Transmission Fluid Change Or Transmission Flush? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 22 Old 11-29-2009, 11:18 AM Thread Starter
AmericanRobster
Silver Bullet
AmericanRobster's Avatar
Question Transmission Fluid Change Or Transmission Flush?
I have an automatic transmission with my 2007 Dodge Ram 1500 4.7 V8 truck with almost 34,000 miles, should I change the transmission fluid or flush the transmission? I also plan on changing the rear diff fluid myself. Thanks !!! Rob
2007 Dodge Ram 1500 THUNDER ROAD 4.7 V8
Lifetime Power Train Warranty Holder
15% Tint, K&N Air Filter, Denso Platinum TT Spark Plugs, DDM Tuning 6000K HIDs, 3.92 Gears
Soon to come...
Exausts, Stereo
AmericanRobster is offline
post #2 of 22 Old 12-01-2009, 01:59 PM
mastertech
follow service schedule
mastertech is offline
post #3 of 22 Old 12-01-2009, 03:33 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
with an 07 at 34k I would let the dealership flush it. I always like to change ALL the fluid out and not just whats in the pan.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #4 of 22 Old 12-01-2009, 05:25 PM
peeblesm
ol faithful
peeblesm's Avatar
do a flush to be on the safe side. but also check out the service interval to.
2004 dodge ram 1500 4.7L engine. quadcab; shortbed 2wd
military guy
nv3500 5-speed tranny
s&b cold air intake
4.56 motive gears and detroit tru trac in the rear end
centerforce II clutch
gibson headers, dual exhaust
flowmaster mufflers 40 series
NGK Spark Plugs (G-power) ZFR6FGP 7100
jet performance 180* t-stat
hurst competition plus shifter #3910155 (94-00 dakota v8) fits nv3500 tranny
line-x spray in bedliner over the rails
camper shell (A.R.E. brand with no windows on the side. too many blind spots now)
kool vue tow mirrors
debadged ram 1500 letters on both sides
PML diff. cover(I like it)
265/70/17 tires on stock rims painted metallic black ( holding up good so far. lol )
peeblesm is offline
post #5 of 22 Old 12-02-2009, 04:23 AM
BossMaverick
I do a "pan drop" fluid and filter change every 15,000-20,000 miles on my '05. I figure by doing this the fluid is still getting changed more often that the owners manual calls for and I can save money doing it myself versus having to pay for the fluid flush. I'd say your at a low enough mileage that this should work for you just fine. The main thing is just doing something instead of letting it go and go and go without changing any of the fluid.
If you can't do it yourself, you might as well spend the few extra dollars and get the flush. If you do decide to change it yourself buy a few extra pan bolts before you begin. You will strip a couple until you learn to go very easy on them.
BossMaverick is offline
post #6 of 22 Old 12-02-2009, 06:30 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
You are correct on this. When I read about it and seen the issues others had with them, I thought ahead and went to the hardware store and bought all new grade 5 or 8 bolts and used them and did not have not one issue with any bolts going back in.
Next projects:
- Custom CAI
weedahoe is offline
post #7 of 22 Old 12-02-2009, 08:15 AM
BossMaverick
weed, do you remember what size the bolts were? I would love to upgrade mine as I still find myself stripping bolts.
post #8 of 22 Old 12-02-2009, 08:22 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I dont remember and there is a nice DIY thread out there but even it didnt have the sizes so I just took one to the store with me and matched it up. I know that doesnt answer your Q but maybe it helps.
Next projects:
- Custom CAI
weedahoe is offline
post #9 of 22 Old 12-02-2009, 08:47 AM
Hosack
Hosack's Avatar
The tech at the dealership that rebuilt my trans said drop the pan and change the filters with Dodge OEM stuff every 20,000 miles.But,I know people that do the flushes and keep up with scheduled filter changes and their trans are fine.
2002 White Dodge Ram 1500 4x4 quad cab 5.9 sport/slt
Hosack is offline
post #10 of 22 Old 12-02-2009, 12:34 PM Thread Starter
AmericanRobster
Silver Bullet
I talked to this mechanic who is right next door from where I work and he said to do a transmission flush every 30k. He recommended that I use the BG fluid and it would bring the grand total to $270. I think that's high for a transmission flush. I think the dealer around here does it for $200 if I recall right.
Soon to come...
Exausts, Stereo
post #11 of 22 Old 12-02-2009, 02:11 PM
HemiPro_05
HemiPro_05's Avatar
dodge puts 100k plus mile transmission fluid in
HemiPro_05 is offline
post #12 of 22 Old 12-02-2009, 04:56 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 56 Post(s)
Skip the flush. A drop 'n' drain "by the book" is sufficient. I think the interval is 60K on the '07s.
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #13 of 22 Old 12-03-2009, 02:31 AM
BossMaverick
You confused yet? You have answers ranging from 15,000 miles all the way to 100,000 miles.
What hasn't been touched is how hard you work your transmission. A lot of interstate highway miles mean longer intervals, while stop and go city driving, towing, or snow plowing may require more frequent intervals. A good thing to remember is Chrysler has put out notices that the ATF +4 fluid does not smell or turn colors when worn or burnt as typical ATF fluids do, so if you wait long enough for one of these signs your transmission is probably already toast. If your still undecided, why not post how you use your truck and in what kind of heat?
For the record, I drop my pan every 15,000 to 20,000 not because I'm that hard on my transmission, I'm just paranoid about my auto transmissions dying. I admit I can be a little OCD when it comes to changing auto trans fluids.
post #14 of 22 Old 12-03-2009, 05:45 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
This is very correct and to re-affirm, the color or smell gives no indication on the condition of the oil
Next projects:
- Custom CAI
weedahoe is offline
post #15 of 22 Old 12-03-2009, 08:12 AM Thread Starter
AmericanRobster
Silver Bullet
Ok, I live here in Florida and I drive my truck mostly in the city. My daily commute to work is about 30 miles a day. I don't really get on the highway alot and I never tow anything at all.
Soon to come...
Exausts, Stereo
post #16 of 22 Old 12-03-2009, 11:57 AM
TwinStick
Here is what I posted on another thread. Post # 43
http://www.dodgetalk.com/forums/show...=198664&page=3
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #17 of 22 Old 12-04-2009, 06:05 AM
BossMaverick
For you, I'd vote to either drop the pan or do the flush every 30,000 since it sounds like a lot of stop and go driving in hot weather. Again, just as long as you do something and not let it go and go and go without changing the fluid somehow.
post #18 of 22 Old 12-04-2009, 03:55 PM
Shaun2003
Hauln' A$$ Suckin' Gas
Shaun2003's Avatar
if you take it some where to do a "flush-fill" make sure that they also drop the pan and replace the spin on filter inside, i have seen some advertising for flush-fill and but on further inquiry thats all they do so no filter change, they tell you that with the flush fill it cleans the filter in the process, this is a load of BS. Just thought i would mention this oh and btw i have mine changed every 30k or 1 year which ever comes first.
Names: Shaun
2009 Dodge Ram 3500 Quad Cab Laramie 4x4 - Brilliant Black
CTD Dually
previous truck: 2003 Dodge Ram 1500 Quad Cab SLT 4X4 - Atlantic Blue
5.7L V8 HEMI!!!
BLUE TRUCK CLUB MEMBER #123
Rice sucks #15
Tow Mirror Truck Club Member # 4
Dodgetalk.com 345 Enthusiast Member #42
Official DT Signatures By Rye, User
Other Vehicles: 2011 Honda TRX420 PG, 2008 International 4300 DT466 Roll-off
Current Mods:
XD Spy Black 20X9,K&N FIPK CAI,
Xenon Dual Beam HID's by Twiggy,
Alpine Deck CDA-9885, Pioneer Speakers,
Powder coated black textured Nerf Bars, Chrome Fuel Door,
Chrome door handles, Rhino Bed Lining,
Shadow Billet Grille, Diamond Plate bed caps,
Blue Painted Calipers, Fog lights
Flip up Tow Mirrors, Front windows tinted to match back
Kenwood sub, Clarion APX2180 Amp
Sealed Fox Box, Retrax Tonneau Cover
Nitto Terra Grappler 305/55/R20
Pop & Lock Power tailgate lock
SRT 10 Hood, Street scene bumper cover
Viper 5901, SC 3865
Solo Performance muffler with custom pipe work
Future Mods:
Body Lift Kit
Ya it's got a HEMI!!
Shaun2003 is offline
post #19 of 22 Old 12-04-2009, 04:35 PM
ChadsGotAHemi
Chad Loves His Hemi
ChadsGotAHemi's Avatar
I have a Dodge Mechanic in my wifes family. I have a HEMI so probably different tranny but he told me change mine at 50000km, making sure they change BOTH filters. I got the quote at $291 (Kind of high but piece of mine knowing a Mopar Mechanic is doing it and is on the books. He also told me change it again at 100000km and get the mechanic to tell me what he sees in the pan. My warranty goes till 120000 so if the mechanic sees something bad.. Start complaining of tranny problems. Just my .02
The Truck:
2008 Dodge Ram 1500 QC 4x4, Towing Package 5.7 HEMI 17' Rims No Lift, GoodYear Wrangler SRA's 265/70/R17(Garbage)
Additions:
K&N Performance Cold Air Intake, Line-X Spray in Bed Liner, Roll-up Soft Tonneau Cover, Serius Satelite Radio, Cobra 29 CB Radio, Chrome Exhaust Tip, Recon Cab Lights, Chrome Door Handles & Gas-Cap, Lights Behind the Grille, 2.5" Leveling Kit, Chrome Bug Deflector
Will be put in VERY Soon:
Wish List:
Gibson or Magaflow Exhaust, Nitto Terra Grapplers, Bull-Bar, New Grille, SuperChips!
ChadsGotAHemi is offline
post #20 of 22 Old 12-04-2009, 09:04 PM
VengefulHemi
Rollin On 4:56's
VengefulHemi's Avatar
Here is the DIY on the tranny flush: http://www.60ateight.com/DodgeRam/
05/Hemi/QC/FlameRed/2WD
Exterior Mods: Willmore Quad Length Nerfs(colormatched)/Debaged/SilverStars-in Fogs/Extang BlackMax Tonneau-Red/Color Matched Handles,Mirrors,Cowl,Antenna Thingy/Recon Smoked Rooflights(Colormatched-Red)
SRT10(Mopar) Hood/Bumpers-F&R(powdercoated-colormatched)/Blackedout(completely)Headlights(500deg paint&clearcoat)/ HID's(4300k)/tctwg(a.k.a.-Tim)Wiring Harness
Tires: Toyo Proxes ST 11's(Superior Traction, but too wimpy looking) I want to trade for aggressive looking ones
Suspension Mods: Leveled(2.5" Daystar Coil Spacers)
Drivetrain Mods: 4:56 Gears
Engine Mods: Jetstream Scoop/PowerWire/Homebrew Intake/SI-DO Exhaust w/Flomaster Hemi Muffler(no resonators)/Flashpaq 3815/DMH E-Cutout/Black Magic 180 Extreme E-Fan/180 T-Stat
Interior Mods: Covercraft Sunshade
Red Truck Club Member #230
VengefulHemi is offline
    Transmission Fluid Change? PFC_2008 2G Dodge Stratus - General Talk 3 03-22-2009 04:33 PM
    transmission fluid change? rlane11 2G Dodge Dakota - Drivetrain Talk 2 10-12-2008 03:57 PM
    Transmission Fluid Change, etc. siiturbo 3G Dodge RAM - Drivetrain Talk 2 12-03-2007 07:43 AM
    Transmission Fluid Change roberto19823 2G Dodge Stratus - General Talk 0 01-09-2006 09:01 PM
    Transmission Flush, or Fluid Change? rumbleT 3G Dodge Ram Performance Talk 5 08-17-2005 09:50 AM
