No forward gears - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 35 Old 01-18-2010, 06:06 PM Thread Starter
Motorpsycho
No forward gears
Hey y'all. As the old saying goes, "when it rains, it pours". Think my transmission in my '94 1500 5.2 4x4 just kicked the bucket. I've only had the truck about a month, so don't know much about it. On my way home today after about a 20 min. drive my automatic trans started making a whirring noise that steadily got worse until when driving down my streets (many stop signs) the truck started free revving (RPM's but no motion) and wouldn't drive. It still has reverse, but none of the forward gears work. Please help!!!
Motorpsycho is offline
post #2 of 35 Old 01-19-2010, 09:26 AM
tactransman
Transmission Man!
tactransman's Avatar
It needs an overhaul. Something happen to the forward clutches. Welcome to Dodge Talk!!!
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #3 of 35 Old 01-19-2010, 11:36 AM Thread Starter
Motorpsycho
I've been searching the net for a master rebuild kit-think that's what I need? Do you know of any good parts suppliers who will carry it? Will I also need a bunch of specialty tools? Thanks
post #4 of 35 Old 01-19-2010, 12:01 PM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
Welcome to Dodge Talk, fill in your signature......
Terry, the guy in post #2 is the Slushbox expert on this site, take his advice, it is sound......
My name is Al from Summerville, SC and I am a
Me: '14 Ram 1500 EcoDiesel
'01 Ram 1500 5.2L Sport
Rhino Liner, Pioneer sound, new ball joints
I am not just a member I am the President
Wife: '05 Durango 4.7L
OleTomCat is offline
post #5 of 35 Old 01-19-2010, 12:47 PM Thread Starter
Motorpsycho
Not to sound like a moron, but I'm new here and don't know how to "fill in a signature". ??? Thanks! -Judd
post #6 of 35 Old 01-19-2010, 12:52 PM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
Click on Control panel link up top, then you will see 'edit signature' on the right side you can fill it in there, add avatar photos etc....
post #7 of 35 Old 01-19-2010, 03:34 PM Thread Starter
Motorpsycho
Thanks Al!
Judd from Michigan-'94 RAM 1500 5.2 4x4 Auto
post #8 of 35 Old 01-19-2010, 11:30 PM Thread Starter
Motorpsycho
Spoke with a mechanic friend of mine-he suggested the whirring noise may be a toasted sun gear(see original post). Are there some things I can do to test possible causes BEFORE I pull the trans out? Band adjustments? I'm new to auto trannies so any input is greatly appreciated!
post #9 of 35 Old 01-20-2010, 08:41 AM
BigGreenV10
Big Green
BigGreenV10's Avatar
Needs rebuilt mine just did that had reverse but no forward the clutches had seized together my advised have a reputable shop do the work that gives a warenty so if not done right they have to fix. I speak from experience as the idiots doing my trans has had it back 3 times and had to fix for free as was under warranty.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #10 of 35 Old 01-20-2010, 01:09 PM Thread Starter
Motorpsycho
Elliot, how much did it total out to? I've already sunk some major $$$ into this thing and am not sure abaout putting much more money into it. I like the truck despite what's gone wrong, but am thinking about cutting my losses.
Cheers
post #11 of 35 Old 01-20-2010, 01:42 PM
BigGreenV10
Big Green
Well like I said mine had no forward gears and acted like it was in neutral when you put in gear but you could tell it was in gear just no forward movement. It went backwards just fine though. I have a 47RE and had it built heavy duty for towing cost 1600.00 I have scene rebuilt ones with warranty on e-bay for 1000.00
post #12 of 35 Old 01-20-2010, 02:12 PM
key99
Quoted: 312 Post(s)
X2. You didn't mention what fluid level, smell, condition was like.
99 1500 SLT QCSB 4x4 5.2 227k mi; SUN vac ga, tow hooks ... umpteenth 46re, LONG 28K lb tr cooler, HAYDEN temp ga ... 3.55 c/w broken clip, 255/70 MICH M+S ... RED HEAD, DSS, MOOG trac n adj BJ; AMS in motor n diffs; HUSKY flr mats ... New shocks, drums, EXTREME rotors, bat; rebuilt mas cyl, alt ... Recent windshield, rad, rr springs, frt axle joints n seals ... Hand vac pump to control recirc door
97 1500 SLT CCSB 4x4 5.2 auto 3.55 lsd, factory tr cooler, HD fan clutch; 140k mi
--Both have spray in box liners; need PS coolers, htr cores and better water pumps for htr/winter use
key99 is offline
post #13 of 35 Old 01-20-2010, 04:04 PM Thread Starter
Motorpsycho
Fluid looked okay, even too good, like it was just changed to cover something up. Smelled fine too-not burned, but the level was actually high on the dipstick, and I made sure to run it through all gear selections and check in neutral. I personally think the a*swipe I bought it from put trans medic or something in there to cover up an issue and that's why the level is high, but the world will never know now...
post #14 of 35 Old 01-20-2010, 04:07 PM
BigGreenV10
Big Green
could have it happens allot my trans went out 1 day after I bought it and transtracman is the residing trans expert on here
post #15 of 35 Old 01-20-2010, 04:44 PM
key99
Quoted: 312 Post(s)
How much too high, and was trans cold, warm, or hot when checked? Should always mention important stuff like that to terry.
key99 is offline
post #16 of 35 Old 01-20-2010, 04:57 PM Thread Starter
Motorpsycho
Nothing like dishonest sellers. Despite all this I really do like the truck, but at this point, I don't know whether I'm keeping it or not-I have it up for sale and I'm going to see what offers I get. If someone offers enough cash, I'm offin it. And hopefully, better luck next time.
post #17 of 35 Old 01-20-2010, 05:51 PM
B-300
4 Wheel Power Disc Brakes
A press, good external circlip pliers, T-25 torx driver is about all you need in the way of special tools. Feeler gauges and hand tools are aso needed.
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #18 of 35 Old 01-20-2010, 06:27 PM
RamThis
RamThis's Avatar
Quoted: 2 Post(s)
Terry can set you up or Wayne at APS Precision can also set you up. Another good guy in Dodge transmissions is Martin Saine though I have not dealt with him personally, I hear nothing but good about him.
You've definitely got a fried transmission, will require a rebuild. Mine went but it had no reverse, though I had forward gears lol. Mine was a band/drum/servo that failed. I bought a Level10 rebuild kit and a few extra parts that the kit didnt include. I already had a trans-go shift kit and Long LPD 28000 GVW cooler on it.
2000 Dodge Ram 1500 Single Cab, 5.9 Auto, 4.10's, Auburn LSD, Edelbrock headers, 2.5" true duals with crossover, MSD Superconductors, APS Plenum Kit, Level10 Trans kit, Trans-Go shift kit, 2-4 BellTech Drop, SS/T rims, Toyo Proxes ST 285-60-17's, Sir Michaels Roll Pan and tailgate handle relocator, Keystone bumper cover with light openings, PIAA fogs, painted grille shell, painted Street Scene Speed Grille Inserts, SCT XCAL-2, Alpine head unit, Infinity Components front, Infinity Coaxials back, Infinity 500W 4 channel amp, Infinity Basslink, new dash, steering wheel, and guage bezel.
1996 Dodge Ram 1500 Club Cab, 5.9 Auto, 4.10's, Detroit Locker, Race Truck Trends Nascar Bumper, Painted SS/T Stripes, Alpine HU, Alpine Sound Field Processor, MTX Thunderform. 5.9L bored .030 over, Sealed Power coated pistons, balanced and polished crank, Comp 210 Cam, MP Timing Chain tensioner, Melling HV oil pump, 1.92 oversized valves and mild porting, Pacesetter Longtube Headers, FMS 24lb Injectors, Level10 Transmission kit, Trans-Go shift kit, 5 gear OD Planetary. Way more to come.
RamThis is offline
post #19 of 35 Old 01-20-2010, 11:45 PM Thread Starter
Motorpsycho
Ok. I'm really on the fence with it right now, but I'd still like to know where to get said rebuild kits and other misc. parts, so any input is greatly appreciated. Thanks!
post #20 of 35 Old 01-21-2010, 12:05 AM
B-300
Here is a lengthy thread to get aquainted with what you would be up against.
www.dodgetalk.com/forums/showthread.php?t=161544
B-300
B-300 is offline
    Shift from Reverse to Drive results in "instant grab" and lurch forward? Tranny/Gears trexmgd 3G Dodge RAM - Drivetrain Talk 13 10-06-2009 11:05 AM
    No Forward harper 1G Dodge Durango - Drivetrain Talk 3 12-30-2006 11:03 AM
    No reverse, drives forward in drive, drives forward in neutral. MqtMatt 2G Dodge RAM - Drivetrain Talk 5 09-19-2005 12:35 AM
    Dodge Ram 97, No forward gears, code P0740 smurrell 2G Dodge RAM - Drivetrain Talk 4 07-16-2005 05:18 PM
    Looking forward to being here FVRam DodgeTalk New Member Welcome 3 09-13-2003 11:03 PM
