1195 B3500 Fuse Diagram ? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 02-23-2010, 07:57 PM Thread Starter
Bunky1267
Question 1195 B3500 Fuse Diagram ?
Does someone have a copy of there owners manual for a Dodge 1995 B3500 I need a diagram of the fuses and what goes where,
I have no Dashlights ....
Bunky1267 is offline
post #2 of 9 Old 02-23-2010, 08:23 PM
alloro
Elder User
Quoted: 19 Post(s)
Originally Posted by Bunky1267 View Post
I have no dash lights ....
Is your dimmer switch turned down by any chance?
alloro is offline
post #3 of 9 Old 02-23-2010, 08:28 PM Thread Starter
Bunky1267
Dimmer Switch
no that was one of the first things I thought off, We just got this van today and I really haven't had time to check it out much I just thought it was odd that every dash light would of been out,
post #4 of 9 Old 02-23-2010, 08:36 PM
97B2500CCV
Gone but not forgotten
97B2500CCV's Avatar
Here is from a 97 B2500, yours should be very similar:
Check fuse number 3 and 20.
1977 Chevrolet Impala Sedan, 5.0L, TH200, 2.56:1, 106K miles, 37 Lifetime Warranty Parts.
1989 GMC Sierra Extended Cab 5.7L, 5 Speed, 3.08:1, 327K miles, 0 Lifetime Warranty Parts.
1997 Dodge Ram B2500, gone.
97B2500CCV is offline
post #5 of 9 Old 02-23-2010, 08:39 PM Thread Starter
Bunky1267
Diagram
Thanks I printed it and will check it out in the morning..
post #6 of 9 Old 02-23-2010, 08:42 PM
97B2500CCV
97B2500CCV's Avatar
Check fuse number 18 also. After looking more over the list 18 may be the one that is at fault.
post #7 of 9 Old 02-23-2010, 09:30 PM
alloro
Elder User
Quoted: 19 Post(s)
Not to beat a dead horse, but if the fuses are good the dimmer switch could still be broken.
alloro is offline
post #8 of 9 Old 02-23-2010, 09:48 PM
97B2500CCV
97B2500CCV's Avatar
Does the cabin lamps light up when the door is open? If not recheck the dimmer switch as Alloro said for if you gently turned it to the left you may have though that it was at its left stop and it may still be in the dimmer/dome light OFF detent. Clock wise turns off the dash lights and dome lamps.
post #9 of 9 Old 02-25-2010, 05:53 PM Thread Starter
Bunky1267
Fixed for now
Well thanks for the help guys. The 1997 fuse panel was different. But after checking the fuses I found a blown one and that fixed the problem.
Thanks again
    Any one have a fuse box diagram or labeling? Dome light fuse? Mystro 2G Dodge Durango General Talk 4 05-30-2009 06:30 PM
    Fuse Panel Diagram Dakota95 Dodge Dakota 1st Gen (87 -96) Forum 0 07-06-2005 07:39 PM
    I need a fuse block diagram dave_27 Mobile Audio & Electronics Talk 0 02-22-2005 02:14 PM
    need fuse diagram to the fuse block in the cab of a 96 dakota chrisryn Dodge Dakota 1st Gen (87 -96) Forum 2 02-16-2005 05:23 PM
    95 Fuse Diagram coyotestunt2 Dodge Dakota 1st Gen (87 -96) Forum 0 10-09-2004 08:07 PM
