Loose steering/ excessive steering wheel play - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 12-08-2009, 09:35 AM Thread Starter
DAVE W
Question Loose steering/ excessive steering wheel play
Hello All,
I have a question in regards to the steering on my 2005 Ram 2500 4x4 Hemi, 48,000 miles. The steering seems to be getting loose, it takes alot of driver input while at highway speeds to keep it going in a straight line. It seems that I can move the steering wheel alot from side to side and it does not actually steer the truck. Because of this it seems to wander on the highway, and creates driver fatigue on long drives. What could be wrong, what should I check? Do these trucks have any adjustment on the steering box, if so how does one adjust?
Thanks,
Dave
DAVE W is offline
post #2 of 4 Old 12-08-2009, 09:45 AM
Hemi_2500
Bigg Rigg
Hemi_2500's Avatar
I would check your tierods for play in them.
Proud Member of the White Truck Club #77
Proud Member of the Military Truck Club #10
2013 Dodge Dart Limited Turbo
2003 Dodge Ram 2500 Hemi
2015 Dodge Journey Limited
Hemi_2500 is online now
post #3 of 4 Old 12-08-2009, 06:19 PM
Shift Kit
Beautiful Loser
That's pretty low milage for that kind of steering wear.
Do you take it off-roading? Could you have knocked it out of alignment?
I'd suspect a problem with the tires.......any odd wear patterns?
You might also swap tires front-to-back for a cheap test.
Shift Kit is offline
post #4 of 4 Old 12-08-2009, 09:19 PM
hemi1569
All Around Great Guy
hemi1569's Avatar
The front ends are pretty bad on the 3/4 tons... I have replaced numerous ball joints, drag links, track bars, have it checked by a reputable shop.
Names' Kevin
9/26/09 htc rally, best run 4880lbs, full street trim minus tailgate
14.31 @ 93.52
6.1 cam and pushrods
Ramhammer intake
Doug's headers(mids) with factory cats
catback
My 6500rpm superchip shift 0 to 60mph video
Knock retard limitations by the pcm on a stock tune, it can pull:
15.0 degrees at low RPM's
5.0 degrees at 6000 RPM
9.0 degrees at 4800 RPM's.
hemi1569 is offline
    Steering wheel loose? Ram lovr 2G Dodge RAM - General Talk 6 03-19-2009 08:11 AM
    steering wheel loose, please help!!! uncledon 2G Dodge RAM - General Talk 4 07-14-2007 08:18 PM
    Loose Steering wheel monoxide83 3G Dodge RAM - Interior/Exterior Talk 4 04-28-2006 08:31 PM
    Steering wheel loose Love-my-87-van Dodge B-Series Vans 1971 - 2003 1 03-09-2006 11:51 AM
    Loose steering wheel *dslynch* Dodge Dakota 1st Gen (87 -96) Forum 2 05-10-2005 08:17 AM
