Thread Tools |
Yellow sludge buildup in oil cap. Ideas?
- Posted: 11-28-2009, 12:04 PM
Post #1
We have a 2005 Durango SLT 5.7 hemi we've had since about July '09. I have changed the oil once on it. It had a synthetic blend something or other, so I went with full synthetic Mobile 1 5w-20 this time around.
Really, this is the first time I have ever put synthetic in any of my vehicles. I do all my own oil changes on all 4 of my vehicles and have done so since i first got my license @ 16. I had always went conventional and changed religiously at 3k miles or less. Anyways, I had to change a leaky power steering hose on the Durango last night, and I thought I would check the oil.. It appeared to need a top off, so I took the oil filler cap off and there was a bunch of stuff that would be best explained as yellow sludge. It looked like lithium grease. I turned the cap over and there was water in there that appeared to be condensation. I cleaned it out completely with brake cleaner topped off oil and put it back. I immediately checked my coolant level and it appeared fine. I have been searching the internet and found that there can be condensation buildup if the PCV valve isnt working properly and due to the design of the filler cap being higher than the pcv valve, that condensation may naturally collect there. I am concerned as to the condition of the internals of the engine. Would this be simply due to the colder temps and condensation buildup or would it be related to the synthetic oil? This is the first time i have ever seen this in my years of doing oil changes, and this is the first time i have used synthetic, so im trying to figure our if there is a relation. Also, it is parked outside, so when the temps range about 40 degrees or lower, the oil light comes on when first started for the day. When the vehicle is shut off and turned back on, typically the oil light will go off unless its really cold. This has occurred even before i changed the oil. I am concerned that it could be a pick up screen in the oil pan, but i have searched the internet and found others with a similar issue, so i dont know if its a common issue/false positive or there is really a mechanical issue. Anyone ever experience the sludge or oil light issue? Anyone have any input or ideas? Thanks in advance! James
[2004 RAM 1500] - new to me 6/28 w/ 156k miles. [2005 Durango SLT] - Wife's grocery getter/kid hauler. [1997 RAM 1500 SLT] -- SOLD 6/25 w/ 193k miles |
| Sponsored Links | |
Advertisement |
Posted: 11-28-2009, 02:37 PM
Post #2
My 4.7L does the same thing. I asked a mechanic and he said it was condensation and not to worry about it. That was over a year ago, so I just don't think about it.
Posted: 11-28-2009, 03:07 PM
Post #3
X2
...Leading Durango HEMI Performance since 2004...
2007 Dodge RAM 3500 CTD 5.9L Cummins SLT 2008 Dodge RAM 5500 CTD 6.7L Cummins SLT 2011 Dodge RAM 2500 CTD 6.7L Cummins Laramie |
Posted: 11-28-2009, 04:40 PM
Post #4
X3... nothing to worry about
Posted: 11-29-2009, 07:38 AM
Post #5
The condensation is normal, but the oil light may not. The oil light may stay on until the pressure comes up, right after engine start. This should only be a few seconds after start. If it stays on longer, than the oil pump may be worn, pickup tube or filter clogged, or sluggish pressure sensor. How long on a cold engine does your light stay on? Depending on the grade, your synthetic oil has realy good pumpability at cold start.
Posted: 11-30-2009, 12:46 PM
Post #6
On the sludge as long as it's just the oil cap no worries, if your oil starts to looklike a milkshake, then worry.
On the oil pressure light.. it's a $30 part, so it maybe worth it to try replacing the oil pressure switch, it's just above the oil filter facing the front of the engine (on the Hemi). My D would always have the light on when it was cold out and cold started.. first time I noticed I had been idling for about 20min letting the D warm up, I freaked, turned it off and back on light went out. after that if the light came on on start up, I just turned off the motor, restarted and it was out. With the new oil pressure switch, no light anymore.
Posted: 11-30-2009, 01:04 PM
Post #7
Mine doesn't have the buildup but there was another thread about it and I guess it's pretty common.
Posted: 12-23-2009, 05:54 PM
Post #8
I am the original owner of a 2005 Ram 1500 slt with a 4.7. From the first oil change, the underside of the oil cap has collected condensate from the crankcase. No biggie.
As of last winter, when it's real cold out the oil pressure gauge dosen't read. Like others i freaked at first. It all good. After 4 years and almost 70,000 miles, I still love my truck. |
Posted: 12-23-2009, 09:33 PM
Post #9
cehall17, you may need a new oil pressure sending unit.. I did.. it was about $25 up here in Canada for the part, and all I needed was a deep socket 23mm or something(can't remember) dealer said 21mm.. but they were wrong. I waited til next oil change swapped it out.. added like 8min to the oil change time and 3min of that was figuring out by touch how to disconnect the darn wire harness...
Posted: 12-24-2009, 12:12 AM
Post #10
Mine has never had that issue.
BLACK '04 Durango LTD "Yeah, it's got a HEMI" SPEED HAS NEVER KILLED ANYONE, SUDDENLY BECOMING STATIONARY, THAT'S WHAT GETS YOU! Black Truck Club member #153 | DT Durango Club member #72|Hemi Club member #102 |
Posted: 12-24-2009, 06:43 PM
Post #11
Proverbs 3:5-7 Reese Brake Controller Tow Kit (MacGyver Homebrew) CAI ![]() Flowmaster 40 Series 35% Front Windows Superchips 3865 Grille Airflow Restriction Delete Air Ram Power Wire 10.2 inch Alpine Rear Flip Down DVD System Royal Purple Full Synthetic Oil 20inch Boss 331's 275 55 20 Pirelli Scorpions Black Stubby Antenna |
Posted: 01-04-2010, 09:12 AM
Post #12
Posted: 01-09-2010, 04:18 PM
Post #13
Took my D in today to replace rear pinion seal AGAIN and also asked them to provide some input on this yellow sludge and they said it was due to condensation. They also suggested to replace the PCV in case it was not breathing well. Had an oil change done and replaced the PCV so will see if there is any benefit...
2004 Dodge Durango Limited |
Posted: 01-10-2010, 08:34 PM
Post #14
This is a common occurence on the 4.7L and 3.7L engines.
It is emulsified oil and water and nothing to worry about. It is usually caused by frequent short trips when the engine doesn't get fully warmed up or very cold climates. The water doesn't get hot enough to evaporate out. And it doesn't help that the filler neck is so high and further away from the engine. If this happens to you I would consider shortening your oil change interval or switching to a high quality synthetic. If you are really worried about it send in a sample of your oil for anaylsis before switching or changing interval, you may be fine. Both the 4.7 in my Aspen and the 3.7 in my Liberty do not have this problem, probably because we hardly ever do any short trips and live in a warm/temperate climate. Syn Rotella 5w-40 in the 4.7 and regular dino juice in the 3.7.
'07 Chrysler Aspen / Brilliant Black Metallic 4.7 Flex Fuel 2WD -Airaid Jr. -Dynomax 30" HD Super Turbo -Shell Rotella T Syn 5w-40 w/ 51515 Wix Filters -Amsoil 75w-140 -Motive 4.10 Gears -Bilstein Shocks -MYGIG RER w/Lockpick Adapter -Backup Camera -Stainless Nerf Bars -Chrome Hood Deflector -Chrome Tow Hooks '11 Jeep Liberty Sport 4X2 DD '06 Mercedes-Benz C230 Sport |
Posted: 01-10-2010, 08:36 PM
Post #15
It's present on my oil cap, but it doesn't seem to be an issue
Posted: 01-10-2010, 10:29 PM
Post #16
I asked my Dodge what it was, and it told me to stop pissing in the tank after the bars...
2011 Ram 1500 4.7L CC 265/70/17 GoodYear Duratracs 2004 Dodge Durango 4.7L 136,143 Miles -TRADED
Posted: 01-11-2010, 06:36 AM
Post #17
Posted: 01-11-2010, 02:50 PM
Post #18
Fuel additive...
Posted: 01-11-2010, 03:42 PM
Post #19
Me too, condensation, no need to worry my 4.7 does it too.
2004 Durango ST 4.7L AWD Mods; Window tint, TB lift, Straight Pipe Exaust.
Posted: 01-12-2010, 08:23 AM
Post #20
Several days now after my oil change and PCV replacement, My D runs better. Wonder what the life expectancy of the PCV is for our D's? This is my first time replacing it after 103K miles. It has to be less then that....
| Thread Tools | |
| Billet Aluminum Oil Cap fits over OEM Cap | rasdon | For Sale - Truck Parts | 3 | 01-01-2008 06:01 PM |
| sludge under oil cap - 2002 4.7 litre | kcb | 1G Dodge Durango Performance Talk | 6 | 03-07-2007 07:32 PM |
| oil sludge? | beaver_scott | 1G Dodge Durango General Talk | 9 | 11-13-2006 05:00 PM |
| Yellow snot on oil filler cap | WkndDrnk | 3G Dodge Ram Performance Talk | 5 | 03-01-2006 09:23 PM |
| Oil Sludge... | bigpav7 | 1G Dodge Durango General Talk | 25 | 05-18-2005 09:44 PM |
Privacy Statement | |
