coolant leak. need help. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 28 Old 12-05-2009, 09:36 AM Thread Starter
bgreen96
ok. i'm confused on this. the truck looses coolant not bad but it does. i fill it up once a week. when i parked it on a small incline the other day i saw coolant on the ground. i had 16.9oz water bottles in my truck. so i used that to fill it up. it only took 2 of the bottles to fill it up. when it runs i dont see coolant leaking but that one time i parked it and turned it off for about 10 mins. i saw coolant dripping and i pretty big spot on the ground. it never overheated. what could this be? have any of you experienced this?
bgreen96 is offline
post #2 of 28 Old 12-05-2009, 11:25 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
Have you checked all the coolant hoses or replaced them all? They may have a small hairline crack in them that leaks.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 28 Old 12-05-2009, 01:21 PM
dodgensince74
Quoted: 11 Post(s)
get underneath the truck and see if you can follow the leak, the leak will get you in the general area. When you figure the general area it will be easier for us to give you more help.
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
dodgensince74 is offline
post #4 of 28 Old 12-05-2009, 01:58 PM
chad1972
chad1972's Avatar
check the weep hole at the water pump
hemifever tuned 2006 dakota 4.7, h.o.cams,180 stat, auburn lsd, richmond 4.10 gears, ported and polished 68.5mm t.b. magnaflow 3" exhaust.
Dodge Talk Central Florida Member #10
DODGETALK.COM 287 ENTHUSIAST MEMBER #318
chad1972 is offline
post #5 of 28 Old 12-05-2009, 04:43 PM Thread Starter
bgreen96
yea i was thinking the water pump, but i havent had a chance to get under it yet. it looks like its running down and dripping in the middle of the front axle. its 4x4.
bgreen96 is offline
post #6 of 28 Old 12-05-2009, 10:49 PM
kevinb70
kevinb70's Avatar
also other possible leaks up front .. thermostat outlet, bypass hose (near outlet), and timing cover all of those can give a small leak like you describe
1999 Dodge Ram 1500 4x2 5.2L NV3500 Club Cab
in: sct by hemifever
-Upgrades waiting on their lazy owner to install: russell stainless lines, hawk ceramic pads, rotor, calipers, energy suspension master kit, derale 4000cfm dual fan kit, moog upper/lower ball joints
kevinb70 is offline
post #7 of 28 Old 12-06-2009, 10:05 AM Thread Starter
bgreen96
the timing cover on these truck will leak coolant? new to dodge. always had gm.
i got under it today, water pump looks dry. it maybe the timing cover. it looks like the timing cover on these truck cover the whole front block? im seeing a little wetness behind the alt. area. on the side of the block or that maybe the timing cover. from what i can see it doesnt look like the therm. housing isnt leaking. i changed the therm. a few months ago.
bgreen96 is offline
post #8 of 28 Old 12-06-2009, 11:41 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
coolant actually flows through the timing cover and yes the timing cover covers the entire front block behind water pump.
Justin
post #9 of 28 Old 12-06-2009, 12:10 PM
Bluffer
Bluffer's Avatar
Yep its your waterpump, not to bad of a job once you get that Fan-clutch pully off. (get a big cresent and whack it hard to the left with a small sledge) Also while you have it down replace T/STAT & crossover hose,
2000 4x4 SB
2in lift with 33s, Goodyear Duratracs.
5.9l
K&N air, flowmasters out.
Hypertech- 93 octane.
Rough Country shocks.
Plus some HiPO ign mods. Hayden Tranny cooler.
DodgeTalk.com 360MAGNUM Enthusiast Member #68 ~
Bluffer is offline
post #10 of 28 Old 12-06-2009, 12:43 PM Thread Starter
bgreen96
the water pump looks dry. its behind the water pump
bgreen96 is offline
post #11 of 28 Old 12-06-2009, 12:58 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
if it is behind the water pump then it is either water pump gasket or if it is farther back then it is probably your timing cover gasket.
Justin
post #12 of 28 Old 12-06-2009, 10:25 PM
Bluffer
Bluffer's Avatar
Dont know how you can see behind the waterpump but when it leaks thru the shaft seal weep hole thats where it will come from.
2000 4x4 SB
5.9l
Bluffer is offline
post #13 of 28 Old 12-06-2009, 10:50 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
All you have to do is look from a side angle. not that hard
Justin
post #14 of 28 Old 12-07-2009, 10:46 PM
BleedDodge
BleedDodge's Avatar
Has that motor got a block heater? That's worth checking if it has one. Had to change the one in my '85 gmc last year because it was leaking steady.
Green Truck Club member #15
Red Truck Club member #155
BleedDodge is offline
post #15 of 28 Old 04-05-2010, 08:53 AM
FrugalOne
What was the outcome on your coolant leak problem? My son has a '98 Durango with the 5.2L V8 that sounds like your problem. Can coolant actually get into the timing chain cover area? I've never had a Dodge and that doesn't seem normal. One of the posts dealing with your issues seemed to imply that "coolant flows through" the timing chain area. Does that mean that the timing chain runs in the coolant? If not, where is the coolant leaking from? Will something behind the timing chain cover have to be replaced? Is there a freeze plug there?
Thanks for your help.
FrugalOne is offline
post #16 of 28 Old 04-05-2010, 09:11 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
yes, coolant unfortunately does flow through the timing cover and around the timing chain and all. Mine is currently leaking around the timing cover.
Justin
post #17 of 28 Old 04-05-2010, 09:26 AM
Ricker97ram
If you're getting coolant inside your timing cover you have problems. The only thing thats wet in there is engine oil. There is a couple waterpump and timing cover bolts that do go into the water passage that may be leaking. Take the truck and have the coolant system pressurized, look for yor leak. You said you replaced the t-stat, I'd look that area over real good. Good luck
Ricker97ram is offline
post #18 of 28 Old 04-05-2010, 11:01 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
Not sure what engine you are looking at, but the 360/318's all have coolant that runs through the timing cover..not oil. That's the way they were designed.
Justin
post #19 of 28 Old 04-05-2010, 11:03 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
maybe this will help what i am talking about. take a look at the pics. http://www.pavementsucks.com/tech-article-37.html
Justin
post #20 of 28 Old 04-05-2010, 11:21 AM
FrugalOne
This inquery is a tag on to the origianl post of several months ago. We have not replaced anything on this truck yet ('98 Durango, 5.2L/318 V8). My son is military, in Rhode Island for a few months and has the problem. They did pressure test the truck at the 3rd shop he went to while the engine was hot and coolant immediately started spraying from the timing cover edge/gasket area. My question now is whether the timing cover gasket is all that will need to be replaced or is there something else behind the cover (freeze plug, etc) that may be causing this and will need to be replaced as well?
    Coolant leak/oil leak 2002 R/T Gold5th Dodge Neon - General Talk 0 03-04-2009 02:23 AM
    2000 Dodge Neon - coolant leak, rusty coolant dodgepodge Dodge Neon - General Talk 3 04-06-2007 01:22 PM
    possible coolant leak??? E6V6I6L 1G Dodge Durango - Drivetrain Talk 5 12-28-2006 08:36 PM
    98 Stratus/oil leak/coolant leak/Any suggestions? Viper65 2G Dodge Stratus - General Talk 1 11-04-2005 07:41 PM
    Coolant Leak hamahed 2G Dodge RAM - General Talk 2 12-03-2003 11:19 PM
