4.7 timing chain change - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 03-02-2010, 09:58 PM Thread Starter
RamMac1
RamMac1
How hard is it to change the timing chain on a 2002 Ram 4.7L? Is there anywhere I can get good step by step instructions for this? It is my sons truck and he really can't afford to pay someone if we can do it ourselves. Thanks
RamMac1 is offline
post #2 of 10 Old 03-05-2010, 08:08 PM
mastertech
its not a real tuff one
mastertech is offline
post #3 of 10 Old 03-06-2010, 08:33 PM
AIR_RAM
AIR_RAM's Avatar
Quoted: 14 Post(s)
The timing chain on the 4.7L Is a HUGE task. You will need to remove and set to the side your AC compressor, Alternator, Power steering pump. Then you will need to remove the valve covers, front cover and oil pan. Removing the pan while installed in the truck is a PITA all by itself. There are 3 chains 4 sprockets... 2 tensioners. There is more too it then one would think.
Once in, setting the timing is actually a bit tricky but simple once you know what your doing.
This is NOT a small job. Expect to be down a couple of days if you have never done this before.
SPEED SAFE, AIR RAM
4.7L PERFORMANCE ENTHUSIAST - DODGE RAM's, DAKOTA's, DURANGO's & JEEP's.
AIR_RAM is offline
post #4 of 10 Old 03-09-2010, 10:35 PM
pjd
pjdhill
I had to do the head gaskets on my Durango 4.7 whic involves taking the timing chains off and putting them back on. Did not have to take the oil pan off - not sure why Airram - who is the #1 expert on the 4.7 - says you have to. To take the oilpan off is a major job in itself
I think there is two special tools you can't do without 1) a special tool to hold the timing chains onto the main sprocket. I don't see how you can put the chains back on without it - twist ties just don't work and 2) special tool to put the dampner back on. You can take the dampner off with a good quality 3 prong puller (Don't use the outside ring to pull it off with).
Good luck
pjd
pjd is offline
post #5 of 10 Old 03-24-2010, 02:46 AM
speedy81304
there is a chain from the crank to an idler sprocket, then 2 chains from the idler sprocket to the cams, one left one right, you must drop the oil pan. to get the front chain and sprocket off the crank. when you did your head you only did half the job, on working with the three chain timing set. there is three timing marks, the idler to the crank then the cams to the idler. 75% chance its a bad auto chain adjuster that went bad and causing the chain to make noise.
you should get your self a repair book. as there is step by step on how to do it and what tools you will need.
speedy81304 is offline
post #6 of 10 Old 03-24-2010, 01:56 PM
AIR_RAM
AIR_RAM's Avatar
Quoted: 14 Post(s)
I have replaced many sets of heads and did not need to remove the oil pan to do so... BUT if your replacing the timing chain... You will need to do allot more then just remove a valve cover. You will need to remove the entire front cover to expose the chains. If you look close you have 3 chains and 4 sprockets. They all go to the idler sprocket in the center. So you have on crank chain that goes from the crank to the idler. Then you have two chains that go from each head down to the idler. The ONLY way to remove the lower crank sprocket is to remove the oil pump. The only way to remove the oil pump is to remove the pick up tube... the only way to remove the pick up tube is to remove the bolt that is on the bottom of the oil pump...which means you need to remove the pan to get at that one oli pick u p tube bolt.
I hope this helps.
SPEED SAFE, NICK
AIR_RAM is offline
post #7 of 10 Old 03-25-2010, 05:34 PM
speedy81304
it sounds harder then it is, but with out a manual, you would be lost, as there is timing marks, TQ specs, and it will make life easy to have a guid on how to do it.
post #8 of 10 Old 03-28-2010, 12:19 PM
AIR_RAM
AIR_RAM's Avatar
Quoted: 14 Post(s)
I have a copy of the manual if anyone is interested.
SPEED SAFE, NICK
AIR_RAM is offline
post #9 of 10 Old 04-02-2010, 03:17 AM
mastertech
no need to mess with oil pan the oil pump is behind the sprocket. its not that hard of a job. here is your timing marks
post #10 of 10 Old 04-03-2010, 10:05 AM
AIR_RAM
AIR_RAM's Avatar
Quoted: 14 Post(s)
You know... Now that you mention it... Your right... The pump does not need to come out. I have only done it while building the engine outside of the vehicle... so I clearly remember having to deal with the pump... Sorry for the confusion.
I can admit when I'm wrong and I was wrong. The pump does not need to come out... BUT the front cover does need to come off. I just went a step further then you had to go...
SPEED SAFE, NICK
AIR_RAM is offline
    New Timing Chain cbarny 2G Dodge Intrepid - General Talk 0 08-27-2009 08:09 AM
    Timing Chain rssking 2G Dodge Stratus - General Talk 2 07-23-2007 02:28 PM
    when to change the timing chain ? RAM MAN 1G Dodge Durango General Talk 7 10-31-2003 11:00 PM
    Does The Hemi Have A Timing Chain Or Timing Belt? ITSAHEMI 3G Dodge RAM - General Talk 6 07-05-2003 12:55 PM
    Timing chain??? spurgon 2G Dodge RAM - General Talk 11 03-22-2003 04:51 PM
    You may not post new threads
    You may not post replies
