Installed - 2.5" Daystar Leveling Lift Kit on a 03 Dodge Ram 1500 2WD - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 41 Old 11-04-2009, 11:04 AM Thread Starter
Top Gun Customz
Top Gun Customz's Avatar
We just finished installing a Daystar 2.5" Leveling Lift Kit on a 2003 Dodge Ram 1500 2WD.
This spacer installs on the top of the front coil spring and bolts back up. No cutting or drilling required.
Kit Benefits:
+Increases vehicle height
Improves ground clearance
Requires no welding or drilling
Includes detailed Instructions
Installed Components:
If you have any questions about this kit or the components used, please feel free to contact us Toll Free at 1-877-274-9362. You can also e-mail us at salesstaff@topguncustomz.com
If you would like to know more about any of the components installed check out our Top Gun Customz Store for these very products!
Supporting Vendor
We Pride Ourselves on Customer Service and Customer Satisfaction.
Give us a call at (865) 681-3008
Top Gun Customz is offline
post #2 of 41 Old 11-04-2009, 11:44 AM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
I have the Daystar 2.5 and have no complaints, good product for the price and ease of install.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #3 of 41 Old 11-05-2009, 07:23 AM
DeMoN-HeMi
NEVER DOUBT THE DEMON
DeMoN-HeMi's Avatar
Quoted: 1 Post(s)
how big of one could i put on my 03 reg cab with 3" lift spindles?
Official DodgeTalk Lighting/Wiring Expert & Retired Moderator- Daniel
2003 1500 HEMI QC -Slammed and Sprayed,
2014 Ram 1500 Black on Black Edition HEMI! - The hauler
2013 Charger - The Toy
1995 Camaro - The Project
"Dont Spread my Wealth, Spread my Work Ethic!"
"Debt is normal, be WEIRD" - Dave Ramsey
DeMoN-HeMi is offline
post #4 of 41 Old 11-05-2009, 08:44 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
4" Demon, trust me, I know. :-)
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #5 of 41 Old 11-05-2009, 10:31 AM Thread Starter
Top Gun Customz
With your current suspension lift (Spindles) theoretically you could run a small spacer. HOWEVER I personally do not recall the outcome in the recent past of us installing a setup like that and can not advocate that running anything larger than 1.5" would not adjust other things. Such as your steering angles.
Supporting Vendor
post #6 of 41 Old 11-05-2009, 12:20 PM
DeMoN-HeMi
DeMoN-HeMi's Avatar
Quoted: 1 Post(s)
im not worried about having to realign it, so you think a 3" would make it where something wont work?
post #7 of 41 Old 11-05-2009, 12:33 PM Thread Starter
Top Gun Customz
Correct me if i'm wrong but are you saying you want to put a 3" spacer ontop of your existing 3" spindle system?
Supporting Vendor
post #8 of 41 Old 11-05-2009, 01:22 PM
DeMoN-HeMi
DeMoN-HeMi's Avatar
Quoted: 1 Post(s)
a 3" spacer on the spring yeah
post #9 of 41 Old 11-05-2009, 02:51 PM Thread Starter
Top Gun Customz
You should have no problem running the 3" spacers. HOWEVER I do not know how that will effect your steering angles.
Bare in mind though, we recommend when purchasing any spacers over the size of 2.5" you STRONGLY consider upgrading your shocks. with the newly added height you have a very good chance of topping out your stock shocks.
Supporting Vendor
post #10 of 41 Old 11-05-2009, 03:11 PM
oefootball_70
oefootball_70's Avatar
Is there such a thing as 3+ inch spacer? I haven't seen one...
03 Ford Expedition 5.4 V8 4x4
oefootball_70 is offline
post #11 of 41 Old 11-05-2009, 03:56 PM
sleblanc
sleblanc's Avatar
Quoted: 2 Post(s)
it would be like running the old rough country kit before the crossmembers demon you could run that 2.5 in there and be good to go or 3inch springs, or 3inch cst spacers
Current: 2012 2500 6.7 4x4
2009 CHEVY 2500HD WHITE 6.0 CREW CAB SHORT BED Z71
2006 4x2 white qc big horn hemi lots of mods
sleblanc is offline
post #12 of 41 Old 11-05-2009, 04:59 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
3" is max b4 uca starts riding/touching the upper coil bucket in full extension. 2.5 is just right.
dizzyD is offline
post #13 of 41 Old 11-06-2009, 06:39 PM
polcat
polcat's Avatar
And just right before I install the 2.5" Daystar tomorrow on my 02 Quad Cab 2wd metallic grey truck. I've been looking for a pic just like this. I did find one (don't recall whose truck it was blue with silver). Although, I don't have a tool box, but I do have crome bug deflector and tow mirrors. I'm getting new shoes as well, nothing special. And, installing bilstein shocks all around. Can't wait! I'll have to post pics as well.
2013 Ram 2500 Laramie Mega Cab
Sold: 2002 Dodge 1500 SLT Quad Cab
polcat is offline
post #14 of 41 Old 11-08-2009, 09:29 AM
MH_MOTORCYCLE
5.9 Vroom..putt..putt..
MH_MOTORCYCLE's Avatar
what shocks would you recommend, I may be going this route with some 33" tires
Ol Whitey...02 QC 360
2/4.5 Drop, Toxic Shocks up front, Cheapo Monroes out back, Stock
MH_MOTORCYCLE is offline
post #15 of 41 Old 11-08-2009, 10:35 AM
The Bull
The Bull's Avatar
Polcat remember to post pics i have all the parts ready just got to get it done i also have a 02 metallic gray
2002 Ram 1500 Sport 5.9L 2WD Quad Cab Short Bed
Mods: Daystar 2.5 Level|Cooper Zeon LTZ 275/60/20's|CAI|Helix Power Tower|Jet Chip|3.92 Gears|3" SI/DO Exhaust|LED Interior Lights|KC's behind the grill 150w|KC Reverse Lights 100w|Fog Light Jumper|DMH E-Cutout|
Train Horn: Tripple Horn| Viair 450C| 3 gal Tank|
Mother Earth Raping Big Truck Club # 60
100,000 Mile+ Club # 13
3rd Gen 360 5.9 Club Member #5
Light Addicts Anonymous # 388
Train Horn Club # 38
Spending money I don't have, to buy parts I don't need, to impress people I don't know!" - Grumpy Jenkins
The Bull is offline
post #16 of 41 Old 11-08-2009, 02:05 PM
polcat
polcat's Avatar
You guys will have to wait. The place I took it into is only open 4 hours on Saturday and since they had to finish a truck leftover from Friday, they would've not been able to do everything on my truck I wanted. I'd rather do the tires, shocks, and level kit at the same time. I'll try to get it done in a week once I get back from a trip.
polcat is offline
post #17 of 41 Old 11-09-2009, 10:51 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Dizzy, Im going to have to disagree with you on this one bro. As you all know Ive got my RC 3" spindles. Some of you who keep up know I did my 3" CST springs also. But what few know is that I still have my spring isolator (on the bottom now of the spring) and a 1" spacer on the top. So you can count that as a 3" spindle lift and a 4" additional lift. My UCA doesnt hit. However I do need to get pics so everyone can see where I am at. IDK tho, maybe my 36s have something to do with it.
Next projects:
- Custom CAI
weedahoe is offline
post #18 of 41 Old 11-09-2009, 05:58 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Next projects:
- Custom CAI
weedahoe is offline
post #19 of 41 Old 11-09-2009, 09:04 PM
sleblanc
sleblanc's Avatar
Quoted: 2 Post(s)
i am tired of this guys i see what your running and your not looking to hot man that ball joint is going to break and leave you upside down on the side of the rd waiting on my ambulance to come and get ya. the way is works is a 3inch spring is not as tall as a 3inch spacer because the spring is using stiffness to make a bit more lift. a 2inch spacer ontop a stock spring and a 3inch spring next to each other are the same height but your going to get more lift with the spring. now with a 3inch spacer its having to use height to make the lift meaning your going to have less room in there for movement.
and for everyones the reason the older style rough country lift with the 3inch spindle and 3 inch spring is not made anymore is because it was making the balljoints on the trucks stay at such an extreme angle like seen above that they were snapping off and causeing some serious injurys and risk......
WHERE IS SLAMMED1 TO BACK ME ON THIS SUBJECT WHEN I NEED HIM.
sleblanc is offline
post #20 of 41 Old 11-10-2009, 06:17 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I understand what you are saying and Im not trying to argue. The only thing I was was there is enough room to do it. IDK about older RC lifts. I do know CST uses spindles and 3" spacers on thiers but CST also has 3" springs for the QCs. To my knowledge, RC is the only one who has drop X-members. The springs i am using are HERE and here is something from thier site.
Please note, this item is NOT designed for use on Standard Cab V6 eqiupped trucks. Quad Cab trucks equipped with the heavier 5.7L V8 Hemi engine will only achieve approximately 2" inches of lift over stock height!
With that being said, this is only a leveling kit so to speak. And if thats the case (because lift spindles have nothing to do with springs), we all are in trouble for those who level by lifting the front instead of droppin the rear.
Next projects:
- Custom CAI
weedahoe is offline
    Installed - 2.5" Top Gun Customz Leveling Lift Spacer Kit on a 09 Dodge Ram 1500 4x4 Top Gun Customz 4G Dodge RAM - 4X4 Talk 25 12-03-2009 09:20 AM
    Installed - Top Gun Customz Torsion Key Leveling Lift Kit on a 04 Dodge Ram 1500 4x4 Top Gun Customz 3G Dodge RAM - 4X4 Talk 2 09-16-2009 07:23 PM
    Where to find a Dodge Ram 1500 2WD 2" Front Leveling Kit? W0rLDWaR4 3G Dodge RAM - General Talk 2 12-28-2008 09:58 AM
