hard start on warm 318 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 04-13-2010, 03:48 PM Thread Starter
coronetkid
coronetkid's Avatar
Question hard start on warm 318
hey guys, i'm having an issue with my 318. when it's cold it will start right up usually with no issues. once in a while i might stall and i'll have to try again. lately when it is up to temp if i stop somewhere and shut it off the restart is a real pain. it will crank way to long and will only start if i hold it to the floor. and when it finally does fire it sputters and i have to play with the petal to get it to smooth out and idle. it has an edelbrock 600 on it. to best of my knowledge the chock works properly and the timing is correct. also the fuel filter is a week old. any suggestions? thanks
68 Dodge Coronet 87 Dodge Power Ram
coronetkid is offline
post #2 of 7 Old 04-14-2010, 08:17 AM
bherder
Mopar Madness - Get it...
bherder's Avatar
After it's warm, is the choke fully open?
"There's been a DODGE in my garage since 1974"
bherder is offline
post #3 of 7 Old 04-14-2010, 08:26 AM
coastermeister
coastermeister's Avatar
Common problem with our old Dodge trucks. Heat from the manifold boils the fuel out of the carb when you shut it off after a long run.
'86 D150 Custom LWB, White, A/C, 318-2bbl, 727, 6050 GVWR, 9-1/4 3.21 Sure-Grip
All Heavy Duty Options- 114 amp alternator, big radiator, transmission cooler, original owner, everything works!
coastermeister is offline
post #4 of 7 Old 04-14-2010, 09:18 AM
threetwos
AirFuelEddie
Is the fuel line near the exhaust anywhere in the engine bay?
threetwos is offline
post #5 of 7 Old 04-14-2010, 12:44 PM Thread Starter
coronetkid
coronetkid's Avatar
the chock is fully open and the fuel line is tucked up in the frame rail away from the exhaust
post #6 of 7 Old 04-14-2010, 01:11 PM
threetwos
AirFuelEddie
What is the fuel pressure?
post #7 of 7 Old 04-15-2010, 06:55 PM Thread Starter
coronetkid
coronetkid's Avatar
is there a way to rig a temporary gauge on there?
    hard to steer after warm-up kprey73 Dodge Dakota 1st Gen (87 -96) Forum 1 04-29-2007 12:06 AM
    Hard starting problem when warm old98quad 2G Dodge RAM - General Talk 14 09-20-2006 06:40 PM
    '97 Intrepid w/3.5 - hard to start when warm joedodge69 Dodge Intrepid 1st Gen (93 - 97) 1 07-05-2005 01:02 PM
