88 odge tbi, fuel pump not running... is there a relay or fusable link for it. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 11-04-2009, 07:57 PM Thread Starter
power ram
power ram's Avatar
ok i finaly got my ignition box wiried up, it has spark.. but i go to start it and no fuel, i checked the fuse box. it must have a relay or fusable link for the fuel pump.. i cant find it thou.. anyone have a wiring diagram or know where to find a fusable link or relay for the pump...
1988 dodge ram 4x4
1991 dodge ram 2wd
power ram is offline
post #2 of 11 Old 11-04-2009, 09:19 PM
dodge88
dodge88's Avatar
It is one of those on the drivers side inner fender.
I think it is the smaller one,maybe the second one from the front(should be a 4 wire).
If you have a spare pair of hands,have them turn on the ignition and feel if the relay is kicking,if not,use a test light and look for the 12volt lead and use a jumper to the opposite wire and see if the pump kicks,if yes new relay.
dodge88 is offline
post #3 of 11 Old 11-04-2009, 09:27 PM Thread Starter
power ram
power ram's Avatar
thanks, i knew you would know..
1988 dodge ram 4x4
1991 dodge ram 2wd
post #4 of 11 Old 11-04-2009, 09:29 PM
dodge88
dodge88's Avatar
I am not that smart,I am guessing.
If no results,we will try other things.
dodge88 is offline
post #5 of 11 Old 11-04-2009, 09:34 PM Thread Starter
power ram
power ram's Avatar
i just tried it, i felt it kick.. and i heard it click.. what now, the fuel pump
1988 dodge ram 4x4
1991 dodge ram 2wd
post #6 of 11 Old 11-04-2009, 09:36 PM Thread Starter
power ram
power ram's Avatar
ok, so if the relay is working.. what should i try next, could the fuel pump just quit, without a sighn.
1988 dodge ram 4x4
1991 dodge ram 2wd
post #7 of 11 Old 11-04-2009, 09:39 PM Thread Starter
power ram
power ram's Avatar
o ya and it ant shooting any codes..
1988 dodge ram 4x4
1991 dodge ram 2wd
post #8 of 11 Old 11-04-2009, 09:41 PM
dodge88
dodge88's Avatar
Next,check for voltage at the pump,check for a good ground.
if you have a long enough piece of wire,run a jumper straight to the pump( hate to say it but you might have to lift that side of the bed to get to it),if it kicks,bad wire someplace,if not,a pump.
dodge88 is offline
post #9 of 11 Old 11-04-2009, 09:42 PM Thread Starter
power ram
power ram's Avatar
do you know where i could find out if there is a fusable link in the line, or do i need to trace the wire..
1988 dodge ram 4x4
1991 dodge ram 2wd
post #10 of 11 Old 11-04-2009, 09:55 PM
dodge88
dodge88's Avatar
There should be fusable links in the harness at those relays.
dodge88 is offline
post #11 of 11 Old 11-05-2009, 01:09 AM Thread Starter
power ram
power ram's Avatar
well i tried a jump wire and the pump did not turn on, then i tried taking three jump wires from the power sorce to all the wires that would come into the relay.. now something blew, i got no power at that relay at all.. all my fuses are good. it aint shooting any codes. i just dont know where to go next..
1988 dodge ram 4x4
1991 dodge ram 2wd
    fuel pump relay c696 Dodge Caravan General Talk 1 06-29-2008 09:39 PM
    Fuel pump relay is getting hot dogguy 2G Dodge Dakota General Talk 1 01-20-2008 05:36 PM
    Need Some Help, Possible Fuel Pump or Relay djawor Dodge Ram Truck 1st Gen (88 - 93) Forum 5 06-10-2007 06:49 AM
    94 RAM 250 where is asd relay and fuel pump relay KHB1 2G Dodge RAM - General Talk 0 11-07-2006 02:15 PM
    Fuel pump relay help? 99sliverram 2G Dodge RAM - General Talk 0 09-24-2006 03:06 PM
