How to bleed power steering in '01 GC - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 01-07-2010, 08:35 PM Thread Starter
jeepme79
I had to change the cooler hose in the power steering tonight. What is the propper way to bleed the system?
2003 2500 CTD QC 4x4 6-speed
- Bully Dog Crazy Larry
- 295/70r17 Nitto's
- 380,000 on the clock
jeepme79 is offline
post #2 of 2 Old 01-08-2010, 06:48 AM
mfahey
Quoted: 1 Post(s)
From Alldata:
Read the fluid level through the side of the power steering fluid reservoir. The fluid level should indicate "COLD RANGE" when the fluid is at a temperature of approximately 21°C to 27°C (70°F to 80°F) .
Wipe the filler cap and area clean, then remove the cap.
Fill the pump fluid reservoir to the proper level and let the fluid settle for at least two 2 minutes.
Start the engine and let run for a few seconds, then turn the engine off.
Add fluid if necessary. Repeat the above steps, until the fluid level remains constant after running the engine.
Raise the front wheels off the ground.
Start the engine.
Slowly turn the steering wheel right and left, lightly contacting the wheel stops.
Add power steering fluid if necessary.
Lower the vehicle, then turn the steering wheel slowly from lock to lock.
Stop the engine. Check the fluid level and refill as required.
If the fluid is extremely foamy, allow the vehicle to stabilize a few minutes, then repeat the above procedure.
Also, one of the cooler hoses let go on our 2001. Had it replaced in the dead of winter, only to have the other one go out on my wife when she was out of town. My point would be that in hindsight, I should have replaced both of them once the first one went bad.
It also says to use only PS fluid, not ATF.
2001 GC ES 207,000 miles
2015 Volvo V-60
2012 Camry Hybrid
1970 Camaro, original owner
mfahey is offline
    How do I bleed power steering system? monkeywrench06 Dodge Caravan General Talk 7 11-10-2009 02:57 PM
    manual steering to power steering swap 1974d10078 1972-1987 Dodge Ram Trucks (D, W-series) 38 04-04-2009 06:33 PM
    2.7l power steering help!!!! rollin85 2G Dodge Intrepid - General Talk 2 04-09-2008 03:35 PM
    I need a Power steering bigmama_8099 Dodge Ram Truck 1st Gen (88 - 93) Forum 3 05-07-2007 11:51 AM
    power steering wndx01 3G Dodge RAM - General Talk 0 02-01-2003 04:07 PM
