Blown Head Gasket - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 34 Old 02-20-2010, 12:18 AM Thread Starter
oaviking06
Blown Head Gasket
Was passing a car, and and looked in rear view mirror, and all i saw was white smoke/ Steam. i drove for about 3miles and making sure it didnt get to hot till i saw a gas station. once i checked it out i saw i blew the lower radiator hose. what gets me is if it was low on coolant why didnt it ever overheat to warn me? replaced the hose and filled it back up and when i turned it on, it was blowing smoke and water out the exhaust, so i hope its just the head gaskets and nothing else like a cracked head
OSCAR ACOSTA
-2012 Ram 1500-
-5.7 HEMI-
-22" SRT Wheels--
oaviking06 is offline
post #2 of 34 Old 02-20-2010, 08:51 AM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
Did you check the oil to confirm that your head gasket was blown?? The cold weather is probably why you didnt overheat immediately. Luckily you have the 4.7L so you have more room to get your heads off and replace the gaskets. I highly recommend doing both sides. You don't want one to go out right after you fix the one thats messed up.
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #3 of 34 Old 02-20-2010, 09:10 AM
HEMI-PWRD
09 HEMI
HEMI-PWRD's Avatar
That sucks bro. I hope you get if fixed soon. Your truck looks great with the wheels and drop!
09 HEMI - CC SB
13.3 @100.6
Go to
for all your truck needs!!!
RIPPs Supercharger!, L&M CUSTOMS Transmission with Mag-Hytec trans pan, MGH/RIPPs tune, 2800-3000 Circle-D Stall Single Billet, 4.10 Gears, JBA Shorty headers with no CATS & custom Y-PIPE to Flowmaster SI/DO, Moe's 87mm TB, Diablo Intune, Moes pillard with boost and air/fuel gauges, 180 T-stat, Mopar V6 Efan, Denso 1 stage colder plugs, 3/5" drop, R/T hood, 2013 Sport wheels on Kuhmos staggered, Shaved grille-antenna-tailgate, HIDs, BT HEMI "T" shifter, and everything painted to match.
Next: Moe's Catch can, re-do tint, spray in bed-liner......
HEMI-PWRD is offline
post #4 of 34 Old 02-20-2010, 09:52 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
unfortunately, we have seen more than a few threads of this same nature with 4.7s
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #5 of 34 Old 02-20-2010, 10:12 AM
1badhemi07
Gold Member
ya i dont know they way its sounding ya i might be a ank error which a head gasket would be in place or its a crack head gasket same but also do both it save you in the long run
1badhemi07 is offline
post #6 of 34 Old 02-20-2010, 09:17 PM
dieseldoc1
dieseldoc1's Avatar
when low on coolant,steam will not operate the temp sender. it must be in liquid.
06 1500 megacab hemi 4x4 flowmaster 50 suv
95 1500 regcab 5.2 long bed
Megacab Club #13
over the years
79 d150 4x2 360 got new drove 21yrs on 3rd owner
78 w100 plymouth trail duster 440 full time 4x4
83 d150 ramcharger 318 4x2
92 d150 3.9
02 qc 1500 4.7 4x2
73 plymouth satellite 318
74 plymouth fury 2dr hardtop 360
92 new yorker
dieseldoc1 is offline
post #7 of 34 Old 02-22-2010, 04:09 PM Thread Starter
oaviking06
yeah, it sucks! lol took it to the shop they are gonna check the heads not just replace the gaskets. Weedahoe, You said youve seen threads like this before, about how much is this gonna set me back?? have any idea. there was not water in the oil.
OSCAR ACOSTA
-2012 Ram 1500-
-5.7 HEMI-
-22" SRT Wheels--
post #8 of 34 Old 02-22-2010, 04:22 PM
Big Boi
Big Boi's Avatar
My 3.7 as well... Took it to a "trusted" mechanic, and ended up with a new engine after it was all done. The mechanic screwed everything up in the old one.
BBK Shotrie's - Magnaflow 14" - Magnaflow "Y" - K&N 77-1561KP - 180° Tstat - 12" Chrome tips - Resonator Delete - 3865 - Train Horns - Hella's "Behind the Grill" - 6K HID's - Tinted Tails -Painted Heads - Lowered with Cut Coils
Big Boi is offline
post #9 of 34 Old 02-23-2010, 07:08 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
IDK about price but there are more than a few threads here from guys with 4.7s coming in an saying they were overheating and it was either blown head gaskets or cracked heads. Obviously, head gaskets would be cheaper. But either way you can do the work yourself minus the machining of the heads or magnafluxing them for cracks.
Next projects:
- Custom CAI
weedahoe is offline
post #10 of 34 Old 02-23-2010, 09:24 AM
Little Harry
Little Harry's Avatar
How many miles do you have on the truck? I have a 3.7L and am not looking forward to having this happen. I too have seen multiple threads of this occuring.
Character is who you are in the dark.
Little Harry is offline
post #11 of 34 Old 02-23-2010, 07:21 PM
Big Boi
Big Boi's Avatar
I have over 100k now, but this happened at like 60k.
Big Boi is offline
post #12 of 34 Old 02-23-2010, 07:40 PM
big guy
big guy's Avatar
Quoted: 12 Post(s)
I just knew it was a 4.7 when I saw the thread title. Just waiting my turn!
Good Luck on the repairs.
2003 Ram 1500 SLT, 4.7,4x4 L.B. 4.10 motive gears, auburn LSD, PML rear diff cover, 3715 super chip, airaid M.I.T. & E.A.A. dry air filter, flexalite electric fan B.M. 180 extreme with moe's fan shroud delete kit, jet 180* stat, hemi radiator (spectra CU 2813). JBA shorty headers, homebrew power wire, aeroforce interceptor scan gauge, sonnex line pressure booster.
big guy is offline
post #13 of 34 Old 02-23-2010, 08:29 PM
rye
rye's Avatar
If you ever suddenly see smoke out of the back of your truck, pull over, and turn it off.
I hope it's not damaged too bad....good luck!
DODGETALK.COM MODERATOR
5.9 2003 1500 4x4
Official Dodgetalk Facebook Page:
rye is offline
post #14 of 34 Old 02-23-2010, 08:43 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 245 Post(s)
I was told to replace both head gaskets and only the head gaskets would cost me $1000-bucks; to replace one head would cost me $2000-buck. I was told this info by a Dodge dealership. I'm sure you can get a better price by someone else. If you're around the Dallas Texas area I know someone you can talk to about this type of problem.
dmcelhannon is offline
post #15 of 34 Old 02-24-2010, 08:45 AM
GreatWhiteNorth
Here's a breakdown of what it cost me for parts only (all numbers in CDN$ which is pretty much par with US$)
$300 for gasket kit
$200 for new head bolts
$60 for new oil & filter
$30 for new coolant
The job itself took my Dad and I a whole weekend, but we were only able to work 6 hours both days.
There was no machining involved because the block had less than 30K miles on it and I put ported heads on at the time. Not sure what shop rates are there, but up here they're about $100 per hour, so I would expect someone who does this regularly to take 8 - 10 hours. They'll also probably charge you an AC drain/refill charge unless they're nice enough to just tie it out of the way. Almost 2 hours of that time was the two of us cleaning parts and surfaces because they would have been coated in an oil/coolant mixture.
'03 4.7 QCSB 4x4 5spd manual
Performance Mods: Flex-a-lite 180 e-fan, Magnaflow cat back kit, Powerwire, Yukon 4.56s, Ported Heads, SCT Tuned by HemiFever, 70MM TB from Stampede4.7, Magnaflow Y-pipe, Paxton Novi 2000 Super Charger, 206 Cams
Appearance Mods: T-Bar crank, Cooper Discoverer S/T 265/70/17, Debadged, Color matched handles and mirrors
GreatWhiteNorth is offline
post #16 of 34 Old 02-24-2010, 10:02 AM
LittleBull
So do you think that the 4.7 is somehow causing bad radiator hoses?
Or that the 4.7 more prone to head gasket failure than any other engine
when being driven 3-4 miles AFTER the driver noticed that he blew a
radiator hose?
When you drive your truck with no coolant, you're pretty much saying
I'd rather take a chance at having to replace the engine than walk...
It's a choice he made.
LittleBull
"02" 4.7 4x2 LWB Ram, HO cam set
4.56:1 gear set, Hellweg swaybar
Bilstein shocks, BF Goodrich all terrain tires
PML differential cover, PML transmission pan
Smittybilt pushbar w/ KC offroad lights, KC backup lights
Uniden cb radio, Xantrex power inverter
WeatherTech in channel visors, Painted calipers
Spray in bed liner, 2.5 in. front coil spacers
Westen Nerfbars, Bushwacker OEM fender flares
LittleBull is offline
post #17 of 34 Old 02-24-2010, 11:19 AM
Big Boi
Big Boi's Avatar
Down here a couple shops quoted me between $2500-$3750 to replace both gaskets and machine the heads.
Big Boi is offline
post #18 of 34 Old 02-24-2010, 11:35 AM
dmcelhannon
Admin - David Mack
Quoted: 245 Post(s)
My understanding about these cylinder head, you can't machine (plain) the 4.7L heads. If the head is warped, you're SOL; you have to replace the head. That's why I'm getting new heads instead of having mine rebuilt.
Is this yet other fact about the 4.7L heads that's BS or was I told the truth?
post #19 of 34 Old 02-24-2010, 11:46 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I guess it would all depend on how much material there is to remove. Also, if you shave the heads, how will you shave the intake to match them? Its plastic.
Next projects:
- Custom CAI
weedahoe is offline
post #20 of 34 Old 02-24-2010, 11:47 AM
Big Boi
Big Boi's Avatar
You guys have a point...
Big Boi is offline
    Blown Head Gasket? ccb_v2 2G Dodge RAM - General Talk 3 08-18-2008 02:19 PM
    Blown Head Gasket CRMRAM 3G Dodge RAM - General Talk 12 10-16-2006 11:06 PM
    Blown head gasket !!! frankhowe 2G Dodge RAM - General Talk 11 10-12-2006 09:30 PM
    blown head gasket or ? egrussell Dodge Caravan General Talk 6 03-25-2005 10:51 PM
