oil smells like gas? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 11-29-2009, 11:08 PM Thread Starter
Whittim
Hey guys I have an 88 d250 with a 2 barrel 360. It's freshly rebuilt with a new holley rebuild. Was having starting issues and finally got the carb dialed in. Changed the oil after because it was running rich. It sat for a week before I started it again so I checked and the oil smells like it has gas in it again any ideas?
~DodgeTalk.com 360MAGNUM Enthusiast Member #68
1988 Dodge D250
edelbrock 1406 carb/9906 intake, 727 Torqueflite
Whittim is offline
post #2 of 15 Old 11-30-2009, 01:26 AM
power ram
power ram's Avatar
How Do The Plugs Look....
1988 dodge ram 4x4
1991 dodge ram 2wd
power ram is offline
post #3 of 15 Old 11-30-2009, 06:22 AM Thread Starter
Whittim
Reply just put a new set in right after i changed the oil, turned in the idle mixture screws a whole turn to try and lean down the mixture. Haven't checked the plugs because they haven't had much run time yet.
1988 Dodge D250
Whittim is offline
post #4 of 15 Old 11-30-2009, 06:29 AM
power ram
power ram's Avatar
how many times have you run it with the oil thats in it...
1988 dodge ram 4x4
1991 dodge ram 2wd
post #5 of 15 Old 11-30-2009, 07:49 PM Thread Starter
Whittim
It probably has about an hour n a half of run time
1988 Dodge D250
Whittim is offline
post #6 of 15 Old 11-30-2009, 10:09 PM
power ram
power ram's Avatar
pull out the #1 plug... see if it is gassy....
1988 dodge ram 4x4
1991 dodge ram 2wd
post #7 of 15 Old 12-01-2009, 06:42 AM
power ram
power ram's Avatar
check that plug, see how it is running.. if it is a little lean, like you want it... then drain out that oil, let the pan drain till it is as close to 100% dry as you can and do new oil and filter again.. run the engine for a minute or two and check the oil to see if it stil smell's.. i think there was a little of the old gassy oil left in the engine, wich mixed with your new oil and spooled it.. that gas in the oil will kill your barrings so get it outa there....
1988 dodge ram 4x4
1991 dodge ram 2wd
post #8 of 15 Old 12-01-2009, 09:10 PM Thread Starter
Whittim
Ya its weird because i added a lucas to the oil and it seems thin and and smells like gas right after the oil change.. could the float be miss adjusted?
1988 Dodge D250
Whittim is offline
post #9 of 15 Old 12-01-2009, 11:36 PM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
A bad fuel pump can some times leak gas into the oil.
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #10 of 15 Old 12-02-2009, 12:14 AM
power ram
power ram's Avatar
ya know thats possable, check your fuel pump aswell...
1988 dodge ram 4x4
1991 dodge ram 2wd
post #11 of 15 Old 12-02-2009, 06:28 AM Thread Starter
Whittim
Ok thats a thought it froze up on me last winter and i thought the fuel pump was the problem.. wouldn't hurt to put a new one on any ways
1988 Dodge D250
Whittim is offline
post #12 of 15 Old 12-02-2009, 06:32 AM
power ram
power ram's Avatar
ya, pull it off and check it for leaks..
1988 dodge ram 4x4
1991 dodge ram 2wd
post #13 of 15 Old 12-02-2009, 08:06 AM
charlie1935
Quoted: 6 Post(s)
Operate the pump by hand with with a piece of line into a container of gas.
If it is what I'm thinking it will spurt out the opening where the lever is that operates off the camshaft.
Grouchy Old Man
Sport short bed
SSBC slotted rotors
3.55 rear
MSD coil
Edelbrock shocks
post #14 of 15 Old 12-02-2009, 08:43 AM
power ram
power ram's Avatar
ya thats good thinking, i never thought about a possable internal leak at the pump..
1988 dodge ram 4x4
1991 dodge ram 2wd
post #15 of 15 Old 12-02-2009, 04:07 PM Thread Starter
Whittim
alright thanks guys ill check it out this weekend and let you know how it go's
1988 Dodge D250
Whittim is offline
    03' Grand Caravan Oil Smells Like Gas JSlot Dodge Caravan General Talk 1 03-22-2009 04:45 AM
    Truck won't start. Smells like gas. durango-driver 1G Dodge Durango General Talk 15 11-18-2008 06:21 PM
    smells like gas fumes around truck Deerango20 3G Dodge RAM - General Talk 0 08-30-2008 10:04 AM
    puff of smoke...smells like gas dodge fever 2G Dodge Ram Performance Talk 3 02-02-2006 02:28 AM
    Oil smells like gas daggerdepot 2G Dodge Ram Performance Talk 5 03-02-2005 09:31 AM
