Rear Brakes - Star wheel, self adjuster - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 03-13-2010, 05:36 PM Thread Starter
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Question Rear Brakes - Star wheel, self adjuster
It seems that the rear brake drum will NOT come off since the shoes are great in adjustment position.
Here's my question.
So, what direction do I need to turn the start wheel for brake drum removal via the slot in the drum backing plate from the backside?
Is it up or is it down?
71 Duster 340, 74 T&C 440-Interceptor, 74 Duster /6 225, 76 Aspen /6 225, 79 Volare S/6 225, 81 Pacer I6 258, 88 Colt I4, 85 Caravan 2.6L, 94 Caravan 3.0L, 96 Caravan 3.3L, 00 Ram Van B1500 3.9L, 01 Ram Van B2500 5.2L, 05 Caravan SXT 3.8L, 03 Ram 2500 5.7L HEMI
stev is offline
post #2 of 11 Old 03-13-2010, 09:02 PM
97B2500CCV
Gone but not forgotten
97B2500CCV's Avatar
For our vans it is "down". The adjuster moves "up" to adjust the brakes.
1977 Chevrolet Impala Sedan, 5.0L, TH200, 2.56:1, 106K miles, 37 Lifetime Warranty Parts.
1989 GMC Sierra Extended Cab 5.7L, 5 Speed, 3.08:1, 327K miles, 0 Lifetime Warranty Parts.
1997 Dodge Ram B2500, gone.
97B2500CCV is offline
post #3 of 11 Old 03-16-2010, 08:54 PM Thread Starter
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Question
So, if I move the tool down and the adjuster moves up, the brake pads will move closer to each other and i can finally get the drum off?
Is there any other tool needed to pull the drum off as well?
stev is offline
post #4 of 11 Old 03-16-2010, 09:53 PM
alloro
Elder User
Quoted: 17 Post(s)
The inside of the star wheel (the differential side) has to move down. This holds true for either side. So in looking at the star wheel from the back bumper of the van, the driver's side turns clockwise to retract the brake shoes and the passenger side turns counterclockwise to retract the brake shoes.
The only other tool you will need is a long thin screwdriver to push the adjuster arm away from the star wheel. If you don't push the arm away it is very difficult to turn the star wheel in the loosening direction.
alloro is offline
post #5 of 11 Old 03-16-2010, 09:58 PM
alloro
Elder User
Quoted: 17 Post(s)
Here's a drawing of the passenger side brake assembly. It should help you to visualize where the star wheel adjusting arm is.
alloro is offline
post #6 of 11 Old 03-16-2010, 11:15 PM
97B2500CCV
97B2500CCV's Avatar
Interesting for my diagrams and my brakes on my van the adjuster turns up (from the drum side) to tighten the shoes. Wonder what year Dodge updated the system.
post #7 of 11 Old 03-17-2010, 10:00 AM
alloro
Elder User
Quoted: 17 Post(s)
You just have to be different...don't you!
But seriously you are correct, I screwed up but mixing up Chrysler and GM drum brakes. So do the complete opposite of what I wrote above.
alloro is offline
post #8 of 11 Old 03-20-2010, 11:24 AM Thread Starter
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Found this link to a 1999 Ram Van rear drum "How To" It seems easy enough.
http://www.freeautomechanic.com/brake-drum-brakes.html
stev is offline
post #9 of 11 Old 03-23-2010, 09:11 PM Thread Starter
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Well, the passenger side star wheel from the slot rotates upward to get loose. Just did that tonight.
I had a 3-lbs hand sledge hammer that took a while to break the drum free from the studs. The shoes were no help being tight either. When I got the drum off of the hub face, I could then stick in a flat crow bar and pry a little all around that inner hole that faces the wheel side.
The eHow was a great help on how to whack the drum to make it free.
stev is offline
post #10 of 11 Old 03-23-2010, 10:04 PM
97B2500CCV
97B2500CCV's Avatar
The driver side will as well.
post #11 of 11 Old 03-24-2010, 06:59 PM Thread Starter
stev
Seating for 12
stev's Avatar
Quoted: 3 Post(s)
Well, I found a trick to get the latch off of the star wheel. All you do is punch it hard and away from the start wheel via the access slot. Now you can turn the wheel either way freely.
When you are ready to put things all back together, fix the latch to contact the star wheel again and then put the drum back on.
stev is offline
    Chrysler Recalls Rear-Wheel-Drive Cars For Front-Wheel Issue RAM MAN Rumor Mill & Gossip Talk 0 11-04-2009 06:24 PM
    Rear wheel locking in 4 Wheel Drive when turning Viking07 3G Dodge RAM - Drivetrain Talk 55 12-19-2007 12:59 AM
    2 Wheel to 4 Wheel ABS Brakes? 71'dart 3G Dodge RAM - General Talk 2 12-04-2007 10:13 PM
    star wheel adjustment cumminandgoin 2G Dodge Ram Diesel Talk 4 07-15-2007 10:07 PM
    Rear brake adjuster screw assembly Snipe48 2G Dodge Dakota General Talk 2 11-24-2003 08:08 PM
