2004 Ram 1500 4x4 Multiple cylinder misfire. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 21 Old 11-03-2009, 09:59 AM Thread Starter
sperry
I have a 2004 Ram 1500 4x4 5.7L. I was driving and the engine started cutting out real bad. It will not idle at all. You have to keep the throttle 1/2 pressed to keep it running. I have had some different codes. Orig. I was getting a multiple cylinder misfire. cylinders 1,2 and 3. I replaces coil on #1 cylinder. Did not seem to help. It tripped a new code last night. P2323 Ignition coil #8 secondary circuit/insufficiant ionization. It kiked out the same code for Cylinder #6,5 and 1 also. Total of four cylinders. I was told by a mechanic that I needed to replace the coils on those four cylinders. The problem I have is that Cylinder #1 has a new coil on it. Could these codes be related to the secondary spark plug? I am about at my witts end with this thing. Does anyone have any suggestions? Thanks!!
sperry is offline
post #2 of 21 Old 11-04-2009, 05:51 PM
hilljack
hilljack's Avatar
Quoted: 5 Post(s)
How many miles are on the engine/spark plugs? What kind of spark plugs are you using?
2005 QC 1500 4x4 Hemi
3.55 gears
Now 4.56 gears
285/70/17
hilljack is offline
post #3 of 21 Old 11-04-2009, 07:19 PM
07quad
07quad's Avatar
Coils don't usually go bad in multiples like you have. I would check the plugs first, for good maintenance at least, but it sounds like you may have a wiring problem. all the coils share 1 wire, you will notice if you check a coil connector, all have a common coloured wire. It is possible that there is a bad spot in the wiring somewhere.
2007 Ram 1500 QC 4X4
Patriot Blue
325/60R20 BFG all terrains on mopar wheels
levelled with Bilsteins
3" PA body lift
Magnaflow exhaust
Hella's behind the grille
Blue Truck Club member #136
1998 ram 1500 4x4
318 auto
hole in lf fender
38's jammed in stock tearing fenders apart as I turn
waiting to be lifted,dovetailed,shortened and beaten
" having an import that can run 11's...is kinda like coming out of the closet....your going to suprise a lot of people....but in the end your still gay"
07quad is offline
post #4 of 21 Old 11-04-2009, 08:34 PM
crasher76
Im wired!!!
crasher76's Avatar
4 to go out at the same time ya right, sounds like your pcm is cooked.
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, 260 cam, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstar ultras, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Rebuilt front suspension, Ditched Sway Bar, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
crasher76 is offline
post #5 of 21 Old 11-04-2009, 09:09 PM Thread Starter
sperry
I have 86,000 miles on it. I put new champion spark plugs in it which I purchased from the Dodge dealer. Tonight I replace the coils on Cylinders 6,8 and 5. That makes a total of four coils that I have replaced. I had already put a new one on Cylinder 1. That did not make any difference. I was going to pick up a set of Plug wires tomorrow and try that. I will look into the common wire. I t looks like it will be hard to trace since they are all wrapped up. Thanks for the info. If you think of anything else I am open to any sugestions. It has been down for a month now. I am getting quite discouraged.
sperry is offline
post #6 of 21 Old 11-04-2009, 10:40 PM
thoesli
Hoesli
thoesli's Avatar
The Champions are the problem. I wouldnt use them in anything. I had a buddy that had one explode on him while he was driving by my house. Sounded like a shot gun going off. Swap the plugs for a set of NGK's or Nippion. That would be alot cheaper than one coil.
2005 Ram 1500 Quad Cab 4x4, Patriot Blue, Cold Air, Flowmaster dual exaust, BFG M/T, home made front tow hooks, A-piller tripple gauge pod, Powerslot rotors and hawk pads, and Bilstein 5125 shocks, Hella's behind the grill Newest install: Hypertech tune, rear LED bar, tinted front windows & latest.....PAID OFF YA HOO FREE AND CLEAR...more to come later (of course).
thoesli is offline
post #7 of 21 Old 11-05-2009, 03:10 AM
crasher76
Im wired!!!
crasher76's Avatar
the wires aint gunna do you no good, pick up the pcm from a bone yard and start there
post #8 of 21 Old 11-05-2009, 06:37 AM
07quad
07quad's Avatar
The champions aren't the problem, thats whats in the truck from factory and one plug exploding doesn't make them a problem, especially when there are millions on the road with no problem. get a wiring diagram and check your wiring. it is possible that the pcm is the problem as well.
Patriot Blue
3" PA body lift
Magnaflow exhaust
1998 ram 1500 4x4
318 auto
hole in lf fender
07quad is offline
post #9 of 21 Old 11-05-2009, 08:16 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Id love to hear how a plug explodes.
And as was said before, Champs come stock and Im riding on them now.
Here is something good to hear though. When I did my 5.7 to 6.1 conversion, all I did was replace the VCs, put the coil packs on top and wire them up. For those that dont know, there are only two wires. However, this kit was BNIB and after all was said and done with, every so often I will get those same codes on cyl 1-3-5. Now I never got a code before so IM SURE its NOT my PCM. However, this kit was BNIB. My plugs were replaced just a few thousand miles back.
So anyone care to explain this? It never misses. I run it hard and it never sputters. You want my opinion? Go check the plug connections on the coils and make sure they are good. Pull the coil pack and reseat it on the plug tips. I havent gotten a chance to get into mine yet but what else could it be right? Everything on mine is all brand new.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #10 of 21 Old 11-05-2009, 07:42 PM Thread Starter
sperry
I am looking for a PCM. Are these all the same for the 5.7L or does it have to be the exact same options as my truck? I had someone tell me today to check for a leak in the intake gasket. Could a intake gasket cause it to run ths bad?
sperry is offline
post #11 of 21 Old 11-05-2009, 08:18 PM
wilbrakloose
paul
wilbrakloose's Avatar
the PCM is not the same for all 5.7 make sure you get the same part#
a leak in the intake will cause it to run bad but not all does misfires
04 black 4x4 QC, Superchips, comp 260 cam, home ported heads -0.020, 6.1 springs & pushrods, Edelbrock TES heders, Innovate LC1, E fan, K&N air intake, Tylor T50 wires, 180* T stat, true duals with Bassani.
Double din Kenwood DNX7100, 80 Gb hard drive, R.camera, Precision Power DCX1500.1 2x 10" RE SE, powered by a Phoenix gold Tantrum 600.4 on dash 4.5" diamond audio on back doors RF Fanatics, powered by a Orion Extreme 500.4 on front doors Orion HCCA 6S comp.
wilbrakloose is offline
post #12 of 21 Old 11-06-2009, 12:23 AM
crasher76
Im wired!!!
crasher76's Avatar
is there a pcm update to run that configeration??
post #13 of 21 Old 11-06-2009, 02:57 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I would say no. I dont think it has to do with the PCM or else it would be on all cyl and not just 2 or 3
Next projects:
- Custom CAI
weedahoe is offline
post #14 of 21 Old 11-12-2009, 06:18 PM Thread Starter
sperry
OK, I have replaced the plug wires. I did not expect it to work but with 85,000 miles it could not hurt. Today I received a different PCM. Yes the part number is exactly the same. It did not fix it. I am still open to any suggestions. Please help!!!!! I do not know what else to do. I have looked for a bare wire but have not found anything yet.
sperry is offline
post #15 of 21 Old 11-12-2009, 07:46 PM
hilljack
hilljack's Avatar
Quoted: 5 Post(s)
Bummer.
Hate to rathole on the spark plugs, but what gap are you running on the plugs?
3.55 gears
Now 4.56 gears
285/70/17
hilljack is offline
post #16 of 21 Old 11-12-2009, 09:23 PM Thread Starter
sperry
I gapped them at .045, the orig. tag was missing. I looked this up on the internet.
sperry is offline
post #17 of 21 Old 11-13-2009, 07:49 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I never thought it was the PCM anyway. I hope it wasnt costly. Make sure you read my post 9 and you will see why I didnt think it was the PCM. Anyay, since you are having cyl 6-5-1 throwing those codes, take those coils out and swap them on different cylinders (ex. 2-3-4) and clear the codes. Then go drive it a while and see if the codes come back and what cyl they are on. Will it be 6-5-1 or 2-3-4?
See what Im saying?
Next projects:
- Custom CAI
weedahoe is offline
post #18 of 21 Old 11-13-2009, 09:07 AM
Drew05
Drew05's Avatar
Have you checked your PCM grounds for good continuity/low resistance?
2005 Ram Hemi Sport 5.7l 4x4 Quad Cap SLT - mostly stock
Mods: Mopar CAI, Flowmaster 40 3"in/2.5"x2 out dumped before rear axle, Ryno lined Bed.
Other: Valantine 1 with hidaway display
Mods I plan on: Superchips flash
2005 SRT4 2.5l - FWD drag car - 676 whp & 776 wtq (boost only w/o n2o and ligher tune) - mods too many to list - 2010 goal 10.4 ET or bust
Drew05 is offline
post #19 of 21 Old 11-13-2009, 09:19 AM
wilbrakloose
paul
All I can think of is the crank position sensor or timing gear.
Also check the harness on the right side that rests on top of the Valve covers, it rubs quite a bit there
post #20 of 21 Old 11-13-2009, 09:39 AM
chefred112
Valdez Racing Team
chefred112's Avatar
Quoted: 58 Post(s)
this week a friend's truck all of a sudden started to run bad and he also couldn't keep it idling with out him holdin the gas peddle down...threw the p0300 multiple misfire also...when I arrived we started re-setting everything (battery, pcm, tuner) and still ran bad an couldn't hold idle. I could hear some clacking in the passenger valve train and decided to pull the valve cover. We found the #3 exhaust spring broken....
05 Ram 1500 QC 5.7 (stroked 6.4 as of 7/14)
Inertia Motorsports Stroker Assy/Custom Tuned
best 1/4 (5.7 nitrous): 12.10 @ 113
best 1/4 (5.7 na): 12.96 @ 104 (cold day)
best 1/4 (6.4 na): 12.54 @ 107 (hot day)
over 300k miles on block
chefred112 is offline
    multiple cylinder misfire, need help DurangoSLT99 1G Dodge Durango General Talk 0 05-26-2009 03:10 PM
    97 neon code 43 multiple cylinder misfire 2.0 sohc trikeusa Dodge Neon - General Talk 5 09-10-2006 09:01 PM
    P0300 Multiple Cylinder Misfire GoldFinger99 2G Dodge Intrepid - Performance Talk 3 09-21-2005 10:13 AM
    P0300 Random/Multiple Cylinder Misfire Detected mmastinRT 1G Dodge Durango General Talk 2 11-16-2004 01:47 AM
