Way to disable Auto Locks? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 17 Old 11-14-2009, 02:10 PM Thread Starter
katrich
Is there a way to disable the feature that automatically locks the door after the car is started? I have a 04 Durango.
I live in Alaska and we frequently leave our cars running during the winter when it gets so cold. I have autostart but am having some trouble with it working. It clicks and the light of on the autostart lights up, but the car doesn't always start. Then sometimes when it does start the doors won't unlock (which isn't too bad because I can always unlock the door with the key).
It's getting -10 degrees and colder now and I would like to warm the car up before driving. I've already had one incident when I started the car up manually and left the passenger door crack just in case. Then a little later went to put something in on the passenger side and shut the door....and the doors locked with the key inside before I got to the driver's door. Not a good situation with a full tank of gas.
I know I probably need to replace the auto start key and get some more spare keys, but those are dealer items and cost $100+ and am short on funds now. So in the meantime, I really don't want my doors to lock automatically. I don't live in a high crime area and automatically looking doors are a safety hazard in the winter time when temps can get -50 periodically.
Thanks.
katrich is offline
post #2 of 17 Old 11-15-2009, 01:10 PM
08Durango
08Durango's Avatar
you may want to have a dealer look at this. the doors are not suppose to autolock until you are moving at like 5-10 mph.
2008 Durango (HEMI)
Black Mamba CIA Member #7
Westin bullbar with lights
Toyo R/t's 33x12.50r20
Liquid Metal Wingman 20's (Charcoal)
08Durango is offline
post #3 of 17 Old 11-15-2009, 01:13 PM
chad1972
chad1972's Avatar
x2,
hemifever tuned 2006 dakota 4.7, h.o.cams,180 stat, auburn lsd, richmond 4.10 gears, ported and polished 68.5mm t.b. magnaflow 3" exhaust.
Dodge Talk Central Florida Member #10
DODGETALK.COM 287 ENTHUSIAST MEMBER #318
chad1972 is offline
post #4 of 17 Old 11-15-2009, 09:12 PM
Sir_Eagle
Hemi User
Sir_Eagle's Avatar
Quoted: 1 Post(s)
Might have been different on the 04 but my 06 looks at 15 mph.
You can get a plain key cut anywhere just to open the doors.
'06 Durango SLT 4x4 / 5.7L Hemi / Tow Package
Drop in K&N Filter / Airaid Intake Tube / Breather Hose Filter / Rubber Flap Removed / Power Wire
OEM Running Boards / Bug Deflector / Side Window Air Deflectors / Molded Splash Guards
Ram Head Hitch Cover / 12" Black Stubbie Antenna / 20% Tinted Fronts
Resonator removed / Magnaflow 22" (12578)
265/70/17 General Grabber AT2 / Monroe Reflex Shocks / TB Lift(6 turns) / Drilled/Slotted Front Rotors
Sir_Eagle is offline
post #5 of 17 Old 11-16-2009, 11:51 AM
AK1
What! Me Worry?
AK1's Avatar
Quoted: 2 Post(s)
Thanks.
Autostart? Is that an aftermarket remote starter? If so then it could be interfering with the autolock circuit and causing the truck to lock on startup. Perhaps an installation issue?
Could you give me a step by step version of what you did?
This is what I'm getting;
1)You unlocked the truck using the unlock button on the key(factory key?)
2) you opened the passenger door, then started the truck.
3)Closed the passenger door, but didn't shut it completely.
4)Came back a bit later(truck's running), opened the passenger door, put something inside), closed the passenger door shut, and the truck locked.
Is that right?
I've never had my doors lock just by closing them. Mine lock after the truck gets to 15mph or so.
BLACK '04 Durango LTD
"Yeah, it's got a HEMI"
SPEED HAS NEVER KILLED ANYONE, SUDDENLY BECOMING STATIONARY, THAT'S WHAT GETS YOU!
Black Truck Club member #153 | DT Durango Club member #72|Hemi Club member #102
AK1 is offline
post #6 of 17 Old 11-16-2009, 12:29 PM
KC_Metal
Mopar Rules!!!!!!!!!!!!!!
KC_Metal's Avatar
Is that right?
X2! Mine locks after the vehicle starts moving.
2006 Chrysler 300 HEMI C 5.7L V8: (Summer Car)
- Hurst Comp stick kit & badge, Windows Tinted 15%.
2010 Avalanche LT 5.3L V8: (Wife's Truck)
- Windows Tinted 15%, 8 Bar 20's from California
2008 Chrysler 300 AWD Touring 3.5L V6: (Winter Car)
- Hurst Comp stick kit & badge, Windows Tinted 15% (soon)
Fu*k Toyota, Honda, Mitsubishi, Lexus and all that other Jap crap!
KC_Metal is offline
post #7 of 17 Old 11-16-2009, 12:29 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
Sounds like the autostart is an aftermarket and has a function to lock doors. Dodge never did this type of programming to lock doors at start up. My old Dakota w/ an aftermarket key fob would auto lock doors at startup, I had to disable it due to truck running and no one inside. 3 times, once w/ my sis-in-law borrowing truck and 300 miles away w/out spare key.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #8 of 17 Old 11-16-2009, 12:30 PM
KC_Metal
KC_Metal's Avatar
Damn! That must have sucked.
KC_Metal is offline
post #9 of 17 Old 11-16-2009, 12:31 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
they lost a 1/4 tank of gas waiting for AAA
dizzyD is offline
post #10 of 17 Old 11-16-2009, 12:32 PM
KC_Metal
KC_Metal's Avatar
Not too bad it could have been worse.
KC_Metal is offline
post #11 of 17 Old 11-16-2009, 12:57 PM
B-300
4 Wheel Power Disc Brakes
Does your truck have a trip/mileage center. If so put it in instantanious readout and see whether it shows above 0.0 mpg when stopped. I mention this becauase my parrents have an S-type Jaquar that will lock the doors on ocasion when the engine is running in park and I found the speed sensor would show the car as moving when stopped while driving it about 1 out of 10 stops. (Once is enough for the PCM to trigger the door locks and look you out.)
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #12 of 17 Old 11-16-2009, 08:01 PM
Sir_Eagle
Hemi User
Sir_Eagle's Avatar
Quoted: 1 Post(s)
Didn't even know this was possible.
post #13 of 17 Old 11-16-2009, 08:46 PM
matted2thefloor
matted2thefloor's Avatar
I've got the OverHead Console...but have never seen instant mpgs...
04 D 5.7 SLT AWD (hers)(gone 3/12)
99 Cobra (mine) SOLD
00 Toyota Camry
06 Toyota Avalon Limited (hers)
matted2thefloor is offline
post #14 of 17 Old 11-17-2009, 02:46 AM
App Dawg
App Dawg's Avatar
Dealers in Ak normally use aftermarket "Auto Start" systems as they offer more options that the stock version, such as turning on heated seats, etc. The one I got with my 04 could be programmed to open the doors, heated seats etc unless I paid a shop another $150 for it. The dealer had to replace a sensor and ended up my auto start to not properly work (alarm sounds when doors are locked and I use the autostart). I would take it to an aftermarket shop; may just be a wiring issue
Mods:
20x9 Wheels
275/55/20 Falken ST04
Putco Chrome Door Handles
Street Scene "Black Chrome" Grill
Painted Grill Surround
Resonator Chop
Hemi Badges
AEM "Brute Force" CAI
Wish List:
Black Wheels
Better Gas mileage
App Dawg is offline
post #15 of 17 Old 01-05-2010, 07:47 PM Thread Starter
katrich
Is that right?
Yes, the above is what happened and it is an aftermarket autostart. It locks without the car moving. It locks before my kids even get into the car if I have already started the car.
Is there a way to disable the autolock? Sorry for the delay in responding. I've been gone for a month and came back to a dead battery and a hood that won't open when pulling the the hood cable latch. But I'll ask for help in another thread.
Kathy
katrich is offline
post #16 of 17 Old 01-05-2010, 11:14 PM
AK1
What! Me Worry?
AK1's Avatar
Quoted: 2 Post(s)
You'll probably have to take it to the installer, they may be able to disable the auto lock feature.
AK1 is offline
post #17 of 17 Old 01-06-2010, 08:50 AM
KC_Metal
KC_Metal's Avatar
Is that right?
Kathy
Sucks your having some bad luck...WTF!
KC_Metal is offline
    How do I disable auto locks/2000 Dakota?? bkoltys 2G Dodge Dakota - Interior/Exterior 8 04-06-2006 03:31 AM
    Disable Auto Door Lock dnorto3 Dodge Caravan General Talk 10 08-30-2005 01:35 PM
    disable 01 auto door locks leen1 2G Dodge RAM - General Talk 2 01-05-2005 03:23 PM
    Door Auto Unlock - can't disable feature vegar 2G Dodge Durango General Talk 7 11-10-2004 01:41 AM
    Disable auto doorlock feature? MtnMan1 2G Dodge RAM - General Talk 3 09-08-2004 12:25 PM
