l
- Posted: 10-16-2009, 12:47 AM
Post #21
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, SRT CAM, 6.1 Rods/Springs, Home Ported/Polished Heads, Custom Catch Can, Amsoil, NGK 5306 Plugs, MSD 8.5MM Full length Wires, Transgo HD W/Resister, Superchip 3865, TCM wirecut mod, 180 T-Stat, K/N 77 Series CAI, Flowtech headers with Y-Pipe, Ditched the Cat, Duals out the back, Jack Rabbit bed cover, Spray in bed liner, Big Mouth Grill-Black, Custom 10's sub enclosure under back seat, Upgraded 160 amp alt., Illegal window tint, Shedded excess weight, Passport 8500 Radar Detector, Debadged.
Posted: 10-16-2009, 01:14 AM
Post #22
I bet it didn't seem cool at the time...too bad how that truck ended up too...
2004 Dodge Ram 1500 QC Hemi Performance: Superchips 3865 | OEM 3.92s w/ LSD | VHT Coated Thorley Tri-Y Headers and Y-Pipe | Magnaflow 3” SI/SO Muffler | Magnaflow Hi-Flow Cat | Raceland USA Switch-N-Blast cutout | Shroudless Mark VIII E-Fan | 180* T-Stat | Taylor Thundervolt 8.2mm Wires | NGK 5306 Plugs | Dual Cold Air Intake | Optima Yellowtop Wheels/Suspension: DJM/Doetsch Tech 2/4 Drop | Belltech Nitro Drop 2 shocks | AirLift "Slam Air" Air Assist | 22" Boss Motorsports black 335s | 275/45R22 Kumho Ecsta STX tires Exterior appearance: 5% Tint | Cleared OEM Headlights | 6000k HIDs | White LED Fogs | LED Tails | Color Matched and Shaved Grill | Gutter Grill | Black Vinyl B-Pillars | Red Calipers Stereo: Stock head | Infinity "Reference" speakers | FatMat throughout doors and cab Alarm: Python 990 Alarm w/ Remote Start | Two Sirens and hidden Piezo Coming Soon: White door spears | Tint for LED tails |
Posted: 10-16-2009, 06:36 AM
Post #23
2007 Ram 2500 QC/SB 4WD - 459rwhp/933rwtq 6" Lift w/ Bilstein 5100 Shocks MB Gunner 20" Wheels w/ 37x13.50x20 Toyo M/T's Twiggy 6000K HID Headlights and Foglights AFE Stage 2 Intake 5" FBD Turbo Back Exhaust Bully Dog Triple Dog w/ Crazy Larry TS Performance MP-8 Bryd's Intake Manifold Relentless Diesel Tranny (Billet Input, Suncoast Triple Disc, VB) Click HERE to view the complete signature... |
Posted: 11-11-2009, 10:27 PM
Post #24
Ok so my driveshaft hit the ground today!!! Lucky i was sitting at the light and had just barely hit the gas to go... Demon where did you go as Ill prob have to have mine towed there...
Posted: 11-12-2009, 09:25 AM
Post #25
I had to swap mine out about 3 years ago. It constantly felt like the truck was dragging something and every so often I'd hear a squeak. Climbed under the truck and there was some serious play at both ends of the drive shaft. I swapped them with greasables so now every time I do an oil change, while I'm under there I give each of them 1 pump from the grease gun and I never have to worry. Took me maybe a 1/2 hour from start to finish.
'03 4.7 QCSB 4x4 5spd manual K&N CAI T-Bar crank Flex-a-lite 180 e-fan Magnaflow cat back kit Powerwire Cooper Discoverer S/T 265/70/17 Yukon 4.56s Debadged, Color matched handles and mirrors Ported Heads |
Posted: 11-12-2009, 01:20 PM
Post #26
How do I check the play in the joints? Truck in park, neutral, drive?
Posted: 11-12-2009, 01:43 PM
Post #27
ooh nevermind
| Sponsored Links |
Posted: 11-12-2009, 01:44 PM
Post #28
seriously though grab it and yank it from side to side if there is any play in it you will notice it. it should clunk back and forth if there is any play. if it is solid then you are good to go.
ooh nevermind
Posted: 11-12-2009, 02:42 PM
Post #29
And it doesn't matter what gear your truck is in either when you test the u-joints, and I typically try to jerk it back and forth at all angles, side to side, up and down, and at left/right angles. If there's any play, get them replaced.
Posted: 11-12-2009, 04:22 PM
Post #30
i was told in neutral with the e-brake on. what you want to try and do is grab the driveshaft on both sides of the u-joint and twist in opposite directions to check for play. there should be very little to no play at all. when i did mine, i had almost a 1/4" of rotational play in them. pretty bad. the truck squeaked, clicked and vibrated like hell. cost me about $40 for new joints and did them myself in a 1/2 hour. if youve got a vice, a hammer and a flat head screw driver, its a piece of cake. you may or may not need a heat torch to loosen them up a bit. i didnt on my truck, but i did on my friends. they were stuck in there really good.
84 Toyota Supra 02 Ram 1500 QCSB 4.7L 4x4 Dodgetalk.com 287 Enthusiast Member #108
Posted: 11-12-2009, 05:18 PM
Post #31
Thanks for the info guys. I'll check this weekend.
Posted: 11-12-2009, 10:37 PM
Post #32
Well i have to replace the u-joint and the flange on the rear.. Took a chunk out of it.. 140$ flange..
| Thread Tools | |
| '05 CTD 4x4: worn u-joint or ball joint? help! | tomcat#1 | 3G RAM Diesel Talk | 6 | 12-05-2008 07:20 PM |
| '05 Ram 2500 CTD 4x4: worn u-joint or ball joint??? | tomcat#1 | 3G RAM - 4X4 Talk | 7 | 12-05-2008 10:14 AM |
| My first Dodge! 2001 1500 4X4, U-joint and Ball Joint questions | Homie_g | 2G RAM - Drivetrain Talk | 5 | 01-07-2007 11:33 PM |
| Is U-Joint going? | rebelram01 | 2G RAM - General Talk | 3 | 10-24-2006 04:36 PM |
| u joint | tomanna | 3G RAM - Drivetrain Talk | 1 | 06-25-2006 09:30 AM |
| Sponsored Links |
