Normal oil pressure and temperature - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 01-22-2010, 08:29 AM Thread Starter
myoung84
Administrator
myoung84's Avatar
Quoted: 19 Post(s)
What is the normal oil pressure and temperature reading on a stock Hemi running dino oil? I just want to compare the numbers to my truck since switching to Amsoil 0w-20 and Amsoil filter. I run about 56-60 PSI in a cold start high idle, about 60-62 PSI cold driving, and about 56 PSI when warmed up and driving. Oil temp this morning after 15 minutes on the highway was about 175 Deg.
Retro Shop Custom FXR Projectors | Diablo inTune | Vararam Intake | Moe's 87mm TB | BT Oil Catch Can
Toyo A/T II Tires | Bilstein 5100 Front Shocks @ 2.1" | Bilstein 5100 Rear Shocks | Movotech UCA's
Bora 1.25" Spacers | AirLift Air Bags | Bestop PowerBoards | Undercover LUX Bed Cover | BedRug
Magnaflow Exhaust | Volant Intake | Diablo inTune w/Hemifever Tuning | BT Oil Catch Can
myoung84 is offline
post #2 of 7 Old 01-26-2010, 08:53 AM Thread Starter
myoung84
Administrator
myoung84's Avatar
Quoted: 19 Post(s)
Anyone?
myoung84 is offline
post #3 of 7 Old 01-26-2010, 03:27 PM
Lead Head
In general if its over 25-30 PSI warm driving its okay. Most manufactures just have an oil pressure switch - on/off. Sometimes they are even connected to the oil pressure gauge, and the gauge is just calibrated to go to the middle range. These pressure switches are sometimes set as low as 7 PSI before throwing a warning.
Are you using your dash gauge to tell pressure? If you are, its essentially worthless. Dodge (atleast in the Cummins, and I wouldn't see why they wouldn't with the Hemi and other engines either) just use an oil pressure switch to tell the dash/pcm whether there is at least 7-10 of oil pressure. This will bring the gauge automatically into the safe 40-70 PSI zone, regardless of actual pressure. The dash board computer will actually move the oil pressure gauge based on engine RPM. I know GM also does the computer-moving-gauge trick, and I know that Ford uses pressure switches as well, but I'm not sure if their gauges are programmed to move either.
The only way to really tell with these new vehicles is to install a mechanical pressure gauge.
Lead Head is offline
post #4 of 7 Old 01-26-2010, 03:45 PM
SilsHemi
Dodge Fanatic!
Running the same oil and EaO filter. Great stuff.
Sil
SilsHemi is offline
post #5 of 7 Old 01-26-2010, 04:03 PM Thread Starter
myoung84
Administrator
myoung84's Avatar
Quoted: 19 Post(s)
Sil
I run the 0W-20 in both my new truck and the wife's Mustang. I also ran Amsoil in my last 2 Dodge's and will probably switch my boat over to Amsoil this spring.
I am using the EVIC on the truck to read the actual pressure and temp. As far as I know, it's accurate.
myoung84 is offline
post #6 of 7 Old 02-01-2010, 11:27 AM
Marchboom
Marchboom's Avatar
59 lbs on start up (above 45 degrees - OAT). At 203 degrees (normal engine temp), it reads 49 lbs at driving speed. Goes down to about 15 lbs at idle. Using Quaker State 5w-20.
John
2009 Dodge Ram 1500, 4X4, Crew Cab, Hemi, 3.55, Bright Silver.
Marchboom is offline
post #7 of 7 Old 02-01-2010, 07:53 PM
oldpianos
oldpianos's Avatar
Running Pennzoil Platinum 5w-20, and on highway speeds the oil and coolant are both at 194 degrees, pressure is ~55psi. It drops to ~26psi at idle.
2009 1500 Hemi R/T Inferno Red
4.10 LSD, Alpine Sound System, Floor Console Shifter, Volant CAI, HID fogs and highs, Bullydog HEMI.
oldpianos is offline
    whats normal boost pressure??? zuma6 Dodge Neon SRT-4 Talk 3 05-25-2008 03:27 PM
    Firestone Air Bag lift under normal pressure H2OSports 3G Dodge RAM - General Talk 5 11-17-2007 03:13 PM
    Oil Pressure 100PSI normal? Daking 3G Dodge Ram Performance Talk 2 03-02-2007 07:36 AM
    Normal temperature gauge reading? Jumper 3G Dodge RAM - Drivetrain Talk 3 04-18-2006 11:04 PM
    31x10.5x15 Normal Air Pressure??? mfitter555 2G Dodge Dakota - Tire/Wheel/Susp Talk 17 09-24-2005 01:57 PM
