Body Module/ Please Look!
- Posted: 08-16-2004, 03:32 PM
Post #1
Pleas read the post 'Cloud car on Drugs,' and tell me if you think that the body module, the box right behind the interior fusebox, could be the culprit.
I took the inst. cluster out today, and now know why the Check engine light didn't come on, while all of the others did, the previous owner, or some idiot thought that when it lit up, it meant to remove the bulb! The cluster & all wires look great. All the wiring on the car, that I can see looks good too. Anyways, if this helps, I put a light back in, did the key boogie, & got 1 ficker-pause 5 flicks-pause-5 flicks. I ran this test twice, same story. Does anyone know what this is telling me? I'm in the mindset that one of these boxes, or computers is completely whack. Thanks to you if you read this! Ric Last edited by 1badredbird : 08-16-2004 at 05:40 PM. Reason: Mis-spelling |
| Sponsored Links |
Posted: 08-16-2004, 05:34 PM
Post #2
check again thats not a code. all codes for that car are 2 digits
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6. |
| Sponsored Links |
Posted: 08-16-2004, 05:42 PM
Post #3
The 55 means that is the end of the message or any codes
Ret.ArmySF Lead, Follow, or get the Hell Out of the Way! 1996 Dodge Ram SLT 1500 5.2L/Debadged (almost) COIN HOLDERS ASSOCIATION MEMBER #69 S.N.A.T.C.H. Spec. Ops. 2nd Lt! Exterior: Blue Xenon Head and Fog Lights - Euro Clear Corners with Blue Krypton Bulbs - Stainless Steel Toolbox - Mopar Molded Mud Flaps - Mopar Bed Liner - Grill and Bumper Stainless Mesh Inserts - Red Painted Brake Calipers - Gabriel Front and Rear Air Shocks - Removed Overload Spring (1 1/2" drop) -Lowering Shackles - Tailgate Handle Lock - Alteza Tail Lights - Rear Spoiler - Aluminum Gas Door - Aluminum 3rd Brake Light Cover - Rear Fender Stripes with Ram's Head Click HERE to view the complete signature... |
Posted: 08-16-2004, 06:18 PM
Post #4
Posted: 08-17-2004, 09:53 PM
Post #5
So what you are saying is that my car is really screwed up big time? Someone told me it was probably the body module, whatcha guys think? I'm thinking either that, or the power train module. I'm all ears! Thanks-'redbird
Posted: 08-22-2004, 07:20 PM
Post #6
Just wanted to tell ya'll that all is well with the Cirrus now. I took the batt for testing, it didn't drop below 11 volts. So I took it home, sanded the terminals & cable ends untill shiney lookin new. Poof, problem solved. That is so wierd that a bad ground (that should have been OK) would cause that kind of mayhem! I'm on Cloud 9 now! 'bird
Posted: 08-22-2004, 07:30 PM
Post #7
cool wouldn't have thought of that but congrats to getting it running again.
Posted: 08-22-2004, 07:34 PM
Post #8
Yea, disconnecting the negative is the way to reset your computer! Sometimes the simplest things take the longest to troubleshoot! Glad you got it working!
| Thread Tools | |
| Sponsored Links |
