radiator drain petcock - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 03-16-2010, 06:12 AM Thread Starter
Megunticook
Megunticook's Avatar
Quoted: 3 Post(s)
I finally installed a new radiator (Proliance).
When I went to install the drain petcock, much to my surprise the hole in the bottom of the radiator was too small for the 1/4" NPT fitting. So I went and got the next smallest size petcock, 1/8" NPT, and the hole is too big.
Is there a 3/16" NPT size petcock? Guy at the parts store said no.
Why in the world would this radiator have an oddball-size hole?
___________
1973 W100 shortbed, 318, 4-speed standard
Megunticook is offline
post #2 of 11 Old 03-16-2010, 06:58 AM
3834B
Metric???
3834B is offline
post #3 of 11 Old 03-16-2010, 10:09 AM
bherder
Mopar Madness - Get it...
bherder's Avatar
I'm guessing that 383 is guessing right..
Doncha' love finding this stuff out after you have something installed and all the bolts tight?
Yeah, there is no such thing as 3/16" pipe thread and there is also no such thing as 'metric' pipe thread...
It's probably some metric size thread where the drain plug uses an o-ring to seal. If you have a set of metric taps, you might want to run a tap in the hole to figure out what size it is. But be careful as metric stuff has different thread pitches also.. Don't want to bugger up your threads.
Jeeeeez. You'd think if they were gonna go 'different' on a new rad, they'd at least of supplied you with the right draincock...
"There's been a DODGE in my garage since 1974"
bherder is offline
post #4 of 11 Old 03-16-2010, 11:12 AM
buck99
Buck99
buck99's Avatar
I had the same problem with my rad so I ran a 1/4 NPT tap into the hole.
Works now.
76 W100 short box sweptline - 400 cid
79 D150 short box utiline - 440 cid
47 Willys CJ2A
95 Camaro Z28 - LT1 350
99 Dakota 4x4 - 5.2 litre
04 GMC Sierra Z71
08 Charger RT - 5.7 Hemi
and others that don't move
buck99 is offline
post #5 of 11 Old 03-17-2010, 05:37 AM Thread Starter
Megunticook
Quoted: 3 Post(s)
Originally Posted by 3834B View Post
Metric???
Could be...why the @##$!& would a big old radiator for an old American vehicle have a metric thread, though? Seems odd.
___________
post #6 of 11 Old 03-17-2010, 05:44 AM Thread Starter
Megunticook
Quoted: 3 Post(s)
I'm kicking myself for that, as the thing was sitting in my workshop for 2 months and I could've easily checked it. Never even occurred to me that it might not be 1/4" NPT.
I'll pull out my metric thread chasers and see. I'm guessing I won't be able to get a petcock for it, though.
It had a flimsy-looking plastic "plug" in it that I assumed was just to keep dirt, etc. out during shipment. It was not threaded, just pulled right out. I chucked it during the installation.
Is it possible there is a bushing of some kind in there? There's a thin hexagonal shape around the hole. I put a socket on it thinking I might unthread it, but it didn't budge and I didn't want to lean on it too hard.
___________
post #7 of 11 Old 03-17-2010, 05:45 AM Thread Starter
Megunticook
Quoted: 3 Post(s)
Works now.
Hmmmm....there's an idea.
___________
post #8 of 11 Old 03-17-2010, 10:10 AM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
Probably made in china.
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #9 of 11 Old 03-17-2010, 06:00 PM
Awingandachair
Doug
Awingandachair's Avatar
Some after market radiators just have a plastic plug for a drain.
Awingandachair is offline
post #10 of 11 Old 03-17-2010, 11:23 PM
mikehopkinsjr
yep sure do ^^
mikehopkinsjr is offline
post #11 of 11 Old 03-18-2010, 09:55 AM Thread Starter
Megunticook
Quoted: 3 Post(s)
Hmmm, let's see, a new brass petcock retails for maybe $3, which means it costs probably $1. A plastic plug costs maybe $ 0.25. So the business geniuses at Proliance are making an extra 75 cents on a $180 product by substituting a plastic plug for a proper petcock. And in the process the customer gets an inferior product because when you go to drain the thing you get coolant spilled all over everywhere.
Might this be the same business mentality that brought such financial success to GM?
I'll see if I can tap out that friggin' hole I guess.
I understand the need to be competitive in the global marketplace, but sometimes I think the folks running our nation's companies are just plain idiots.
But hey, no problem, I guess nowadays you can drive your company into the ground while lining the executive's pockets and no problem, us taxpayers will bail you right out and you can do it all over again.
___________
    is there a radiator drain plug slingin_mudd 3G Dodge RAM - General Talk 14 01-17-2009 12:22 PM
    Radiator Flush - Petcock Won't Flow lanesharon Dodge B-Series Vans 1971 - 2003 23 04-12-2007 01:13 AM
    Radiator drain plug nuramman 3G Dodge RAM - General Talk 10 08-20-2006 12:17 AM
    Need help quick! (Radiator won't drain) ice8 2G Dodge RAM - General Talk 9 09-28-2004 01:40 PM
    Where Is The Radiator Petcock???? rtagg 2G Dodge Dakota General Talk 0 08-10-2004 01:36 PM
