Dodge Talk Community Forum
Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Dakota 2nd Gen (97 - 04) Forums > 2G Dakota - Drivetrain Talk
mreinsmith
  2002 Half Shaft Replacement Help - Posted: 03-23-2010, 09:05 AM
State: PA
Post #1
I’m working on replacing the half shafts (automatic Transmission)
All the documentation and posts I’ve read indicate that the shafts should come out without having to remove the upper or lower control arm ball joints.
However, When I went to release the Half Shaft the spline on the inner side (I think they call it the axle shaft) pulled out of the transfer case. The way they describe the procedure, the axle shaft is not supposed to pull out.
I still can’t get a clear answer whether this is supposed to happen. So now I have two problems I need to address before I’ll feel comfortable working on the Passenger side.
1 – I’m assuming I should replace the Bearings in the transfer case at this point?
2 – How do I get the spline off the inner side of the half shaft. I’ve read there is a puller to do the Job, but I need to find where to get one. Unless there is a more practical way to do it? (it is really seized in there)
My fear of course is now the Transfer case is screwed up, but I don’t think that is case, I just need to be sure before I go any farther
Any help on this issue would be greatly appreciated!
Thanks
M
HELP! - Can't get inner CV / half shaft off angusdevil 3G RAM - 4X4 Talk 31 07-24-2009 09:34 AM
Cv Half shaft replacement mpersica 3G RAM - Drivetrain Talk 12 01-11-2009 05:13 PM
Half shaft length? WannaBeFast Neon SRT-4 Talk 11 11-12-2007 12:26 AM
half shaft ? airborne1113 3G RAM - General Talk 2 05-12-2007 04:22 PM
half shaft MulesHemi Dakota 1st Gen (Pre-1997) Forum 0 04-26-2007 12:55 AM
