How to tell if wheel bearing is bad - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 03-30-2010, 02:27 PM Thread Starter
jeepme79
I've got an '03 2500 4x4 CTD with a very loose front end. I know the ball joints are bad, and I'm assuming the wheel bearings are bad too, but my question is unless the bearing is really bad, how can I tell if it still needs replaced? Is there any way to really test it? I am seeing a little rusty dust gathering on the wheels leading me to believe the bearings are dry, but with a sealed unit, it's hard to verify that.
Tearing it apart tonight. Any help would be greatly appreciated.
Thanks
2003 2500 CTD QC 4x4 6-speed
- Bully Dog Crazy Larry
- 295/70r17 Nitto's
- 380,000 on the clock
jeepme79 is offline
post #2 of 9 Old 03-30-2010, 02:32 PM
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
Usually there is a howling sound that will be worse when you turn one way as apposed to another.
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #3 of 9 Old 03-30-2010, 03:49 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 229 Post(s)
If you jack the truck up and spin the wheel, you'll hear it. It will sound like a clunck clunck sound when turning the wheel. Rather than a smooth motion, you'll almost feel the wheel stop at points when they are bad.
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #4 of 9 Old 03-31-2010, 11:49 AM Thread Starter
jeepme79
Bad u-joint and bad ball-joints make that hard to diagonse. I pulled the bearing out last night and by hand it feels fine, so I'm not really sure if I should replace it or not.
On a side note, does the axle shaft have a c-clip inside the diff housing? I tried pulling the half shaft out and it sure feels like it.
- 295/70r17 Nitto's
jeepme79 is offline
post #5 of 9 Old 04-01-2010, 05:41 PM
RobRamAZ
RobRamAZ's Avatar
i will make a nosie and you will know it, Bearing degrade slowly over time but when one goes bad it will make a friction nosie, you sould hear it. If it is a loud nosie change it soon i have seen the friction so bad that they can cause a fire in the frontend.
RobRamAZ is offline
post #6 of 9 Old 04-03-2010, 07:48 AM
ramminsilver
ramminsilver's Avatar
Good luck gettin' them off. Did mine a month ago. PITA x 10!
2004 DODGE RAM 2500 LARAMIE w/ THE HEMI - BLACK ON BLACK/GRAY LEATHER - 295/70/18 NITTO TRAIL GRAPPLERS - 18x9 FUEL BOOST 5.75" BS/+20 OFFSET - AEM BRUTE FORCE CAI -CUSTOM MAGNAFLOW CAT-BACK EXHAUST 14" SI/SO - MAGNAFLOW Y-PIPE - NGK 5306 SPARKPLUGS - DIEHARD PLATINUM BATTERY - RECON SMOKED CAB AND 3RD BRAKE LIGHTS - RECON FIRE AND ICE TAILGATE BAR - TOTAL LED CONVERSION FRONT TO REAR - BILSTEIN'S ALL AROUND - EXTANG FULLTILT TONNEAU COVER - ALPINE 9886 HEAD UNIT AND ALPINE MRP_M300 AMP - JL AUDIO 12w1v2 SUBWOOFER - AVITAL 4103 REMOTE START AND KEYLESS ENTRY - UNIQUE COATINGS FLASHTECH HIDS - 9007 6000K BI-XENON HEADS AND 9006 6000K FOGS - EZ-DOWN TAILGATE ASSIST - HUSKY FLOORMATS - SUPERCHIPS CORTEX 3950 w/ TRANNY TUNE - MOPAR REAR WHEEL WELL LINERS - BUSHWACKER EXTEND-A-FENDERS - TEKONSHA PRODIGY BRAKE CONTROLLER-AUTO METER FACTORY MATCHED TRANNY TEMP GAUGE
ramminsilver is offline
post #7 of 9 Old 04-03-2010, 07:49 AM
ramminsilver
http://www.dodgetalk.com/forums/showthread.php?t=292195
post #8 of 9 Old 06-30-2010, 07:36 PM
hemipower0469
Jack uP the front end, put one hand at 12oclock one at 6, rock the tire if you feel play the bearing is bad, just make sure your lower and upper ball joints are not moving and the hub is moving.
hemipower0469 is offline
post #9 of 9 Old 07-01-2010, 04:53 AM
LPGHemi
LPG Hemi
LPGHemi's Avatar
Quoted: 11 Post(s)
Yep....the CV/axle/front drive shaft have a retaining snap ring inside.
THe manual says to use two pry bars to pry out the drive shaft.
AL.
03 Dodge Ram 1500 Hemi SLT
5.7 ltr QC sb 4x4
Performance Mods
K&N air & oil filters.
NGK Iridiums. Detroit TruTrac. TMR delete.
Procomp ES9000 with torsion bar tweak.
EBC slotted rotors with Yellow stuff pads and Cooper Zeon LTZ275/60/R20.
3" T304 stainless steel custom exhaust with high flow cat side exit near rear tire with DMH Electric cutout and T304 custom muffler.
Prinz LPG VSI sequential gaseous injection system
with 2x70 litre siamesed fuel tanks.
Exterior Mods
Siege Engineering Kong Mk2 Train horns 200 psi Viair 480C compressor & 3 gallon tank.
6000K HID Twiggy hi/lo + fogs.
White front and red rear LED license plate bolt Skulls.
Rear view colour camera with infra red, hooked up to an LCD rear view mirror doubling up as a 7" monitor
Tints 20's & Westins.
Raider Low Rider solid tonneau.
Xenon wheel arches.
Billet Aluminium Rapid hitch.
EZ lift tailgate torsion bar.
Bug deflector.
Dodge valve caps.
Interior Mods
Black coin holder ha ha ha.
DVD head unit.
2xRockford Fosgate Punch 12" subs.
2 Kenwood 6x9's & 2 5.25's.
2x9inch DVD screens built into custom headrests.
Full custom black leather interior with red piping & custom stitched red Ram logo into front seat backs .
Toad Thatcham cat 1 alarm
LPGHemi is offline
    Bad Wheel Bearing = Vibration while braking? jmmagrin 3G Dodge RAM - General Talk 14 09-29-2009 07:19 PM
    Bad differential bearing?? stuss73 2G Dodge Stratus - General Talk 0 05-01-2008 10:33 PM
    A bad wheel bearing. powerfulhemi 3G Dodge Dakota - Drivetrain Talk 6 01-10-2008 10:50 PM
    Wheel bearing bad? Grantman31 2G Dodge RAM - General Talk 6 07-29-2006 08:27 PM
    How to tell if wheel bearing or is the rack is bad? Stampede4.7 3G Dodge RAM - General Talk 10 01-26-2006 05:57 PM
