v10 crank position sensor - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 01-09-2010, 05:32 PM Thread Starter
vaquerorngr
can anybody tell me how to get the crank position sensor out of the side of a v10 block, please?
vaquerorngr is offline
post #2 of 6 Old 01-09-2010, 10:09 PM
Speed Dragon
Aka Force Fed Mopar
Speed Dragon's Avatar
Probably takes a bit of twisting, maybe some prying if you can get a screwdriver or something in there. They usually have a little o-ring on them that sometimes gets hard and doesn't like to slide well. They also get oil varnish build up on them that has to basically scrape off on it's way back out through the block. Be careful not to break the head off the sensor though, or you will really have fun getting it out
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Speed Dragon is offline
post #3 of 6 Old 01-09-2010, 11:39 PM Thread Starter
vaquerorngr
ok, I guess I just have to keep messing with it.
post #4 of 6 Old 01-10-2010, 01:13 PM Thread Starter
vaquerorngr
It's like 6 degrees here and the truck is sitting in snow. I have worked and worked on it until my fingers can't take the cold anymore. Maybe the cold has hardened the o ring to much right now and I have to wait until it warms up a little.
post #5 of 6 Old 01-10-2010, 06:56 PM
Speed Dragon
Aka Force Fed Mopar
Can you get a pic of the sensor and post it? Might help us give better ideas.
Rob M.
post #6 of 6 Old 01-13-2010, 05:15 PM Thread Starter
vaquerorngr
well I waited until today when it warmed up I plugged in my block heater in and the sensor pulled right out. But, it wasn't the problem the truck still cranks but won't start.
    Crank position sensor Miami_Son 2G Dodge Ram Performance Talk 3 07-23-2009 03:51 AM
    Crank Position sensor/cam sensor MONKYMAN 2G Dodge Dakota General Talk 0 05-27-2009 02:31 PM
    Where is the crank position sensor on a 97 colty045 2G Dodge Dakota General Talk 3 07-30-2006 09:15 AM
    Crank Position Sensor neon1234 Dodge Neon - General Talk 2 02-07-2006 07:56 PM
    You may not post new threads
    You may not post replies
