8 to 5 lug wheel adapter? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 04-11-2010, 02:33 AM Thread Starter
SILVERMEX
SILVERMEX's Avatar
is there an adapter to fit the 2500 8 lug wheels to a 1500 5 lug wheel hub I searched on net but it seems like they arnt available, or any 2500 knock off wheels with 5 lug pattern?
06 QC Hemi Sport 4x4, Magnaflow 12589 Y pipe, Hellas, BFG AT KO 275/65/20
SILVERMEX is offline
Quote Quick Reply
post #2 of 9 Old 04-11-2010, 04:22 AM
ratram
Home of the Whopper
ratram's Avatar
If I were you I wouldn't use wheel adapters. It's another set of lugs that can get loose. Plus I have read of adapter failure before. I never have run them, and I never will.
1998 2500 4x4 Laramie. V10 auto. Infinity sound, leather interior.
Some Mods: Cab lights, 4th gen look mirrors, level.
Free spin hub conversion. Have all parts on hand.
ratram is offline
post #3 of 9 Old 04-11-2010, 07:06 PM
KhakiTJ03
KhakiTJ03's Avatar
Well, from someone that has actually used them, I believe they are fine. I have used them on several vehicles, and ones that actually were used for serious off road use. Never had a problem with loosening or cracking, etc. Spidertrax makes great ones. That being said, im not sure if ive seen ones that adapt from 5 to 8. Good Luck.
Silver '08 Bighorn Hemi QC 4x4 3.92 Gears
Aero Turbine 3030XL, Magnaflow Y-pipe
Superchips 3865,Powerwire
Line-X / X-tra, Bilstein 2" Level, 275-65-20 Nitto Terra Grappler
KhakiTJ03 is offline
post #4 of 9 Old 04-12-2010, 04:41 PM
mitchgmace
mitchgmace's Avatar
Don't do it.
2006 Ram 2500 5.9 CUMMINS TURBO DIESEL (325/610-stock
) 4x4 Standard Cab Long Bed 6-Speed - [SIZE=1]
Westin bed extender, LINE-X, Neopene seat covers
ATS Exhaust manifold/header
Muffler, Silencer ring, & Cat MIA, striaght pipe/stack
S&B CAI =Moe's, Byrd's Intake horn, Fass Fuel System
75hp injectors
Diablosport Predator Stacked with MP8 = Ton of HP
Dual disc clutch
Kore Recon lift 34" Swamper LTB's, Garmin Nav system
572hp/1077tq
Trucks and Guns Club #127
I spend my money on my truck and not my girlfriend, because I'll have it longer and less people have been in it! "
mitchgmace is offline
post #5 of 9 Old 04-12-2010, 04:51 PM
Bubba_Hemi
5 Years... 6 Dodges
Bubba_Hemi's Avatar
I haven't used adapters (but I have used spacers) and with as many people running those as well as 10 lug adapters, I don't see if being an issue.
My advice if you do it though, just be sure to check the lugs ever so often just as you would on your wheels.
WCOG
2009 Dodge Ram
1500 QC SB
TOTM- October '04: '04 Ram 2500 CTD 600 QC SB..........'05 Dodge Stratus SXT SE: October '05- COTM
Posting Foolishness 69.12% of the time
You have one hell of an interesting perspective on things... and by "interesting", I mean retarded
Bubba_Hemi is offline
post #6 of 9 Old 04-13-2010, 08:21 PM
07quad
07quad's Avatar
Loctite! loctite! and torqued evenly..
2007 Ram 1500 QC 4X4
Patriot Blue
325/60R20 BFG all terrains on mopar wheels
levelled with Bilsteins
3" PA body lift
Magnaflow exhaust
Hella's behind the grille
Blue Truck Club member #136
1998 ram 1500 4x4
318 auto
hole in lf fender
38's jammed in stock tearing fenders apart as I turn
waiting to be lifted,dovetailed,shortened and beaten
" having an import that can run 11's...is kinda like coming out of the closet....your going to suprise a lot of people....but in the end your still gay"
07quad is offline
post #7 of 9 Old 04-14-2010, 09:33 AM
'04DMR1500
The White Collar Redneck
They have to be custom made; there was a guy on Ebay that made them, but they are expensive. Also, they are 2 piece, as there is some overlap of the holes. I did a few google searches and came across some information on other forums.
Its kind of hacked to me; but I wanted to put the polished 17" 8 lugs on my truck at one time, which is why I started looking for these.
2004 Ram 1500 4x4 RC/SB:
*4.7/ NV3500/ 3.55s/ 93K miles
*Deep Molten Red Pearlcoat
*Garage Queen
287 Enthusiast Club Member #190
Red Truck Club Member #335
1975 Ford F-250 4WD:
*390/NP435/NP205/D44/D60 4.10s
*Rustfree Oregon Highboy
2014 VW Jetta TDI Premium
*TDI/ 6 spd
*50 MPG Driver
'04DMR1500 is offline
post #8 of 9 Old 04-14-2010, 09:55 AM Thread Starter
SILVERMEX
SILVERMEX's Avatar
looks like to much of hassle, might be easier to contact manufacturer and see if they would do a 5 lug set most likely they will be real expensive and not worth it either, to bad bc those 17s look real nice
post #9 of 9 Old 04-14-2010, 10:23 AM
djtecthreat
QCSB 5.7L Hemi
djtecthreat's Avatar
If I were to do this I would look into changing the hubs to 8 lug.
New truck: White '09 Ram 1500 Hemi Big Horn Crew Cab. Bone stock for now except for a Line-X spray in bed liner.
Old truck: Deep Red '03 Ram 1500 Hemi QC (Lots of mods and goodies over the time I owned it).
djtecthreat is offline
    Wheel adapter/spacers zrm111 2G Dodge Durango - Tire/Wheel/Susp Talk 20 02-24-2010 09:59 AM
    Wheel Adapter or Wheel Spacers 2005RAM1500 3G Dodge RAM - Drivetrain Talk 17 10-02-2005 10:19 PM
    Steering wheel adapter dodgewith20s 2G Dodge RAM - Sport Truck Talk 57 05-17-2005 05:37 PM
    Wheel adapter jeffvb9 3G Dodge RAM - Tire and Wheel Talk 4 03-05-2005 11:21 PM
    Wheel adapter HotCtyPlaya 1G Dodge Durango - Tire/Wheel/Susp Talk 7 10-31-2004 03:04 AM
