Fuel gauge not working - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 02-17-2010, 09:05 PM Thread Starter
RideHigh533
GETER DONE
RideHigh533's Avatar
I was woundering if any knows why my fuel gauge in my 02 ram 1500 is not working at all, it just stays on e all the time. Its just starting to get anoying. Thanks in adavance.
RideHigh533 is offline
post #2 of 4 Old 02-17-2010, 11:52 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 235 Post(s)
I would first try the ....
"Instrument Cluster Self Test"
The Self Test can be initiated manually by depressing and holding the Trip Reset button while turning the ignition on.
Observe the gauge in question while the Instrument Cluster performs the Self Test.
The gauges should position at the following calibrations points:
Speedometer MPH: 0, 20, 60, 90
Tachometer Gas: 0, 1000, 3000, 6000
Fuel: E, 1/4, 1/2, 3/4, F
Coolant: Cold, 1/4, 1/2, 3/4, HI
Volts: 6, 9, 12, 15, 17
.... if it fails the test, you could have a bad sending unit in the tank which is real bad news. The fuel gauge sending unit, fuel pump, and fuel filter are all one assembly. Check fuses, wires, and everything else you can think of because I believe the assembly is pretty costly.
dmcelhannon is offline
post #3 of 4 Old 02-17-2010, 11:55 PM
slims
slims
slims's Avatar
mine trys to stick when it gets around e. ill put 20 in it and the needle over a period of about 20 minutes will slowly move towards full
2004 ram 1500
2004 jeep liberty
2001 chevy 1500
1989 chevy s-10
Trucks & Guns Club Member #98
Don't TOUCH my Truck Club #3
slims is offline
post #4 of 4 Old 02-18-2010, 06:36 AM Thread Starter
RideHigh533
GETER DONE
I have tried the test and the fuel gauge worked but it stil says I have no fuel in the tank. And yes the fuel sending unit is 208 bucks for me which is alot for 1 piese.
    Speedometer/Odometer/Fuel Gauge not working jujuwagner 2G Dodge RAM - General Talk 2 04-05-2007 09:09 PM
    Fuel Gauge Not Working When On Half Tank TEWMINATOR 1973-1993 Dodge RamCharger 1 03-31-2007 12:18 AM
    fuel gauge not working properly ohiogary 2G Dodge Intrepid - General Talk 1 03-18-2006 08:42 PM
    Fuel Gauge Not Working ollhippieinsc Dodge Dakota 1st Gen (87 -96) Forum 4 12-24-2004 10:58 AM
    fuel gauge not working properly shark Bait 2G Dodge RAM - General Talk 4 03-04-2004 08:57 AM
