Crate engine? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 25 Old 01-28-2010, 08:15 AM Thread Starter
DodgeRam5.9
11B! Killem all.
DodgeRam5.9's Avatar
Question Crate engine?
He guys I have looked around and have had a hard time finding cheap create engines.Buy cheap I mean my price rang is between $4-5,000. I need a engine thats somewhere between 4-500HP. If you guys know if any websites that would really help.
Side note. How hard would it be to put a chevy engine in my 98 1500 dodge ram? I have found tons of cheap chevy engines.
1990 Chevy RS camaro 305 TBI 700R4 tranny (Sold)
1998 Dodge Ram 1500 4X4 5.9L Gas (Sold)
1989 Dodge Dakota 3.9L 5 Speed (Sold)
LINK:
DodgeRam5.9 is offline
post #2 of 25 Old 01-28-2010, 08:27 AM
madmikeismad
R.I.P Big Blue
madmikeismad's Avatar
Quoted: 109 Post(s)
I'm figuring they are all 350's too lol, the 350 is like the chevy slut, its been in everything. The only sites I know of for crates, are jegs, summit, edelbrock?, sites like that.
Mike Hill
Purple People Eater - 98 12v - Maybe 800whp on old block:
The Race Truck
01 Ram 1500 Sport 4x4 5.9 (RIP Big Blue
madmikeismad is offline
post #3 of 25 Old 01-28-2010, 08:59 AM Thread Starter
DodgeRam5.9
11B! Killem all.
yeah I have looked there.No luck. all chevy. lol I want me a hemi! lol But I might just bore it out to a 426.
LINK:
post #4 of 25 Old 01-28-2010, 01:51 PM
itate
No Agenda Producer
itate's Avatar
Summit has 408 stroker crate motors...
http://www.summitracing.com/search/M...word=blueprint
98 Dodge Ram SS/T Black-Silver Stripes - 5.9L, Hughes Plenum Pan & Gasket, Open element air cleaner,
Harland Sharp 1.7 rockers, shorty headers, 3.91 gears, poor man's throttle body mod, and Hellas behind the grill.
98 Dodge Neon Sport DOHC (262,000 miles)
68 Plymouth Barracuda - May 2009 VOTM
62 Chrysler Newport
itate is offline
post #5 of 25 Old 01-28-2010, 02:01 PM
ppp1182
ppp1182's Avatar
People have put sbc 350 in the Ram, but it requires a bit of work. Probably won't get you in below your mark unless you do a lot of work yourself.
There are lots of companies out there offering stroker magnum motors. I would go with a high torque stroker in the 402-408 ci range (depends on how your block cleans up). That is doable with your budget, and should net 375-425 hp depending on heads and cam running pump gas.
2000 Ram 1500 SPORT 4x4 5.9L (360) in BLACK (it looks bigger)
BFG All-Terrain T/A KO 285/70r17 from Michigan 4 x 4
Port-matched MP1 Intake Manifold from The Fastman
17x8 Off-Road Edition rims (Thanks Tazz411)
Gibson swept-side stainless single exhaust
SCT custom tuned by Hemifever
Gibson ceramic coated headers
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
408 stroker with stage 3 Eddy heads
4.56 gears
ppp1182 is offline
post #6 of 25 Old 01-28-2010, 02:12 PM Thread Starter
DodgeRam5.9
11B! Killem all.
What do you think about boring it out to a 426>?
LINK:
post #7 of 25 Old 01-28-2010, 02:18 PM
ppp1182
ppp1182's Avatar
I have no personal experience with the Hughes/KRC 360/426 stroker, but it is NOT a proven design and it has rod ratios that are too small and everything that would indicate high cylinder wall loads. It may be ok for a race engine, but everyone I talked to recommended against it for daily driver use. Besides, you could build a big block for that kind of money and have all the spots milled for the sensors. Or even go with a 340 replacement block for 416ci. Or an R3 siamese block.
IMO, stick with a 360/408 if you are using a 360 magnum block.
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
4.56 gears
ppp1182 is offline
post #8 of 25 Old 01-28-2010, 02:21 PM Thread Starter
DodgeRam5.9
11B! Killem all.
Well I am looking at this engine:
http://www.summitracing.com/parts/MLL-BPC4081CT/
It seems like it would also be good for a daily driver too. But if i decided to get a stroke kit for a daily drive the 408 seems like it would be better?
LINK:
post #9 of 25 Old 01-28-2010, 08:05 PM
Woodstock
Woodstock
Woodstock's Avatar
Those engines are LA based blocks, not Magnum based blocks. I would call and see if they are available in Magnum. It would save a LOT of hassels.
Make CHRYSLER
Engine Type V8
Engine Size 5.9L/360
Engine Family Mopar small block LA
Fuel Delivery Carburetor
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr
SCT by hemifever, 4.10 Gears, Stainless Steel Headers
HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials
1985 350 Custom Dually 360ci 4barrel 727
1990 Jeep YJ 4.2 waiting for 5.9 swap
Woodstock is offline
post #10 of 25 Old 01-28-2010, 09:54 PM Thread Starter
DodgeRam5.9
11B! Killem all.
Yeah. This is all just cool ideas right now. I'm in the marines and will be gone for quite some time. So i have a lot of time to save money.
LINK:
post #11 of 25 Old 01-28-2010, 09:54 PM Thread Starter
DodgeRam5.9
11B! Killem all.
yep
LINK:
post #12 of 25 Old 01-29-2010, 12:16 AM
rumblebee2
rumblebee2 is offline
post #13 of 25 Old 01-29-2010, 07:35 AM Thread Starter
DodgeRam5.9
11B! Killem all.
Thanks
LINK:
post #14 of 25 Old 01-30-2010, 06:30 PM
Bluedually4x4
Bluedually4x4's Avatar
Stick with a Dodge engine, and fuel injection. Much easier to keep it registered in some states if it has the same make of engine. Since you are in the marines and I know duty stations can change.
You could punch out the stock engine and add some better heads, intake, headers. And get a fair amount of power out of it. Heck even supercharge it and forget about naturally aspirated.
1998 1 ton dually 4x4. 12valve Cummins 5 speed manual. TST # 10 fuel plate DPI 75 hp injectors ATS 3 piece exhaust manifold BHAF intake 5" Turbo back exhaust dual 5" stacks South Bend 13.5 clutch 2001 flip out towing mirrors 16 degrees of timing and 3000GS BD Super B turbo
Dynoed at 452 horse power
And over 900 foot pounds
Bluedually4x4 is offline
post #15 of 25 Old 01-31-2010, 12:15 PM Thread Starter
DodgeRam5.9
11B! Killem all.
Yeah superchargers are sick!
LINK:
post #16 of 25 Old 01-31-2010, 11:24 PM
littleredwagon
littleredwagon's Avatar
nowadays the technology for turbos has come a long ways, the most power and daily driveability youre going to achieve from forced induction is going to be turbo. if i could afford it id do twin turbo in a heart beat. get some concave pistons to lower the compression a tiny bit, flow your heads and get the biggest headers you can find, set up a really good fuel management system, and pump 18psi into it. that oughta blow yer hair back.
if you cant dodge it, well then its probably going to run into you at some point.
littleredwagon is offline
post #17 of 25 Old 02-01-2010, 07:34 AM Thread Starter
DodgeRam5.9
11B! Killem all.
yeah but superchargers blow up faster and for as something a powerful as a V8 I think super is the way to go where if its a 4 banger or a V6 go with turbo.
LINK:
post #18 of 25 Old 02-01-2010, 09:50 AM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
Here is the thread I started on the 440 crate motors, there is a local shop here in SC that can get them, the owner chimed in on this thread on page two.
http://www.dodgetalk.com/forums/showthread.php?t=276273
My name is Al from Summerville, SC and I am a
Me: '14 Ram 1500 EcoDiesel
'01 Ram 1500 5.2L Sport
Rhino Liner, Pioneer sound, new ball joints
I am not just a member I am the President
Wife: '05 Durango 4.7L
OleTomCat is offline
post #19 of 25 Old 02-01-2010, 06:35 PM
Bluedually4x4
The biggest difference between a supercharger and a turbocharger is where in the power band you gain the power. Their power bands do over lap a little but generally a engine driven set up will give you power right of idle to mid rpm and the exhaust driven set up will give power from mid rpm and up.
post #20 of 25 Old 02-01-2010, 06:55 PM
madmikeismad
R.I.P Big Blue
Quoted: 109 Post(s)
Or, with a turbo, you can just do boosted launches, if your trans is up for it....
Is this charger gonna be for just DD street use, or racing/having fun?
Mike Hill
The Race Truck
    New/Crate Engine ProjectPowerRam Dodge Ram Truck 1st Gen (88 - 93) Forum 1 01-08-2010 01:42 PM
    Crate engine? CatRam 3G Dodge Ram Performance Talk 10 04-14-2007 08:43 PM
    crate engine Go-off-road 2G Dodge Ram Performance Talk 33 02-20-2005 10:48 AM
    so now that we have 5.7 crate engine xxumattuxx 3G Dodge Ram Performance Talk 9 01-15-2005 07:27 PM
    crate engine low ss/t 2G Dodge RAM - General Talk 8 10-12-2003 04:50 PM
