2004 RAM 2500 Alarm Reset - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 12-27-2009, 09:51 AM Thread Starter
surfyak
i have a blue light flashing on the dash... three blinks pause three blinks... when i try to open the truck with either the FOB or the key the alarm sounds and the truck will not start. I tried disconnecting both battries and got the same result. Any ideas would be apreciated....
thanks
surfyak is offline
post #2 of 10 Old 12-27-2009, 10:40 AM
mitchgmace
mitchgmace's Avatar
did you get a code with key trick?
2006 Ram 2500 5.9 CUMMINS TURBO DIESEL (325/610-stock
) 4x4 Standard Cab Long Bed 6-Speed - [SIZE=1]
Westin bed extender, LINE-X, Neopene seat covers
ATS Exhaust manifold/header
Muffler, Silencer ring, & Cat MIA, striaght pipe/stack
S&B CAI =Moe's, Byrd's Intake horn, Fass Fuel System
75hp injectors
Diablosport Predator Stacked with MP8 = Ton of HP
Dual disc clutch
Kore Recon lift 34" Swamper LTB's, Garmin Nav system
572hp/1077tq
Trucks and Guns Club #127
I spend my money on my truck and not my girlfriend, because I'll have it longer and less people have been in it! "
mitchgmace is offline
post #3 of 10 Old 12-27-2009, 10:49 AM Thread Starter
surfyak
not sure what the key trick is?
surfyak is offline
post #4 of 10 Old 12-27-2009, 10:55 AM
mitchgmace
mitchgmace's Avatar
Turn your key to on and them twist it to run back and forth 3 times. But not start. Third time to run leave it there and your odometer should show a PO **** code
75hp injectors
Dual disc clutch
572hp/1077tq
post #5 of 10 Old 12-27-2009, 12:25 PM Thread Starter
surfyak
it says "done" after the key trick.....
surfyak is offline
post #6 of 10 Old 12-27-2009, 02:48 PM
mitchgmace
mitchgmace's Avatar
That means no codes. So I'm at a loss.
75hp injectors
Dual disc clutch
572hp/1077tq
post #7 of 10 Old 12-27-2009, 02:57 PM Thread Starter
surfyak
thanks for your help.. me too I have also checked the fuses and no luck their either. I am not sure if this is a factory alarm or not, I will check the batteries next to make sure there is not a lack of amps
surfyak is offline
post #8 of 10 Old 12-27-2009, 07:54 PM Thread Starter
surfyak
I am beginning to suspect a non factory alarm installed. The redlight called out in the manual is responding to the FOB, but the blue light is not... i have scoured the engine compartment and under the dash but have not turned up anything obvious
surfyak is offline
post #9 of 10 Old 12-27-2009, 08:06 PM Thread Starter
surfyak
exciting update.. found a little red switch under the dash and next to it a spring loaded button.....no clue what to do with them but hope I found something
surfyak is offline
post #10 of 10 Old 12-27-2009, 10:10 PM
mitchgmace
mitchgmace's Avatar
Bump. You might post something over in interior section. Someone might know about alarms there.
75hp injectors
Dual disc clutch
572hp/1077tq
    2004 Ram 2500 pics HVYDUTYHEMI 3G Dodge RAM - General Talk 19 07-22-2009 08:29 AM
    Thorttle Position Sensor Reset 2500 Ram CJ Growers 2G Dodge Ram Diesel Talk 3 03-05-2007 02:04 PM
    Ram 2500 Alarm Activation Von_Josh 3G Dodge RAM - General Talk 2 01-04-2007 07:01 PM
    2004 Ram 1500 Alarm Install - how to wire power locks? Burghemi Mobile Audio & Electronics Talk 3 03-15-2006 11:14 PM
    Alarm Reset after battery failure transam2001 Mobile Audio & Electronics Talk 6 03-22-2005 11:30 PM
