2004 Ram 1500 4.7V8 engine/oil prob - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 19 Old 10-20-2009, 11:08 AM Thread Starter
PhoenixMopar
Unhappy 2004 Ram 1500 4.7V8 engine/oil prob
[F][/FONT]2004 Ram 1500 4.7V8 stick shift
A few days ago I was driving along and the oil pressure gauge started dropping to nothing and coming back up. Sometimes it would be for just a second, sometimes for several minutes, sometimes longer, etc. Every time the gauge dropped the "check gauges" light would come on. Checked the oil and it's still full. I know I'm due for an oil change. Engine never over-heated, and I heard no other sounds suggesting engine problems so I figured it was a bad connection on the gauge itself.
This weekend on a 2-hour trip the engine began to sound like it was either dry or not getting oil. Sound got progressively worse over the last 5 miles, and louder at higher rpms.
Has anyone encountered this problem before or know what it might be?
Could it be the oil pump going out or the screen clogged up?
I already had to shell out $100 for a diagnostic at the Dodge house where the problems culminated but they couldn't figure it out and now they want $500 more to "tear it down to find the problem."
Any help is greatly appreciated...
PhoenixMopar is offline
post #2 of 19 Old 10-20-2009, 11:43 AM
stricnine
RANGO
If you have an 04 you should still be under powertrain warranty shouldn't you? Why would they charge you $500.00 to figure out what a problem is. Something doesn't sound right.....
stricnine is offline
post #3 of 19 Old 10-20-2009, 11:43 AM
mopar_57
Check the oil, make sure its full? I had this happen to mine, all I did was change the oil and everything work again.
mopar_57 is offline
post #4 of 19 Old 10-20-2009, 07:59 PM
07quad
07quad's Avatar
Could be just a oil pressure switch problem, they are not made of quality.
2007 Ram 1500 QC 4X4
Patriot Blue
325/60R20 BFG all terrains on mopar wheels
levelled with Bilsteins
3" PA body lift
Magnaflow exhaust
Hella's behind the grille
Blue Truck Club member #136
1998 ram 1500 4x4
318 auto
hole in lf fender
38's jammed in stock tearing fenders apart as I turn
waiting to be lifted,dovetailed,shortened and beaten
" having an import that can run 11's...is kinda like coming out of the closet....your going to suprise a lot of people....but in the end your still gay"
07quad is offline
post #5 of 19 Old 10-20-2009, 09:42 PM
crasher76
Im wired!!!
crasher76's Avatar
oil
Who does your oil changes and what weight you running, what brand filter?
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, 260 cam, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstar ultras, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Rebuilt front suspension, Ditched Sway Bar, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
crasher76 is offline
post #6 of 19 Old 10-23-2009, 09:07 AM Thread Starter
PhoenixMopar
I'm using 5w-30 and fram filters. I've always done my own oil changes with the exception of this last time. Just never can fully trust a shop. I always use synthetic but I don't know what they used. It was a Goodyear shop if they have a company-wide policy. When this started and I checked the oil I tried to open the oil cap just in case and neither I nor my father could get it to budge... Does Goodyear use torque specs to put it back on?
I bought it used so the warranty has been up for just short of a year.
I've got the truck back and I'm going to change the oil and filter, run it for a bit, then change it again. Hopefully it's just sludge and the first oil change will help clean the gunk off all the walls... (had to take off the air filter housing and use a pair of vice grips to get the oil cap off)
post #7 of 19 Old 10-23-2009, 09:37 AM
BigHemiTex
Tex
BigHemiTex's Avatar
could be your oil pump starting to fail
2003 Hemi + Mods
BigHemiTex is offline
post #8 of 19 Old 10-23-2009, 10:09 AM
greenshovel
So Mote It Be !!!
greenshovel's Avatar
Oil pump, I had this on my second gen ram. Took it to the dealership, they replace the sending unit, sent me on my way. Still did it, they then replaced the switch, still did it....Then the engine started to make the noise your describing, crank bearings shot due to bad oil pump.
The dodge stealership actually replaced the whole motor for free, after corporate got involved....Long story
Good luck with this.....
Steve ستيف
Member #64 "Mineral Gray Metallic Clear Coat"
Retired Combat Engineer-Regular Army
2008 Lone Star RAM 4X4 - T/G Level kit - 3" PA Body Lift - Line-X XTR in bed - OEM Nerf bars - OEM Wheel Well Liners - Micky Thompson Classics II - 17x9 - LT315/70R17 BF Goodrich - K&N Air Filter - Superchips Flashpaq Tuner 3865 - Flowmaster 50 Series Cat Back - Warn Fender Flares W/Line-X Xtra - 4.56 gears - Detroit TrueTrac -
Sig pic provided by - BMRbrnSNRbrd - Thanks Dave
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, and loudly proclaiming, 'Wow, what a ride....................So Mote It Be!!....o~`o..!'"
greenshovel is offline
post #9 of 19 Old 10-23-2009, 01:54 PM
crasher76
Im wired!!!
crasher76's Avatar
Sounds like a new motor is in your trucks near future.
post #10 of 19 Old 10-23-2009, 05:58 PM Thread Starter
PhoenixMopar
Well I changed the oil a couple of times and ran some engine flush through it both times... no real change.
Tommorow gonna drop the oil pan and check the screen, filter and pump itself.
In the back of my mind I've been thinking it may be the pump, but if it was going bad would it not just die instead of going out then coming back on like it has been?
post #11 of 19 Old 10-23-2009, 06:06 PM
greenshovel
So Mote It Be !!!
Nope, mine did exactly like yours is doing. Good to go drop to nothing bounce a bit back to normal....Could stay normal for an hour then drop to zero whenever, no method to it's madness.
Steve ستيف
post #12 of 19 Old 10-23-2009, 07:24 PM
chambers
sub'd, good luck it sounds like the oil pump considering Steve's experience in which he had the same symptoms.
3.7L Powertech Club Member #12
Mods:
SCT tuned by hemifever
True Flow intake w/ AEM dryflow filter
ASP underdrive pulley
Taurus e-fan
Magnaflow muffler dual-in single-out (factory y gone)
Jet stream scoop
jba titanium ceramic headers
Fastman ported TB
Line-x bedliner, rocker panels, and tailgate
Hellwig anti-sway bar
chambers is offline
post #13 of 19 Old 10-24-2009, 05:17 AM
crasher76
Im wired!!!
crasher76's Avatar
Good luck!
post #14 of 19 Old 12-11-2009, 10:54 PM
mailiboy
had same problem on my 04 ram, drop oil pan. full of slug, also removed pick up tube and cleaned. did't have a problem after. switched to sinthetic oil. about 1 1/2 year later started again. droped pan and found pick up tube cloged, but no slug this time. it was all the crap that was left by slug problem. was easy fix. been about 6 months now and no problems.
mailiboy is offline
post #15 of 19 Old 12-12-2009, 12:34 AM
speedy81304
if you lost oil pressure for more then a couple secs. the damage is already done. and you say you would drive it for mins even longer. and it making a noise now. I say your pump is going or gone. and your going to need a new engine or a rebuild. dont forget theres no cam bearings in the heads the cams ride on the head. and if oil pressure dropped and no oil got to the cam area. your cams and heads are done for.
speedy81304 is offline
post #16 of 19 Old 12-12-2009, 03:44 AM
Turboram4.7
ASE master certified
Turboram4.7's Avatar
come'on guys an oil psi switch wont make the knocking he's describing...
what normally happens in the 4.7 is 2 things
1. the sludge/carbon chunks in the engine clog up the filter screen and block oil flow to the bearings causing you to chew up conncting rod bearings in short order (5 mins)
2. the timing chain guide is plastic after alot of heat cycles the thing snaps and winds up floating in you oil pan , eventually it clogs up the oil pump pickup tube and bam cuts oil pressure and you chew up bearings , how long it takes to destroy the engine depends on how clogged the tube screen is ...
you have noise so one of your connecting rod bearings is shot guarenteed , mine almost suffered the same fate but I caught it in time ...
pull the oil pan and clean out the tube screen , check for any kinda crap in there , the plastic will be orangy colored ...
there is no way to just change the oil and fix it , you have to pull the pan , there will also be about 1/4" of sludge in the bottom of the pan
the dealer wants you to think its a pump , more money involved there then replacing the pickup tube and cleaning the pan or changing the switch , 9 times out of 10 its the pickup tube , usually my customers let me catch it in time before they need a new engine , but 2 hours ? your engines done bro, sorry
2003 dodge ram 1500 4.7 auto,twin garrett T-03 turbos,pcv/valve cover mod, srt-10 seats,srt dash bezel,srt brakes,billet gas door ,future mods include 08 front end conversion, some kinda drop kit 4/6
Turboram4.7 is offline
post #17 of 19 Old 12-12-2009, 07:44 AM
greenshovel
So Mote It Be !!!
Not always true, mine had no sludge as that was the deciding factor if they were going to pay or me. They paid as the pan had no sludge....I was also there to see myself to ensure they (the stealership) wouldn't BS me ....
Turbo, if you read my post you will see that the knocking didn't take place until after they swapped the switch, not during the knocking.
To the OP what was the final results to the situation?
Steve ستيف
post #18 of 19 Old 12-12-2009, 09:05 AM
peeblesm
ol faithful
peeblesm's Avatar
interesting info here guys. i'm so tempted to drop my oil pan and see how my bottom end looks like.
2004 dodge ram 1500 4.7L engine. quadcab; shortbed 2wd
military guy
nv3500 5-speed tranny
s&b cold air intake
4.56 motive gears and detroit tru trac in the rear end
centerforce II clutch
gibson headers, dual exhaust
flowmaster mufflers 40 series
NGK Spark Plugs (G-power) ZFR6FGP 7100
jet performance 180* t-stat
hurst competition plus shifter #3910155 (94-00 dakota v8) fits nv3500 tranny
line-x spray in bedliner over the rails
camper shell (A.R.E. brand with no windows on the side. too many blind spots now)
kool vue tow mirrors
debadged ram 1500 letters on both sides
PML diff. cover(I like it)
265/70/17 tires on stock rims painted metallic black ( holding up good so far. lol )
peeblesm is offline
post #19 of 19 Old 12-12-2009, 10:20 AM
Turboram4.7
if you have 2wd its so damn easy to drop the oilpan , not sure who said you need to lift the motor , but you dont have 2
    1986 D100 A/C wiring prob / Engine prob kkcummins98 1972-1987 Dodge Ram Trucks (D, W-series) 4 06-06-2009 04:44 AM
    2004 Ram 1500 4x4 Check Engine Light fmaglin 3G Dodge RAM - General Talk 1 03-02-2008 09:30 AM
    2004 Ram 1500 Hemi Dual Exhaust Installed and Check Engine Light problem jjames15ca 3G Dodge Ram Performance Talk 13 01-09-2008 06:02 PM
    2005 ram 1500 electrical loss prob Embalmer 3G Dodge RAM - 4X4 Talk 1 04-06-2007 05:45 PM
    2004 Durango rims on 2004 1500 ram? mfc 3G Dodge RAM - General Talk 2 11-09-2004 04:25 PM
