5.9
Stock
jmsteelers11 is offline
post #3 of 54 Old 04-15-2010, 11:36 AM
KC_Metal
Mopar Rules!!!!!!!!!!!!!!
KC_Metal's Avatar
I'd say it's a warped rotor or a bad wheel bearing.
2006 Chrysler 300 HEMI C 5.7L V8: (Summer Car)
- Hurst Comp stick kit & badge, Windows Tinted 15%.
2010 Avalanche LT 5.3L V8: (Wife's Truck)
- Windows Tinted 15%, 8 Bar 20's from California
2008 Chrysler 300 AWD Touring 3.5L V6: (Winter Car)
- Hurst Comp stick kit & badge, Windows Tinted 15% (soon)
Fu*k Toyota, Honda, Mitsubishi, Lexus and all that other Jap crap!
KC_Metal is offline
post #4 of 54 Old 04-15-2010, 12:11 PM Thread Starter
rammit98
I check the rotors a couple weeks ago when i replaced calipers. originally i though the passenger side caliper was failing. nothing is coming in contact that shouldnt be. checked ball joints and bearings - replaced the unit bearings. wheel spins good and suspension doesn't appear to have any worn out components.
Also, i should add that the brakes work well. They will lock up and stop the truck just fine, even with 33's...
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
post #5 of 54 Old 04-15-2010, 01:04 PM
KC_Metal
KC_Metal's Avatar
Well if it's not the rotors I'd be surprised. Why don't you just change out the side that shakes and see if it fixes the problem. My rotors looked great on my Taurus so I didn't change them when I did the pads and only every once and a while it shimmies just like my Impala did with the 4 wheel disk.
KC_Metal is offline
post #6 of 54 Old 04-15-2010, 01:35 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
I agree change the rotors and see what happens.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #7 of 54 Old 04-15-2010, 04:36 PM Thread Starter
rammit98
the rotors are practically new. they went on less than 30k miles ago. i pulled them to check em out and they are barely worn, and they are straight. checked with machinist straight edge and caliper... they havent been that hot, either.
is there anything else that could cause my problems? drilled and slotted rotors arent cheap and im broke. lol
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
post #8 of 54 Old 04-15-2010, 07:34 PM
dkacat
You've already checked this, but I'm putting it out there anyway. Just had a similar situation on my wife's Pacifica. I thought for sure it was brake rotors, but it was actually a caused by a worn tie rod end. Any slop in those can cause your wheels to shake & brake pedal to pulsate under braking.
dkacat is offline
post #9 of 54 Old 04-15-2010, 08:21 PM
redheadhunter21
redheadhunter21's Avatar
Did this start when you put the rotors in try flipping the side the rotor is on, like take the passenger side and move it to the drivers side, that is if there not directional rotors and do you have an old set to throw on real quick.
Jack up front tires and see if they have movement side to side, and up, down
1996 Dodge Ram Ext. 2wd Sport with a 360
Ebay intake, Custum true dual 2.5" exhaust, 2500 brake calipers and pads, 3500 rear cylinders, Pioneer CD Player, Infinity Kappa 6x9's and reference 6 1/2's, Tint, Excalibur alarm with remote start, 2.5" lift coils and 3" doetsch spindles in front, 1.75" lift shackles and 2" blocks rear, Cragar soft 8's(285/75/16 Dakota M/T), Cragar super sport(33x12.5x15 timberland A/t), SCT by Hemifever, below rails toolbox with alarm hooked up to it, Mossy Oak seat covers and headliner
Wanted: KRC 210x, Shift kit and trans rebuild, 4.10s, locker, oh yea more money
redheadhunter21 is offline
post #10 of 54 Old 04-15-2010, 11:17 PM
Ram Pwnage
Ram Pwnage
Ram Pwnage's Avatar
If there's no loose parts, and the rotors aren't warped make sure the hub surface is clean. If you get rust buildup or contaminants are b/w the hub and rotor it can cause runout that will cause a vibration
2007 Dodge Ram 1500 Quad Cab Big Horn 4x4
Yeah, it's got a HEMI!
Pretty much stock for now, still way better than my 98
Ram Pwnage is offline
post #11 of 54 Old 04-15-2010, 11:36 PM
key99
Quoted: 312 Post(s)
Could worn/loose front suspension arm bushings/mounts be allowing front diff housing to "twist", or jump "foward and rearward", causing the shudder? ..... If so, it may cause trouble with the brakes/antilock. Just a guess.
....Does it shudder and pulse under heavy braking, and/or light braking, or does it ALWAYS do it?
...Are the pulses always "in time" with each wheel/rotor rotation?
99 1500 SLT QCSB 4x4 5.2 227k mi; SUN vac ga, tow hooks ... umpteenth 46re, LONG 28K lb tr cooler, HAYDEN temp ga ... 3.55 c/w broken clip, 255/70 MICH M+S ... RED HEAD, DSS, MOOG trac n adj BJ; AMS in motor n diffs; HUSKY flr mats ... New shocks, drums, EXTREME rotors, bat; rebuilt mas cyl, alt ... Recent windshield, rad, rr springs, frt axle joints n seals ... Hand vac pump to control recirc door
97 1500 SLT CCSB 4x4 5.2 auto 3.55 lsd, factory tr cooler, HD fan clutch; 140k mi
--Both have spray in box liners; need PS coolers, htr cores and better water pumps for htr/winter use
key99 is offline
post #12 of 54 Old 04-16-2010, 09:25 AM Thread Starter
rammit98
i was wondering about the suspension letting the axle to twist slightly... bushings look good, but thought that the alignment (thrust angle, or axle center) might be off.
it shudders under all breaking conditions, seems to get worse the more i drive it in a session. it will be seemingly fine the first stop sign i brake for in my neighborhood in the morning and each subsequent stop it will get more noticeable until its just bad all the time.
i cant be sure if the pulses are in time with wheel rotation. it kinda seems like they are not. it doesnt pulse faster if i am trying to stop from a faster speed...
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
post #13 of 54 Old 04-16-2010, 09:26 AM Thread Starter
rammit98
hubs are about a month old. i have been trying to eliminate stuff and have been replacing parts that might be the problem. hubs were worn ne ways so they got replaced. there is not rust, contamination on the rotors or hubs.
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
post #14 of 54 Old 04-16-2010, 09:33 AM Thread Starter
rammit98
this has been going on for years... since before i put my lift on. used to not be as noticeable, just a shudder on the front pass. side of the truck, now its a pretty bad shudder, and pulsing brake pedal. can't flip the rotors, they are directional.
pretty much everything has been replaced on the front end since this started. they only things that havent been touched are some suspension/steering joints, master/slave cylinder.
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
post #15 of 54 Old 04-16-2010, 10:07 AM
Harveyb
Harveyb's Avatar
my truck did that when the front tires were badly cupped,had it lined up and rotated the tires and the problem was gone.
2001 Dodge Ram 1500 Offroad Sport,fully loaded,360,SCT by Hemifever,flowmaster catback exhaust,Hard bed cover,flush mount(painted to match truck)bed rug,leather interior,custom sub box,2 10" MTX subs powered by a jackhammer amp,memphis door and rear speakers powered by a memphis amp,sir micheals roll pan,fresh paint after tree incident.
fastman 52mm throttle body,Gibson shorty ceramic coated headers,airgap intake,K&N cold air intake,mopar performance valve covers,harland sharp 1.7 roller rockers and magna flow high flow cat and y-pipe.37/12.50/17 BFGOODRICH M/Ts on Cragar Black Rock Wheels,4.88 gearing,converted to 5-speed,5" BDS long arm lift with full rear leafs,plus a 2" coil spacer and 2"taller rear leaf blocks,DT profab trackbar,Borgeson steering box and steering shaft,BD Diesel steering box brace,dual steering stabilizer,Bilstein shocks and stabilizers all around,1-ton steering upgrade.
Harveyb is offline
post #16 of 54 Old 04-16-2010, 10:10 AM
Harveyb
Harveyb's Avatar
also to add,I just thought the rotors were warped(felt just like a warped rotor)and replaced them,I was pretty dissapointed when I still had the problem.
Harveyb is offline
post #17 of 54 Old 04-16-2010, 10:28 AM Thread Starter
rammit98
the tires are wearing very well. they arent that old and i rotate them regularly, problem stays where it is and doesnt follow a tire through rotation.
this is really pi$$ing me off.
later today ill jack it up and start rechecking everything that i can without throwing more money at it.
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
post #18 of 54 Old 04-16-2010, 11:31 AM
key99
Quoted: 312 Post(s)
..... Sounds like an anti lock issue.
.. I would check into a COMPLETE bleeding of the system. Theres 2 DIFFERENT procedures(even the wheel sequence is different); one for "Rear Wheel Anti-Lock" (RWAL), and the other for the optional "4-wheel Anti-Lock Brake System" (ABS).
...... Haynes says there is ORIGINAL and also updated/different? anti-lock valve. Also may need special tool to bleed it and the motor assembly.
...Im guessing its important to identify EXACTLY whats in your truck, as that will dictate procedure. Good luck man. HTH
key99 is offline
post #19 of 54 Old 04-16-2010, 01:11 PM
Ormudboy09
Ram Power
Ormudboy09's Avatar
Ive got the same problem .. Mines a mixture of Rotors and Pitman arm and Idler arm .. check them too . i replaced my pitman and now i have to do my idler arm .. they both had slack in them .
1999 "Ol' Faithful" 1500 5.9 (360)
The Blue Truck club #227
R.I.P "Ol' Girl" 2003 Ram 1500 Quad Cab Hemi
Ormudboy09 is offline
post #20 of 54 Old 04-16-2010, 03:04 PM Thread Starter
rammit98
pitman arm is pretty new. i dont think i have an idler arm (4wd), am i right?
The Money Pit List
- Nerf Bars
- Lift 'er Again
rammit98 is offline
    Wet carpet on front passenger side bill9iron 2G Dodge Stratus - General Talk 0 03-22-2010 05:29 PM
    Clunk from front/passenger side?? Taylor 3G Dodge RAM - General Talk 7 01-03-2009 07:20 PM
    Passenger side front parking light doesn't work LoudRam Dodge Caravan General Talk 7 02-03-2008 03:39 PM
    Help leaking coolant from front passenger side intake MissingLink 2G Dodge RAM - General Talk 1 03-26-2007 12:12 AM
    Water leaking in front door-passenger side guillermo9846 Dodge Neon SRT-4 Talk 0 12-25-2005 06:36 PM
