Exploded views of the axles - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 16 Old 11-30-2009, 04:30 AM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking Exploded views of the axles
I came across this exploded view of the axles in my search for 5.13 gears.
Page 56 is the front axle and page 60 is the rear axle.
http://cumminsownerz.com/PDF/AAM-Breakdown.pdf
Found gear sets for the 9.25 front axle, but not of the 10.5 rear axle.
PWOC #53
2008 POWER WAGON RC
Sequentially Number #08-1505,
Inferno Red, Automatic
Mods to the PW;
Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Extang Tonneau Cover, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, Had 35" Cooper STT's now 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper, PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal and it's own body bag!, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, MORE STUFF COMIN', TTI headers, Somebody's long arm, 7.2L MOTOR
Mods to me; Ti hip replacement. Zerk fitting in knee. Now it's gets greased more than some guys front drive shafts. I've been Used, Abused and Recycled!
Survivor of The Cold War,
Heaven's Gate, The Grand Conjunction, The Pleiadeans Landings, Y2K, The Winch Mob Banning, The Mayan Apocalypse, and some other covert stuff. Future ISIS killer!
"Moab '10, '12, '14",
"Rausch Creek-Spring, Fall '11, Spring '12, Summer '13, Summer '14"
RUSS
RustyPW08 is offline
post #2 of 16 Old 11-30-2009, 10:22 AM
Hemi_2500
Bigg Rigg
Hemi_2500's Avatar
When I open that .pdf file up there is only 43 pages to it.
Proud Member of the White Truck Club #77
Proud Member of the Military Truck Club #10
2013 Dodge Dart Limited Turbo
2003 Dodge Ram 2500 Hemi
2015 Dodge Journey Limited
Hemi_2500 is offline
post #3 of 16 Old 11-30-2009, 10:30 AM
crawler#976
crawler#976's Avatar
Tip: Ya have to read the page #'s on the doc.
Page 56 is on page 30 of the PDF file.
Page 60 is on page 32 of the PDF file.
Sarchasm : The gulf between the author of sarcastic wit and the person who doesn't get it.
crawler#976 is offline
post #4 of 16 Old 11-30-2009, 11:13 AM
TwinStick
Good find !!!
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #5 of 16 Old 11-30-2009, 12:48 PM
Hemi_2500
Bigg Rigg
Hemi_2500's Avatar
ok I didnt even look on the book for page numbers.
post #6 of 16 Old 11-30-2009, 04:25 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Angry
Also found 5.13's for the 11.5. Nothing for the 10.5.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #7 of 16 Old 11-30-2009, 09:18 PM
Sixspeed
Sixspeed's Avatar
Nice find Russ! Now all I need is the exploded view of the rest of the truck...What I really need is an OEM service manual, IMO there is really not much point in cheaping out on a haynes manual, or other crappy manual. I hate it when I come across something that I need to get apart but it isn't shown or explained in the manual that I'm working from.
Sixspeed is offline
post #8 of 16 Old 12-06-2009, 11:22 PM
AcemanMCT
Power Wagon Winch Mob
AcemanMCT's Avatar
Wasn't this discussed before that the 5.13s can't fit in the 10.5" rear? It sounds familiar.
AcemanMCT is offline
post #9 of 16 Old 12-06-2009, 11:27 PM
AcemanMCT
AcemanMCT's Avatar
FYI, FWIW, and I'm not sure if this was ever posted, but I found a PDF of the 2006 Dodge Ram service manual (includes Diesel and Ram SRT10). I uploaded it to SendSpace, a free file storage site. Go to the following link for the download.
http://www.sendspace.com/file/j12l45
The password for the zipfile is acemanmct (all lowercase).
I found the 2005 file, but it was corrupt. I tried to repair it but no luck.
post #10 of 16 Old 12-06-2009, 11:46 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Angry
Read about a couple of guys talking about using the GM AAM 10.5, 5.13 gear set in the Dodge AAM 10.5 housing. BUT I can't get no other information on it. So far I found 5.13's for the Dodge front 9.25 AAM axle, and for the 11.5 AAM rear axle. And for the GM 10.5 AAM rear axle. I tried to cross part numbers with a different ratio between the Dodge and GM 10.5 with no luck.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #11 of 16 Old 12-07-2009, 03:31 PM
AcemanMCT
AcemanMCT's Avatar
I spent a little time searching, but I didn't find much. Some of the results that came up were actually our posts in this thread other threads in DT.
post #12 of 16 Old 12-07-2009, 04:56 PM
fbenross
fbenross's Avatar
Thanks for the manual Aceman
2006 POWER WAGON 6 SPD
1970 SCOUT 800 4 SPD
fbenross is offline
post #13 of 16 Old 12-08-2009, 12:17 AM
AcemanMCT
AcemanMCT's Avatar
You are welcome!
post #14 of 16 Old 12-08-2009, 12:23 AM
AcemanMCT
AcemanMCT's Avatar
Due to any possible copyright infringements, I pulled the link. Sorry if anyone wanted it but didn't grab it while it was up. There is a copyright clause in the DT posting guidelines section. I thought JUST IN CASE this falls under those guidelines, (it's kind of a gray area), I should pull it.
PM me if you have any questions.
post #15 of 16 Old 12-08-2009, 09:00 PM
Sixspeed
Sixspeed's Avatar
Smart move Ace
Sixspeed is offline
post #16 of 16 Old 12-08-2009, 10:11 PM
AcemanMCT
AcemanMCT's Avatar
Thanks, Sixspeed!
    Battery almost exploded! ramman1 1972-1987 Dodge Ram Trucks (D, W-series) 22 01-07-2007 08:51 AM
    Exhaust views? freefaller 2G Dodge Ram Performance Talk 3 01-01-2006 03:04 PM
    Views Of the Magnum DroolsForHemi Dodge Magnum - General Talk 11 02-15-2005 03:07 PM
