Thread Tools |
accelerator pedal position (app) sensor
- Posted: 11-05-2009, 05:14 PM
Post #1
Has anyone had to replace this sensor? I noticed my truck bogging down sometimes when I take off as well as it not shifting right (at least that's what it felt like). Hooked up a scanner and it this is what was flagged.
I was just curious if anyone has replaced this and what was the price. Also how difficult it was to replace. I'm pretty sure I know where it is, doesn't seem like a big deal. Do you think this would cause what I explained. also, i have adj pedals if that matters.
2004 QC Hemi SLT Sport 4X4 Altlantic Blue |
| Sponsored Links | |
Advertisement |
Posted: 11-05-2009, 05:17 PM
Post #2
Try recalibrating the throttle first.
'07 QCSB, Flame Red 5.7 4x4 SLT Performance: Internal: Custom Cam, 180 T-Stat - Intake: Ported Throttle Body, K&N Filter - Exhaust: Edelbrock Shorties, Magnaflow Y Pipe, Raceland Cutout, Dumped Gibson Catback Tuning & Monitoring: SuperChimps, Aeroforce Interceptor w/ afr Suspension & Tires: Lift: 6" Suspension, 3" Body Lift - Wheels: Custom Painted BMF S.O.T.A.s, 37" Trail Grapplers, Mopar Wheel Well Liners Appearance: Bed: Leer 100XQ Shell, Line-x XTRA, Defender Roof Rack - Other: SRT Hood, Bushwacker Pocket Flares,Tow Mirrors, Nerf Bars, 2500 Tow Hooks, Shorty Antenna, Tactical Grill AV: Tunes: Kenwood DDX512, Infinity Reference Speakers, Kicker 10" Sub, Kicker 400.1 Amp, FoxBox - Video: 10.4" TFT-LCD Flip-down Overhead Monitor, R Cam, Chuck Norris Kicked My Ass Lighting: Led Tails, Smoked Cab Lights, 4x VisionX 180w, Hella 500's
Posted: 11-05-2009, 08:29 PM
Post #3
I just had my teuck at the dealership today for the same issues. I have to replace the app sensor as well. I was told i need to replace the pedal assembly because the sensor is built into it. I also have adjustable pedals and the dealership quoted me at about $350. Im gonna be doing it myself. My uncle replaced one before and said it was easy.
2003 Dodge Ram 1500 5.7L V8 HEMI Laramie Quad cab Pro Comp leveling kit 17" Mamba wheels BF Goodrich All-Terrain t/a 315/70/17 Gibson Dual Extreme exhaust CAI, Superchip Programer |
Posted: 11-05-2009, 08:36 PM
Post #4
What Frog said....try recalibrating the pedal first before you do anything else.....the procedure should be in your owners manual.
Jeff |
Posted: 11-05-2009, 10:53 PM
Post #5
good luck
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, SRT CAM, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstars, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded. ![]()
Posted: 11-06-2009, 06:24 AM
Post #6
I was just searching through the manual and it said the sensor is located under the battery tray. Exactly where we thought it was. I'm not sure why you would have to replace the entire pedal assy.
I'm going to try and recalibrate it first. Once I figure out how. If that doesn't work, I'll be replacing just the sensor, not the entire assy. Thoughts.
Posted: 11-06-2009, 08:41 AM
Post #7
Well the dealership told me you had to replace the entire petal assembly, and they wouldnt lie to me...lol. I did some reading as well and i didnt see anything that said replace the pedal assembly. Ill be heading to the auto store now and working on this tomorrow.
Posted: 11-06-2009, 08:43 AM
Post #8
Thor,
Let me know what you find out. Any idea of how to recalibrate the pedal?
Posted: 11-06-2009, 08:44 AM
Post #9
FYI...recalibration did not work for me
Post #10
The process for recalibrating the pedal should be in your owners manual.
Jeff |
Posted: 11-06-2009, 08:47 AM
Post #11
Jeff,
I looked through the manual and didn't see anything. Not saying it's not in there, just didn't see it. Any idea what section it's in?
Posted: 11-06-2009, 08:56 AM
Post #12
I do not have the fly by wire throttle....so I do not know where it is in the manual. If you still have trouble finding it, let me know and I will check the service manual.
Jeff |
Posted: 11-06-2009, 10:53 AM
Post #13
I found this while searching the froum. Its what i tried.
"The code said you need to change the sensor? Try this. Disconnect batterys for 20 min. Reconnect. Turn the key on but do not start, slowly mash down on the accelerator till it hits the floor then slowly let up, turn key off. Crank and drive and see if there is a difference. This will reset the APPS." I just got back from autozone and they told me that the APPS is only available through the dealer. I called them and it runs $265
Posted: 11-06-2009, 11:13 AM
Post #14
Yeah I've tried that before. Everything but the battery disc. I'll try that when I get home. Cheaper than $200+
Posted: 11-06-2009, 11:18 AM
Post #15
Thor,
Just wondering what your truck was doing, symptoms wise?
Posted: 11-06-2009, 11:27 AM
Post #16
I have been experiencing some acceleration issues. Sometimes when I go to get on the gas to pass someone or take off I get no response. It would take a awhile for it to respond. Mainly it happens when i am already moving and try to accelerate.
| Thread Tools | |
| accel pedal position sensor? | TAZ4X4 | 2G Dodge Ram Diesel Talk | 25 | 05-07-2009 07:45 PM |
| accelerator pedal position sensor (apps) (or throttle position sensor - TPS) | FatBull | 2G Dodge Ram Diesel Talk | 2 | 03-24-2008 10:41 PM |
| Accelerator pedal travel | Budd | 2G Dodge RAM - General Talk | 1 | 09-21-2007 02:10 AM |
| pedal position sensor? (murrays and autozone were no help) | MLL5000 | 2G Dodge RAM - General Talk | 3 | 01-03-2004 11:22 PM |
| Play in accelerator pedal | JRosenberg | 3G Dodge RAM - General Talk | 3 | 09-18-2003 07:10 AM |
Privacy Statement | |
