Axle nut torque spec? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 19 Old 03-17-2010, 03:54 PM Thread Starter
t1320t
t1320t's Avatar
Hey guys, I'm doing wheel bearings on a 2003 RT again. Does anyone know the torque spec for the axle nut?
t1320t is offline
post #2 of 19 Old 03-17-2010, 06:33 PM
minivanguy
Silver Member
180ftlbs
minivanguy is offline
post #3 of 19 Old 03-17-2010, 07:42 PM
TX_Firehawk
Neon Master Mechanic
TX_Firehawk's Avatar
Interesting. 1st gens are 135. Seems logical tho, a lot of things are a little scaled up on 2nd gens.. disc thickness, torque rating on the trans, etc.
Black 97 2.4L Coupe
"Doubling down on stupid is not a particularly good idea"~Breitbart
TX_Firehawk is offline
post #4 of 19 Old 03-17-2010, 08:50 PM
minivanguy
Silver Member
IDK where you are getting 135. my 96 neon calls for 150.. which doesn't make much sense since the thread size and nut size is the same... even weirder is my 1988 Omni specs Hub nut at 180 also.
post #5 of 19 Old 03-17-2010, 10:55 PM
TX_Firehawk
Haynes Repair Manual 95-99 chapter 8 page 1 Clutch and Driveaxles torque specs.
Black 97 2.4L Coupe
post #6 of 19 Old 03-18-2010, 06:23 AM
minivanguy
Silver Member
that figures. I'm using the Factory service manuals.
I quit using the cheapo reference books (haynes, chilton, etc) when 25 years ago, I was rebuilding my 904 trans and their manuals said to torque the valve body to 110ftlbs. It was pretty obvious this was a printing error. I torqued them to 110 inlbs because I have more common sense
post #7 of 19 Old 03-18-2010, 08:13 AM Thread Starter
t1320t
t1320t's Avatar
Thanks guys. This car EATS wheel bearings... I've done 3 on each side and it only has 97k. 180 ft/lb looks like what I'll be using. For those of you interested, this might help out with other vehicles also
http://www.autowaresgroup.com/resour...rque_specs.pdf
t1320t is offline
post #8 of 19 Old 03-18-2010, 08:29 AM
minivanguy
Silver Member
WOW, that's a lot of issue. I use to circle track race an L-body and a gen1 Neon and never had a wheel bearing problem. Just think about the loading I put on my RF. There's no way a street or even a weekend racer would load the bearing as much as I did. Use the high end Borg Warner wheel bearing From Napa and make darn sure you're pressing them in correctly.
Another option, I use for bearings, is I go to a local industrial bearing supplier and have them find a better quality bearing. This is usually cheaper than buying the same bearing from a parts store. When I rebuild the Getrag trans in my cummins d350, I got all my trans bearing from the industrial dealer. the prices saved me over $50.
post #9 of 19 Old 03-18-2010, 08:54 AM Thread Starter
t1320t
t1320t's Avatar
Yeah, this car torques me off. It's only a daily driver & shouldn't be going through bearing like it does. I actually have 2 spindles for each side to decrease the down time when swapping bearings. I've used Timken in the past & have recently tried the National (Moog) bearing. An industrial bearing may be an option.
t1320t is offline
post #10 of 19 Old 03-18-2010, 06:25 PM
TX_Firehawk
This is the 1st time I have heard of someone eating bearings like that..
and MiniVan I had never compared the specs from the FSM to the Haynes.. I will start pulling the FSM out if I need torque specs and leave the Haynes for picture reference
I will ask around but I can't see how you run thru bearings like that. Do you drive it hard/ on dirt/ rough roads? Not sure what else could cause it. Are you packing them before you install? I know that is a silly question but ya know.
Black 97 2.4L Coupe
post #11 of 19 Old 03-19-2010, 07:49 AM Thread Starter
t1320t
t1320t's Avatar
Yeah, this is the 1st vehicle I've ever wrenched on that has such an issue going through wheel bearings. It's just a daily driver that doesn't get driven that hard on normal paved roads. The bearing a dual sealed unit that isn't greasable. Well, I should say that it comes pre-greased.
t1320t is offline
post #12 of 19 Old 03-19-2010, 07:51 AM
minivanguy
Silver Member
sure might be an assembly issue.
As for haynes for FSM, if you have an FSM wtf would you waste your time with the generic manual?
post #13 of 19 Old 03-19-2010, 09:14 AM Thread Starter
t1320t
t1320t's Avatar
I thought it was an assembly issue too, but, I have 2 knuckles that I've used & I've used Moog & Timken bearing with the same results. Crap, I got frustrated with it that I had my ASE Cert buddy come over & press one in... he did it exactly the same way that I do.
t1320t is offline
post #14 of 19 Old 03-19-2010, 09:40 AM
minivanguy
Silver Member
Well, everything you said and done absolutely makes no sense what so ever. Are you by chance miss diagnosing? How about just getting another set of used spindles and changing again.
If I had your car in my hands I could guarantee that you wouldn't have a wheel bearing issue.
post #15 of 19 Old 03-20-2010, 03:38 PM
TX_Firehawk
Minivan, my FSM is a PDF, Haynes is hard copy. So that is why I pick it up a little more often.
I know I know I need a hard copy FSM.
Black 97 2.4L Coupe
post #16 of 19 Old 03-22-2010, 03:14 AM
dodgeneonACR98
So whats UR excuse?
I have replaced my bearings about 3 times since I owned the car. Iv'e also put well over 140,000 on it since then. So thats probably not too bad really. Good luck getting yours straight.
Squad member #53 [/url]
04 Neon SRT-4
98 Neon ACR-2.4 swaped with goodies
dodgeneonACR98 is offline
post #17 of 19 Old 03-22-2010, 08:14 AM Thread Starter
t1320t
t1320t's Avatar
Man, I'm glad to hear someone else has wheel bearing issues w theirs.
t1320t is offline
post #18 of 19 Old 03-22-2010, 02:32 PM
TX_Firehawk
Ya know ACR you 2 guys are the only ones I have ever come across that had to change a wheel bearing that does not auto cross their car.
I am going to poke around, maybe I am missing something.
Black 97 2.4L Coupe
post #19 of 19 Old 03-22-2010, 03:29 PM Thread Starter
t1320t
t1320t's Avatar
I should clarify some specs on the knuckles I have... I said I have 2 for each side. 2 are the factory originals that came on the car, the other 2 are OEM pieces that are (were) brand new.
TX-I'd like to hear some tech feedback re installation procedures in case I'm missing something blatantly ovbious!
Thanks for the feedback guys.
t1320t is offline
    '03 GC - Lug-Nut Torque Spec rcsec Dodge Caravan General Talk 1 02-12-2008 06:50 PM
    Bolt Torque Spec for Chrysler RAM MAN Mopar Muscle Talk 4 01-30-2007 04:34 PM
    axle, wheel bearing torque spec ptextreme 3G Dodge RAM - Drivetrain Talk 0 08-09-2006 06:37 PM
    Header Torque spec 1strongdodge 3G Dodge Ram Performance Talk 1 01-14-2006 08:05 AM
    wheel torque spec mr.nobody Dodge Neon - Interior/Exterior Talk 3 10-11-2005 12:05 AM
