water in driver side floorboard - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 02-07-2010, 03:06 AM Thread Starter
IronHorse98
IronHorse98's Avatar
I have read many post about water in the passenger side floor, i know its either the heater core or the a/c drain. But when it rains, when im driving or parked, my driver side floor is soaked. What is the issue with this? Anyone else heard of this issue? I have yet to experience the passenger side drama, atleast i know what that entalls in repairs. Anyone?
Its a 98 CC 5.2 M5.
1998 2wd CC, 318, 6 inch lift, 33/12.50/15 Duratracs, Pro Comp 15x10 Bead Lock's, 5 speed, in bed tire carrier, all badges removed, pre-runner front tube bumper.
Future mods: Carb conversion, 408 stroker, 4 link rear suspension.
"If your too scared to carry your truck offroad, take your pansy ass and go buy a honda" - Robby Gordon..
IronHorse98 is offline
post #2 of 8 Old 02-07-2010, 09:26 AM
RAM MAN
Originating Member
RAM MAN's Avatar
I'd say if it only happens when its raining, your windshield may not be sealed properly
Good luck on your project.
RAM MAN is offline
post #3 of 8 Old 02-07-2010, 09:27 AM
RAM MAN
Originating Member
RAM MAN's Avatar
BTW - do you have a rear sliding glass window ?
RAM MAN is offline
post #4 of 8 Old 02-07-2010, 10:15 AM
TEAMFAST
01RC2WD4.75SPD
TEAMFAST's Avatar
run a hose over your truck and look for the leak. repair hole/crack. enjoy.
Unsafe at any speed
TEAMFAST is offline
post #5 of 8 Old 02-07-2010, 07:01 PM Thread Starter
IronHorse98
I do have a rear sliding window. Why? The seal mabey?
post #6 of 8 Old 02-08-2010, 06:41 PM
RAM MAN
Originating Member
RAM MAN's Avatar
yes
the reason I asked is - I remember a guy who had a 2nd Gen Ram, and he was having wet carpet problems, and I remember he found the problem was related to his rear window- so don't forget to check there as well
RAM MAN is offline
post #7 of 8 Old 03-02-2010, 11:49 PM
Sting32
I have a 66 mustang, this is the only car I have owned long enough I guess to learn this... But in almost all cars, the cowl vent is an area (below the winshield directly behind the hood) that can rust out and leak OR get plugged with twigs/dirt/leaves and crap... what you have is a cavern, that water can go into, then a dam around that so the air goes above it. if the dam is damaged, or cant drain water away then water can overflow into the cab, POSSIBLY... Surely they design it a little better in 97 and up... but Im sure it is possible...
so if you pump water into that area, there are 2 posibilites, one is that leaves a dirt and crap have plugged up the drains (that let water out yet let air into the cab). or there is a rust or seal problem.
and this is probably less likely than rear window, yet it is an easy check, after everything is dry, place your garden hose at back of hood, below windshield... if it dont leak, then maybe door seals (if it wasnt the rear window)...
Sting32 is offline
post #8 of 8 Old 03-03-2010, 11:18 PM
MONKYMAN
MONKYMAN's Avatar
Quoted: 9 Post(s)
Pray its not the heater core! I just did my friends heatercore with him.... WOW That was a chore! Almost have to drain the Ac lines You can just barely do it without. Took a good 3 days to do his! You have to take everything out of the inside! bare firewall! almost.
Next time it is wet taste if it is antifreeze
By the way... Heater core is on the drivers side of the ac box on the floor but it drains out the freshair flap onto the passenger side. But its more on the tranny hump then the passenger floor.
2000 Dakota R/t 5.9 Club Cab: SRT-4 Seats, K&N FIPK, Holley 52mm Throttle Body, Superchips 3715, 4.10 Gears, Viper Fan, 180* T-Stat, Hooker Shorty Headers, Flowmaster 50 Dumped, Lowered 2/5 with Nitro Drop Shocks, CalTracs, Boss 330's, Nitto 420s tires, Shaved Tailgate, Grant Kustoms Weld-in Rollpan.
Stereo:
Pioneer Premier DEH-P510UB, Pioneer Premier 6 3/4 components, Pioneer Premier 6x9 Premier 800x4 amp driving speakers, MTX Thunderform Box with 2 10" Shallow Premier subs.
MONKYMAN is offline
    Water on floorboard? Slap_my_momma 3G Dodge RAM - General Talk 12 05-01-2010 11:37 AM
    Water on floorboard - A/C or leak? 05DodgeDakota 3G Dodge Dakota - Interior/Exterior 23 12-27-2009 01:31 PM
    Water leak driver side sjensen9 2G Dodge Stratus - Interior/Exterior Talk 0 06-15-2009 09:27 AM
    Recall info for water leak on Driver side A pillar slayer 3G Dodge RAM - General Talk 1 04-21-2006 06:59 PM
    water leak in van (front driver side) HELP.. gcourage Dodge Caravan General Talk 1 09-25-2004 12:43 PM
