Check ball location. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 01-17-2010, 02:57 PM Thread Starter
Ram lovr
Driven to perfection
Ram lovr's Avatar
This is the trans line that goes into the botton of the radiator. I stuck a screwdriver in the brass fitting and there seams to be a one way valve with a spring behind it. Is that the check ball I hear everyone talking about? And if so what is it's perpose?
98 Ram 1500 4x4 Quad Cab Sport, 5.9L,
Rancho 3" lift, 285/75/16 Hankook Dynapro MT's on stock rims
Windecker Steering Stabilizer
Flowmaster Exhaust
Lund Sun visor
Sony Head Unit,MTX Sub Box, MTX RT 2100X Amp,Stock Infinity speakers
KC 6" Slimlites
Rebuilt Trans w-aftermarket cooler
Pilot Fog Lights
Black Truck Member # 164
Cracked Dash Member #31
Ram lovr is offline
post #2 of 13 Old 01-17-2010, 04:05 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
STANDARD PROCEDURE - TORQUE
CONVERTER DRAINBACK VALVE
The converter drainback check valve is located in
the cooler outlet (pressure) line near the radiator
tank. The valve prevents fluid drainback when the
vehicle is parked for lengthy periods. The valve check
ball is spring loaded and has an opening pressure of
approximately 2 psi.
The valve is serviced as an assembly; it is not
repairable. Do not clean the valve if restricted, or
contaminated by sludge, or debris. If the valve fails,
or if a transmission malfunction occurs that generates
significant amounts of sludge and/or clutch particles
and metal shavings, the valve must be
replaced.
The valve must be removed whenever the cooler
and lines are reverse flushed. The valve can be flow
tested when necessary. The procedure is exactly the
same as for flow testing a cooler.
If the valve is restricted, installed backwards, or in
the wrong line, it will cause an overheating condition
and possible transmission failure.
CAUTION: The drainback valve is a one-way flow
device. It must be properly oriented in terms of flow
direction for the cooler to function properly. The
valve must be installed in the pressure line. Otherwise
flow will be blocked and would cause an overheating
condition and eventual transmission failure.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 13 Old 01-17-2010, 08:22 PM Thread Starter
Ram lovr
Ram lovr's Avatar
That told me absolutely nothing! Every one on this site is saying to remove it. Are they wrong?So I guess since I have nothing wrong with the valve. Sticking or such that I;m ok. The reason I ask is because I was having a problem with the OD shutting off at speeds over 65. But now that stopped happening?I have had people tell me'
Flowmaster Exhaust
Lund Sun visor
KC 6" Slimlites
Pilot Fog Lights
Ram lovr is offline
post #4 of 13 Old 01-17-2010, 09:08 PM
Lee Peterson
Lee Peterson's Avatar
Quoted: 4 Post(s)
Most people remove them becuase they can stick causing the tranny to overheat. If your tranny is overheating it will drop out of OD. Is your Torque converter locking up in overdrive?
2002 Dodge Ram 1500 4x4.
360 Magnum
Hughes FI Air Gap
52mm BBK TB
210/220 .512I.512E 110 LSA cam
MSD 6A , Blaster 2 Coil
Spintech muffler
SCT tuned by FlyinRyan
Trucks & Guns Club Member #88
Lee Peterson is offline
post #5 of 13 Old 01-17-2010, 09:48 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
Not sure how that did not tell you anything. you asked what it's purpose was and i explained what it does. As for removing it, you can remove it. But from what i gather you will not hold the pressure in your torque converter when the truck sits for a while.
Justin
post #6 of 13 Old 01-17-2010, 11:51 PM
B-300
4 Wheel Power Disc Brakes
The reason behind removal is the seat the ball seals on is plastic and can break into pieces and restrict fluid flow which lubricates the high load areas in the transmission.
If bypassed, start your truck in neutral to start fluid flow thru the transmission if it has sit for a day or more. (Fluid doesn't flow in park unless you have a shift kit installed.)
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #7 of 13 Old 01-18-2010, 04:17 AM
key99
Quoted: 312 Post(s)
[QUOTED FROM POST #2]. The converter drainback check valve is located in the cooler outlet (pressure) line near the radiator
tank. [unquote]. .... This is INCORRECT. It should read TRANS OUTLET or COOLER INLET.
Ram Lovr. If you dont mind, STARTING, AND, "IDLING IN NUETRAL" while conv is refilling, getting rid of check valve eliminates plugging/failing/sticking issues that can RESTRICT FLOW. Your choice.
[QUOTE] by Lee Peterson. If your tranny is overheating it will drop out of OD. Is your Torque converter locking up in overdrive? [UNQUOTE].
X2. Does it remain locked up? Is it slipping?
99 1500 SLT QCSB 4x4 5.2 227k mi; SUN vac ga, tow hooks ... umpteenth 46re, LONG 28K lb tr cooler, HAYDEN temp ga ... 3.55 c/w broken clip, 255/70 MICH M+S ... RED HEAD, DSS, MOOG trac n adj BJ; AMS in motor n diffs; HUSKY flr mats ... New shocks, drums, EXTREME rotors, bat; rebuilt mas cyl, alt ... Recent windshield, rad, rr springs, frt axle joints n seals ... Hand vac pump to control recirc door
97 1500 SLT CCSB 4x4 5.2 auto 3.55 lsd, factory tr cooler, HD fan clutch; 140k mi
--Both have spray in box liners; need PS coolers, htr cores and better water pumps for htr/winter use
key99 is offline
post #8 of 13 Old 01-18-2010, 05:56 AM Thread Starter
Ram lovr
Ram lovr's Avatar
What my trans has been doing is dropping out of OD But only when the truck has been driven at say 65-70mph for some 30-40 miles.It's not slipping no trans light just drops out of OD. Sometimes not always.
Flowmaster Exhaust
Lund Sun visor
KC 6" Slimlites
Pilot Fog Lights
Ram lovr is offline
post #9 of 13 Old 01-18-2010, 02:15 PM
key99
Quoted: 312 Post(s)
. Sounds like a typical TCC issue thats causing trans overheating. When its supposed to, it should; LOCK, REMAIN LOCKED, AND NOT SLIP. Count your shifts, and watch your tach. In 99, only trucks equipped with HD TRANS OIL COOLING i.e. snow plow, came with a trans temp light.
key99 is offline
post #10 of 13 Old 01-18-2010, 04:14 PM
tactransman
Transmission Man!
tactransman's Avatar
FYI, I have NEVER seen a a cooler line check ball stick shut. You need to remove the check ball to BACK FLUSH the transmission cooler in the radiator. You can reinstall it after the back flush procedure and you would probably be fine. You can leave it out and you will be fine.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #11 of 13 Old 01-24-2010, 01:10 PM
MosersRam
Mine is gone, and even though my truck sits for weeks at a time I haven't had any hesitation at start up and don't see any difference with it gone. I don't idle in neutral before I pull out. I took it out because I was under the impression that the ball itself was known to melt or disintegrate putting debris into the cooling lines and overheating the trans. I cut the hose just behind the valve, shoved the flare up into the hose an inch or so and put a hose clamp on it.
1997 Ram 1500, 5.2L, auto, 2wd, 170K
Towing package plus second trans cooler, trans temp gauge
Felpro plenum gasket repair
Coming soon JR shift kit
Pulling a 20 foot Forester pontoon boat all around the Raystown Country
MosersRam is offline
post #12 of 13 Old 01-24-2010, 01:24 PM Thread Starter
Ram lovr
Ram lovr's Avatar
OK Trans stopped dropping out of O/D. Now what?
Flowmaster Exhaust
Lund Sun visor
KC 6" Slimlites
Pilot Fog Lights
Ram lovr is offline
post #13 of 13 Old 01-24-2010, 03:16 PM
key99
Quoted: 312 Post(s)
Good news. But trans may still be getting too warm, try a temp gun on lines and pan. OD drops out about 270ish*F.
key99 is offline
    Check Engine reader plug location? Vintage IRA 2G Dodge RAM - General Talk 4 11-05-2008 06:45 PM
    check ball strokerjoe 2G Dodge RAM - Drivetrain Talk 11 07-11-2007 03:28 PM
    tranny check ball/valve wolf hybrid 2G Dodge RAM - Drivetrain Talk 8 04-01-2005 04:49 PM
    how do you check the ball Joints? StressboyD 1G Dodge Durango General Talk 10 11-03-2004 02:13 AM
    Has anyone heard of the check ball in your tranny line? limekyle19 2G Dodge RAM - Drivetrain Talk 7 09-22-2004 09:07 AM
