cant get crank position sensor out! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 04-03-2010, 11:31 AM Thread Starter
twol8uluz
twol8uluz's Avatar
so of course the day started with the lovely check engine light coming on, which of course then struck my curiousity as to why. come to find out my crank sensor is on the fritz i guess!? (truck is still running fine) so i get the part, find out where it is (back of passenger side lower engine block, can see it through front passenger wheel well) took the bolt out, unclipped the wire harness..woo hoo this is gonna be easy....not so much!! the plastic is coroded inside the block! i tried prying, pulling, scraping, pb blaster, and no results!! and i dont wanna break it off in the block!! has anyone encountered this problem with good results? cuz for now im holding off until i know how to do it without causing much bigger problems!! thanx
2001 DODGE DURANGO SLT 4.7L 4X4-MAGNAFLOW EXHAUST
17" r/t rims w/275-60-17 goodyears
cold air intake
8,000k H.I.D foglights
10,000k H.I.D headlights
twol8uluz is offline
post #2 of 7 Old 04-03-2010, 08:14 PM
mtx11
I replaced two on durangos and 1 on a jeep 5.2 (try that that is tight plus hey have solid fender no removable plastic. But any way there are two bolts that go down in to the block. 1/2 inch socket I think. There is also a ground wire that might get in the way. But you just pull straight up on the sensor. There is a rubber grommet that it sits in.
mtx11 is offline
post #3 of 7 Old 04-03-2010, 11:57 PM
qtipextra
^BIG D^
qtipextra's Avatar
Quoted: 2 Post(s)
What engine do you have? I am guessing the 4.7l based upon your description of the location. And don't you mean the Camshaft Position Sensor? I am thinking you have the wrong sensor on the block. I made the same mistake when I was swapping mine out. The one I removed first must have been the oil pressure sensor. It was lower on the block and was a PAIN to remove once the bolt was released.
The one you need (from what I gather from your post) is actually further up and further to the front of the vehicle. Its JUST below the valve cover, and its easier to pull out.
Take a good look at the new sensor that you have, particularity the head of it IIRC, and compare it to the one you are trying to get out. There was a small difference that becomes obvious once the lower (wrong) one was removed.
Hope this helps, and Good Luck!
"Big D" - SOM Feb '10
Black 2003 Dodge Durango Sport 4.7L 4X4 4.56:1 Auburn LSD
Interior: Double DIN Pioneer HU - 141.7 dB Sound System - Dash Mat - Blue L.E.D Interior Lighting - Blue Gauge Backlighting - Audiovox 2-Way Remote Start - 6 Gauge Cluster Swap
Exterior: Black 1 Piece DEPO headlights - 55W DDM 5000K HID 9007 BiXenon - Hella Optilux 2500 Driving lights - 55W DDM 5000K HID H3 - 3rd Brake light decal "BIG D" - Dodge Hitch/Cover - Dodge Logo on Tinted Tails - Stainless Steel Bar Grill Inserts - Gibson 4" Exhaust Tip
Performance: Dynomax Bullet Muffler - Flowmonster High Flow Catalytic Converter - Chrome Intakes CAI - Superchips 3715 at 91 Octane - NGK V-Power Plugs
Tires/Wheels/Lift: 3" PA Body Lift - 2" T/S Lift - 33 X 11.5 X 16 Firestone Destination M/T Tires - MB Gunner 6 Gun metal gray 16X8 rims
Drivetrain: Rebuilt 545RFE Trans with Transgo Shift Kit - 4.56:1 R/P Motive gears - Auburn High Performance LSD
qtipextra is offline
post #4 of 7 Old 04-04-2010, 11:47 AM Thread Starter
twol8uluz
twol8uluz's Avatar
im sorry, i have the 4.7. yeah i thought it was the right one, it looked about the same. but i did go out and check, there is one that looks just like it towards the front! how do i know the difference, and what was that i was tryin to pull out before then? the box for the part said crankshaft positioning sensor. ugh!! lol unfortunately todays easter and my better half would kill me if i was out wrenching on the truck all day....ill have to deal with it tomorrow.
cold air intake
post #5 of 7 Old 04-04-2010, 11:50 AM Thread Starter
twol8uluz
twol8uluz's Avatar
oh, and to add, ive noticed my trucks been making a "tinging" when exellarating, almost sounds like an exhaust leak....this wouldnt have anything to do with the sensor issue would it?
cold air intake
post #6 of 7 Old 04-04-2010, 12:41 PM
dodgefan360
Platinum 2K R/T
dodgefan360's Avatar
Quoted: 1 Post(s)
I'll wrench on my vehicles all day long, and tell my other half to make me some gruel. She just brought out a grilled cheese for me. It's either I do the work, or she can drive it to a shop, pay the $100/hr. She'd rather make me a sandwich, and not complain.
You may have an exhaust leak. I read that the 4.7 manifold bolts are weak in places, and can crack or sear off(?). I ran a quick search myself and couldn't find anything...weird.
2011 RAM Quad Cab 4x4 SXT - Silver
63,000kms
2000 5.9 R/T - Platinum - SOLD - 18 DEC 2014
155,000m (251,000kms)
Amsoil in the diffs, transfer case and engine - Hughes Plenum - Fastman 52mm TB - K&N FIPK - SCT tuner currently set at 87 octane - Magnaflow 15659 exhaust
dodgefan360 is offline
post #7 of 7 Old 04-05-2010, 03:29 PM Thread Starter
twol8uluz
twol8uluz's Avatar
lol!! yeah, i might have to take it to an exhaust shop and see what they say, unfortunately. but right now its not a huge concern. as far as my crank or cam sensor, the light mysteriosly turned off without me repalcing any parts, so i think right now i might just ride it out until it comes back on or presents problems!!
cold air intake
    Crank Position sensor/cam sensor MONKYMAN 2G Dodge Dakota General Talk 0 05-27-2009 02:31 PM
    fs...CRANK POSITION SENSOR ILSAVU For Sale - Truck Parts 4 12-25-2007 10:53 PM
    Where is the crank position sensor on a 97 colty045 2G Dodge Dakota General Talk 3 07-30-2006 09:15 AM
    Crank Position Sensor YellaDakRT Dodge Dakota 1st Gen (87 -96) Forum 2 01-14-2003 09:19 PM
