Pics of Bypass Hose? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 11-23-2009, 07:04 PM Thread Starter
Harrison_Berger
Quoted: 2 Post(s)
Does anyone have a pic of the heater bypass hose on a 5.9 gasser or equivalent?
Is it something that just can't be seen without taking off the alternator and the various brackets? I just replaced my radiator a few days ago and today something blew up and sprayed the engine with coolant. Looks like the bypass hose is a common culprit, but I would like to make some kind of visual inspection before I order a new one.
I am going out of town tomorrow and don't have the option of taking it apart tonight. It would be nice if I could order whatever parts I need before I leave or while I'm gone so they can be waiting for me when I get back.
#7
Harrison_Berger is offline
post #2 of 9 Old 11-23-2009, 09:05 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
The bypass hose you cannot see unless you remove the alternator, and a/c compressor. I had to replace mine and it is not too bad. Let me see if i can find the pics of when i done it.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 9 Old 11-23-2009, 09:18 PM
truckman323
truckman323
truckman323's Avatar
Quoted: 3 Post(s)
i have pics on my thread for doing the plenum.....it might be the o-ring on the hard pipe going into the water pump blew too....i'll look for pics
Yes, this is my truck. No, I won't help you move.
Current: 2015 1500 Ecodiesel, outdoorsman, crew cab, leveled with Bilsteins
Sold: 2013 Ram 1500 CC, Flame Red, Outdoorsman, 6-spd, 3:55s, BT Catch Can, TonnoPro Loroll tonneau, 26% front tint, Bilsteins @ 2.1, Mevotech UCAs, AirLift 1000's, plasti dipped badges, wheels an bumpers, Amsoil
Sold: '07 Ram 1500, 295/70/18 Nitto Terra Grapplers, American Racing ATX, K&N Cold Air, true duals, ProCote bedliner, 6" lift, Firestone Air-ride Suspension Helper Springs, Bilstein 5100s, Pioneer navigation unit, AMSOIL, 190 t-stat, 1-ton transmission cooler, Transgo, 4.10 with Auburn LSD, Superchips
Sold: '07 Ram 1500 Mega Cab, 5.7l Hemi, AirRait AIT intake, AMSOIL, Hellas behind the grill, block heater, Transgo HD2 shift kit, B&W gooseneck hitch, Magnaflow 4" stainless exhaust, 2" leveling kit, Bilstein 5100s
Sold: '99 Ram 2500, 5.9l 360, NV4500 Tranny, AMSOIL, 180 T-stat, MOPAR Performance open element, home ported TB, plenum fixed, 2" leveling kit + Bilstein 5100's, 295/75/16 BFG AT KO's on black RockCrawler steelies, Magnaflow high-flow cat and muffler, 3" single in/out, smoked cab lights, luke's links, lights, lights, lights
truckman323 is offline
post #4 of 9 Old 11-23-2009, 09:27 PM
truckman323
truckman323
Quoted: 3 Post(s)
http://www.dodgetalk.com/forums/showthread.php?t=231255
you can see it in a couple of the pictures. If you want better pictures of it just let me know, and I will send them to you.
post #5 of 9 Old 11-23-2009, 10:00 PM Thread Starter
Harrison_Berger
Quoted: 2 Post(s)
Thanks, I can make it out in truckman's pics, I am thinking that is where my blow came from. The hard line with the o-ring looks fine, so I don't think it could have lost as much coolant as was lost.
I guess I am just going to order the hose and hope that is it, I'll get a new o-ring too just so that does not go next. What size is the o-ring?
post #6 of 9 Old 11-23-2009, 10:28 PM
truckman323
truckman323
Quoted: 3 Post(s)
I'm not sure what size the o-ring is......you might just have to take it off and take it to a parts store to match it. Hopefully it's just the bypass hose and you won't have to worry about the o-ring on that hard line. if you lost a LOT of coolant, then that line going into the water pump is probably not the problem. Usually that's just a slow seep.
post #7 of 9 Old 11-24-2009, 01:54 AM
DerwooD509
Get some new clamps while your at it, when I did mine the old clamps were pretty crappy shape, clamps are cheap might as well only do the job once.
Just finishing fixing the plenum now, broke a damn intake bolt GRRRRRR, I think my torque wrench has taken a dump, this angers me greatly.......
'98 Ram 4x4 318 xtend cab auto
3" lift & 33" Cooper SST on stock chrome rims.
Magnaflo highflow cat into Magnaflo muffler 3"
Mopar perf open element air cleaner and K&N
TB cleanup mod, stock kegger port mod,
SOON- headers & Y pipe, some type of program flash.
Pioneer head unit, Infinity 6x9 front & 6" rear, Infinity 4ch 600W amp, 10" sub Pioneer amp. Sirius sat, Cosco baby seat lol
Hauls my SkiDoo summit 1000 winter & home reno stuff and camper summer.
DerwooD509 is offline
post #8 of 9 Old 11-24-2009, 03:26 AM Thread Starter
Harrison_Berger
Quoted: 2 Post(s)
Where do you get the special hose clamps that came stock? Can those be had generically, or do I have to buy them from Dodge?
I read on here that changing to the screw type is not a good idea.
post #9 of 9 Old 11-24-2009, 11:23 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
changing to the screw type is actually better. i changed all mine to the screw kind. But you should be able to find those kind at some auto parts stores i am sure of.
Justin
    Coolant bypass hose 3.9L F_Dog23 2G Dodge Dakota General Talk 1 07-26-2009 10:24 AM
    water pump bypass hose Jmw132001 2G Dodge RAM - General Talk 3 09-28-2008 09:34 AM
    How do I change the bypass hose? anthdale 2G Dodge RAM - General Talk 11 03-19-2008 07:03 PM
    Water pump bypass hose tube corroded **PICS** btrotter 1G Dodge Durango General Talk 9 12-03-2006 08:00 PM
