AC Clutch Won't Engage - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 08-10-2004, 05:49 PM Thread Starter
gym teacher
Arrow AC Clutch Won't Engage
AC clutch won't engage when temp control is set at max cold and vent control is set to Max AC. Blower provides air at all speeds. Checked fuse in engine compartment - it's OK. Replaced relay with known-to-be-good (horn) relay. Then removed relay and jumpered #3 and #5. Clutch engages and compressor runs, however, after about 5 minutes at 1500 rpm, no cold air. System was working fine until it would not come on. Could it be a sensor that is keeping the clutch from engaging? If so, which one and where is it? Any other ideas would be much appreciated.
gym teacher is offline
post #2 of 3 Old 08-13-2004, 06:11 PM
six pak
six pak's Avatar
Since you can force an engagment but no cooling sounds like a freon leak drained system . let a pro with the req tools and knowledge figure it out
six pak is offline
post #3 of 3 Old 08-13-2004, 06:24 PM Thread Starter
gym teacher
Thanks Six Pak. I think you are correct. There are two sensors: the high head pressure sensor (located inline at the compressor output) and the low pressure sensor (located on the cannister). I jumpered the low pressure connector and the clutch immediately engaged. So the system is low on freon. I will have it checked by an A/C pro. Good call Sixer.
