Remove pass airbag cover to remove dash... Help ASAP - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 03-19-2010, 05:31 AM Thread Starter
20inchDurango
So I'm trying to repair the leather on my dash. I've removed the A-pillar molding on each side, the air vent molding, and have the entire top dash panel ready to come out... Except there is 1 or 2 screws holding it in above the passenger airbag. Yep. The dash panels that needed to be removed are out, but I cannot figure out how to remove the airbag door/cover to remove the last screw or two.
I've disconnected the airbag after removing the radio, and the truck battery disconnected.
How do I remove the air bag cover to get to the screw(s) I seek!
Thanks all!
20inchDurango is offline
post #2 of 6 Old 03-19-2010, 09:42 AM
Durangoholic
It doesn't need a Hemi
Durangoholic's Avatar
What year is your Durango?
1999 Durango SLT 4X4 5.9L Engine, 231HD TransferCase
__________________________________________________ ___
Induction: Shaker hood scoop ∞ Fastman 52mm TB ∞ Mopar M1 Intake
Ignition: MSD blaster coil ∞ MSD 9mm wires
Engine: Edelbrock Performer RPM heads ∞ Comp. Cams RR ∞ 180 T-stat ∞ CC grind CRS264HR-12
Exhaust: Edelbrock TES ∞ Thermo-Tec heat shield ∞ Magnaflow Cat-back
Suspention & Tires: 2" T/S lift ∞ BFG 32x11.5 AT
Electronics: SCT Custom Tune ∞ TPS modified ∞ Dynojet WB2
Trim: Optilux Angel Eyes ∞ EL Gauge Face w/bezel ∞ Lo-Tek gauge pod
Durangoholic is offline
post #3 of 6 Old 03-19-2010, 12:49 PM Thread Starter
20inchDurango
Shoot, I always forget to include that.
2001 Dodge Durango / 5.9L / 46RE Trans / SLT / 2WD
post #4 of 6 Old 03-20-2010, 09:23 AM
Durangoholic
The whole airbag comes out, cover and all. For the 99, you access the two screws through the glove box opening. You need to remove the glove box. I know the dash is different for your year, but mayb e the design is similar.
post #5 of 6 Old 03-20-2010, 07:34 PM Thread Starter
20inchDurango
Well that's a PITA. I'll dive into it in the morning!
post #6 of 6 Old 03-28-2010, 04:59 PM Thread Starter
20inchDurango
I finally got around to removing the leather dash panel. I removed the glove box and unbolted the airbag enough to allow me to wiggle in a screw driver and remove the two nuts I'd been needing to get to.
Here she is gutted down.
I was able to use 5 min epoxy and get about 10 inches of the leather material glued back down to the plastic molding... Tomorrow I'll head to Home Depot and get about 20 1" clamps and epoxy the leather that's no longer adhered to the plastic molding and then clamp the leather down with folded cardboard and clamps and let her dry. Woohoo! Then, put it all back together, yay!
    Remove Dash Tips DadTruck 1972-1987 Dodge Ram Trucks (D, W-series) 2 02-26-2009 02:31 PM
    Remove Dash Hemi1 3G Dodge RAM - Interior/Exterior Talk 9 03-03-2008 04:05 PM
    HELP ASAP-HOW DO I REMOVE 20" SPARE TIRE????? krs225 3G Dodge RAM - General Talk 66 02-15-2008 11:49 AM
    How Do I Remove The 06 Dash? MonsoonMike 3G Dodge RAM - Interior/Exterior Talk 13 12-03-2007 03:52 PM
    Remove dash BigJon Mobile Audio & Electronics Talk 18 08-11-2005 09:45 PM
