Draining Coolant - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 11-18-2009, 09:00 PM Thread Starter
Harrison_Berger
Quoted: 2 Post(s)
Draining Coolant
I'm changing my radiator tomorrow. What is the word on taking out the coolant plugs on the block?
My Haynes manual says do it, and that the holes may be rusted over and need a good poking to open them.
1.Is their a risk of this poked rust clogging my new radiator, or will all the loose stuff come out once the coolant starts flowing from the hole?
2.I read that on some vehicles removing the plugs is not advised because they are often so corroded that they break off, is this a problem on our trucks?
I've never done this because I didn't know the plugs were there.
Harrison_Berger is offline
post #2 of 18 Old 11-18-2009, 09:29 PM
barracudadave67
I wouldnt do it. When you have the hoses off just flush it real good.
You stand a good chance of creating a lot of unneeded work by pulling the freeze plugs its not worth the chance.
Flush it good with clean water, mix up some new anti-freeze, with a 50/50 mixture and be done. You could change the bypass hose, just to be safe, and maybe your upper and lower hoses, and T-Stat, if needed. Thats all I would do, if I was only changing the radiator.
barracudadave67 aka Dave C.
04 Dodge Ram 1500 4x4 Hemi
99 Dodge Ram 1500 4x4 5.9
91 Dodge Ramcharger 4x4 318 ( restored)
69 B-Cuda FB 340 4bbl 904 323 8 3/4
67 B-Cuda NB 273 4bbl 904 323 8 3/4
66 Dart GT HT (Project car)
Lots of mopar parts.
barracudadave67 is offline
post #3 of 18 Old 11-18-2009, 09:49 PM Thread Starter
Harrison_Berger
Quoted: 2 Post(s)
Not the freeze plugs. According to the manual there is a bolt on each side of the block specifically for draining coolant.
I was thinking about flushing too, but I don't plan to dig in and take out the thermostat, so it would be pointless, right? I know I should, but this is sort of a band aid repair until I get everything amassed to do the plenum fix and all the little stuff that goes with that.
post #4 of 18 Old 11-18-2009, 10:16 PM
wes springer
wes springer's Avatar
umm i have never heard of a ''coolant drain plug'' on a motor, there are only freeze plugs, there is however a coolant drain plug on the bottom driverside of the radiator
new to mopar
new to dodgetalk.com forum
1996 Dodge Ram 2500 ex cab 4x4
408 cuin 46Re
4:10 gears, interior from a 2001 2500
spray in bed liner,soon to finish body work
5'' suspension and 3'' body
sitting on 42'' x 19'' x 15'' Mickey Thompson bajas
have a 1/4'' steel plate as a bumper right now b/c its deer season !!
otherwise its got the factory chrome
here chevy chevy chevy
wes springer is offline
post #5 of 18 Old 11-18-2009, 11:21 PM
waynebyrom
waynebyrom's Avatar
Yes, there is one. I just took mine out today for new antifreeze. Its on the drivers side betweeen the freeze plugs. Its a 9/16 bolt and you will probably need a small breaker bar to get it loose. I would take it out as long as it comes out fairly easy. It took about 75 pounds of torgue to get mine out. Take it out if you want to get all of the old antifreeze out.
Wayne
waynebyrom is offline
post #6 of 18 Old 11-19-2009, 12:05 AM
ramthisone
Dodge Aficianado
ramthisone's Avatar
There most certainly are drain plugs on each side of the engine, usually right above the oil pan mounting boss. They are usually a brass pipe plug. They drain the coolant out of the cavities that surround the cylinders.
I would definitely pull these out and drain all the old coolant. You can take a small brush and scrub the holes a bit to get the corrosion out, then with the plugs still out you can flush with some fresh water. Then let it all drain out, replace the plugs (maybe with some petcocks for the next time?) and refill with antifreeze mix. Done.
98' Ram 1500
4X4 Quad Cab Short Bed, 318 Auto, Magnaflow Catback,
Flowmaster 50-Series DOS, Truxedo Truxsport Tonneau Cover
1987 Buick Regal
Blue Metallic, built 350/TH350, dual Flowmasters,
Eibach Springs,GM F41 high performance suspension
Get in, Sit Down, Shut Up and Hold On!
ramthisone is offline
post #7 of 18 Old 11-19-2009, 12:38 PM
wes springer
ehh learn something new everyday, im new to the mopars
new to mopar
408 cuin 46Re
post #8 of 18 Old 11-19-2009, 12:52 PM
kevinb70
kevinb70's Avatar
i have a rubber plug in my 99. was leaky when i first got it and had to tighten it up a tad, so already knew about it.
if your going to use something like prestone super radiator flush, id back flush to help prevent ur heater core from clogging (if your system was dirty) id probably rid my air hose maybe at 20psi to give it more agitation (bubbles) and little more pressure but not too much air, might stress the gaskets
1999 Dodge Ram 1500 4x2 5.2L NV3500 Club Cab
in: sct by hemifever
-Upgrades waiting on their lazy owner to install: russell stainless lines, hawk ceramic pads, rotor, calipers, energy suspension master kit, derale 4000cfm dual fan kit, moog upper/lower ball joints
kevinb70 is offline
post #9 of 18 Old 11-19-2009, 04:46 PM
Raine883
i replaced mine when i rebuilt my engine, they were petty corroded but i replaced them with brass instead of galvanized steel and i probably wont worry about it for another 150k. But i just put a water hose in the lower hose on my jeep and ran the engine without a t-stat and let the water run out of the upper hose.
96 dodge ram 1500 Laramie Club cab 5.2
You can have my guns when you pry them from my cold dead hands-The Late Charlton Heston
-Speed Pro Flat top pistons .30 over
-Ported 52mm throttle body
-3 angle ported heads
-Ebay stainless shorty headers
-Custom off road y pipe
-Single 3 in Exhaust with delta 44 muffler
-Accel Coil
-Taylor 8.2mm wires
-crane timing chain adjusted +4 degree advance
-Hughes air gap
-24lb ford racing injectors
-Volant CAI
-transmission replace at 120k
-engine rebuilt at 120k
Stuff i need to install
SCT that im getting tuned when i get home
transgo jr
Richmond 3.92s
finned 24in. trans cooler
derale deep tranny pan
daystar spring spacers
moog springs
u-joints
ssbc front brake upgrade kit
msd streetfire
fabtech steering stabilizer
150 watt driving lights
KYB Excel-G shocks
Stainless Brake lines
Raine883 is offline
post #10 of 18 Old 11-19-2009, 06:10 PM
B-300
4 Wheel Power Disc Brakes
That rubber plug isn't OEM, it's a replacement for the front right freeze plug.
The drain plugs near the back of each bank of cylinders. They aren't bolts, they're 1/4"NPT plugs and if the coolant is flushed they won't corrode in.
Use pipe sealant on them rather than over torquing them and they will come out easy next time.
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #11 of 18 Old 11-19-2009, 06:40 PM Thread Starter
Harrison_Berger
Quoted: 2 Post(s)
The driver side one is behind the starter, so I didn't even bother. The other one was fairly easy to get to, but it wasn't budging even with a 2' breaker bar, and I wanted the swap to go smoothly(didn't want to risk breaking it), so I ended up leaving it too.
The thread wasn't a total loss though, those two guys found out about the drain plugs.
post #12 of 18 Old 11-19-2009, 07:03 PM
kevinb70
kevinb70's Avatar
can u guys see this pic? if not ill move it to photobucket.
and yes to above, going by the picture, it does look like oem would be brass/steel freeze plugs, and my rubber one is aftermarket replacement (dunno may vary by mfg year, I cant really read the plug to see if the mfg is an aftermarket name or not)
but i do like the convenience of the removable plugs, for flushing.
kevinb70 is offline
post #13 of 18 Old 11-21-2009, 11:50 AM
Ram lovr
Driven to perfection
Ram lovr's Avatar
Good info, learn something new all the time.
98 Ram 1500 4x4 Quad Cab Sport, 5.9L,
Rancho 3" lift, 285/75/16 Hankook Dynapro MT's on stock rims
Windecker Steering Stabilizer
Flowmaster Exhaust
Lund Sun visor
Sony Head Unit,MTX Sub Box, MTX RT 2100X Amp,Stock Infinity speakers
KC 6" Slimlites
Rebuilt Trans w-aftermarket cooler
Pilot Fog Lights
Black Truck Member # 164
Cracked Dash Member #31
Ram lovr is offline
post #14 of 18 Old 11-21-2009, 02:56 PM
kevinb70
kevinb70's Avatar
bah image got switched.
kevinb70 is offline
post #15 of 18 Old 11-21-2009, 10:01 PM
BIG_BAD_DODGE
BIG_BAD_DODGE's Avatar
this is a frost plug
BIG_BAD_DODGE is offline
post #16 of 18 Old 11-21-2009, 10:18 PM
spun360
spun360's Avatar
Quoted: 149 Post(s)
prestone flush is 75% glycol and 25% bs. use pyroil, in a little black pint. it packs a punch! run it for a week then drain. yes remove the block plugs. driver side is behind the starter which you will have to remove to get to. in the least remove the passenger and when you reinstall plugs, apply teflon or plumbers pipe dope to allow easy removal next time. yes they are hard to get out," a six sided socket only, so as not to round them off."
spun360 is offline
post #17 of 18 Old 11-22-2009, 03:49 PM
RamThis
RamThis's Avatar
Quoted: 2 Post(s)
With as many times as I've pulled the engine on my 96 you'd think I would have heard of this. I have a 360 hanging on the cherry picker in the garage Im gonna go look at those things!!!
2000 Dodge Ram 1500 Single Cab, 5.9 Auto, 4.10's, Auburn LSD, Edelbrock headers, 2.5" true duals with crossover, MSD Superconductors, APS Plenum Kit, Level10 Trans kit, Trans-Go shift kit, 2-4 BellTech Drop, SS/T rims, Toyo Proxes ST 285-60-17's, Sir Michaels Roll Pan and tailgate handle relocator, Keystone bumper cover with light openings, PIAA fogs, painted grille shell, painted Street Scene Speed Grille Inserts, SCT XCAL-2, Alpine head unit, Infinity Components front, Infinity Coaxials back, Infinity 500W 4 channel amp, Infinity Basslink, new dash, steering wheel, and guage bezel.
1996 Dodge Ram 1500 Club Cab, 5.9 Auto, 4.10's, Detroit Locker, Race Truck Trends Nascar Bumper, Painted SS/T Stripes, Alpine HU, Alpine Sound Field Processor, MTX Thunderform. 5.9L bored .030 over, Sealed Power coated pistons, balanced and polished crank, Comp 210 Cam, MP Timing Chain tensioner, Melling HV oil pump, 1.92 oversized valves and mild porting, Pacesetter Longtube Headers, FMS 24lb Injectors, Level10 Transmission kit, Trans-Go shift kit, 5 gear OD Planetary. Way more to come.
RamThis is offline
post #18 of 18 Old 11-22-2009, 08:14 PM
spun360
spun360's Avatar
Quoted: 149 Post(s)
the driver side is behind the starter and the pass is above and slightly forward of the engine mount, at least on my 96 360.
spun360 is offline
    4.7L Draining Coolant from the Engine Block ggravant 3G Dodge RAM - General Talk 6 06-05-2008 12:38 AM
    Draining tranny Rockin Kgin 2G Dodge RAM - Drivetrain Talk 1 10-31-2007 11:42 PM
    2000 Dodge Neon - coolant leak, rusty coolant dodgepodge Dodge Neon - General Talk 3 04-06-2007 02:22 PM
    Help....Q about draining coolant. pn2112 2G Dodge RAM - General Talk 7 08-06-2006 04:04 PM
