lose oil pressure when engine warm - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 16 Old 10-15-2009, 05:22 PM Thread Starter
pb_
I've got a 2001 1500 2wd 5.2L Ram and need to replace the thermostat. It usually sticks open and keeps the temp gauge just above the needle's resting place. With Winter coming, I want to get it replaced...
However if it works and the engine heats up, or of I heat up the engine by towing, etc, the temp gauge appears to work fine. Only problem is that when the engine is warm, my oil pressure drops. If I'm coming off of the highway, or slow down from towing (with OD off) the oil pressure drops to nothing and picks up within a couple of seconds only to do it again a short time later.
I know the oil thins as it gets hotter and I'm concerned that I may have some bearing damage/issue where the tolerances are opening too far as the temp rises. Could the oil not drain back fast enough/ weak pump, etc? Any ideas? I'm looking for something simple to ease my mind
Thanks
pb_ is offline
post #2 of 16 Old 10-15-2009, 05:31 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
My 93 dak 318 had low oil pressure, which is why I pulled the engine out. Turned out that the cam journals were worn bad. You can live longer by using heavier oil and a can of "Restore" 8 cyl version. Does the idiot light come on when dropping to zero on the presure guage?
Other things I've heard are the passages get gummed up at the sensor or the sensor itself is bad.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #3 of 16 Old 10-15-2009, 05:40 PM Thread Starter
pb_
The (no) oil light and a warning chime occur when it hits zero.
pb_ is offline
post #4 of 16 Old 10-16-2009, 06:28 PM
kevinb70
kevinb70's Avatar
how many miles? i would go oil pump over bearings unless you're getting close to 300k
if you go to autozone get the standard volume pump...
1999 Dodge Ram 1500 4x2 5.2L NV3500 Club Cab
in: sct by hemifever
-Upgrades waiting on their lazy owner to install: russell stainless lines, hawk ceramic pads, rotor, calipers, energy suspension master kit, derale 4000cfm dual fan kit, moog upper/lower ball joints
kevinb70 is offline
post #5 of 16 Old 10-16-2009, 10:10 PM Thread Starter
pb_
It's only got 112K on it. Thanks
pb_ is offline
post #6 of 16 Old 10-19-2009, 07:14 PM Thread Starter
pb_
Any other ideas on my I lose all oil pressure at operating temps going from 2000 rpm or higher down to idle?
pb_ is offline
post #7 of 16 Old 10-20-2009, 06:47 PM
97black_ram
97black_ram's Avatar
I would try a oil pressure sensor, there like $16 at autozone.
Not to hijack your thread but I'm having a similar issue. I have a 97 ram 1500 4x4 5.2L with 156K miles on it. I did an oil change with 10w-30 pennzoil and frame extra guard filter and for the last two days my oil pressure gauge has been stupid. It runs at 40psi on the freeway and 39psi at idle in gear then would start jumping around. Ok so like above today I replaced the oil pressure sensor and now it reads I only have 20psi go figure.
I'm going to change the oil again this weekend to what I normally use and an stp filter see if the issue goes away.
Any thoughts or suggestions otherwise.....
1997 Dodge Ram 1500 4x4 Sport 5.2L * Auto built 46RE * 4.10 Gears, flowmaster 10series, 315/75/16 firestone mt, MSD Wires, napa brass cap/rotor, Hughes Plenum, B&M deep pan & trans. cooler, 3" TGC lift, Dana 60 Swap
1981 Chevy K20 4x4 5.7L
97black_ram is offline
post #8 of 16 Old 10-20-2009, 10:38 PM
RamThis
RamThis's Avatar
Quoted: 2 Post(s)
He's already tried an oil pressure sending unit.
One thing you might try, but it would be a bit difficult I think to reach properly, is to remove the oil pressure sending unit, and blow some compressed air back through the port to make sure it's not clogged somehow, but I doubt that's the case.
ONLY other thing I can think of that would cause a gradual loss of pressure would be if you had a chunk of gasket material or chunks of RTV from a poor repair job that fell down into the oil pan, and are getting sucked up against the oil pump screen. If no one's been into any part of the engine then that's probably not the problem.
I'd still lean towards large bearing tolerances around the cam and crank but even at that it would have to be really really excessive for it to be dropping to zero on the dash guage.
You really really should try a mechanical guage hooked up to the sending unit's port. Since Im sure you have an old sending unit laying around you could use that to match up the thread pitch and diameter and come up with a guage and adapter of some sort to thread into the hole and check the pressure with a good analog guage to be sure. Hell it could even be something wrong with the cluster or PCM?? You'll never know unless you check the actual pressure reading though.
2000 Dodge Ram 1500 Single Cab, 5.9 Auto, 4.10's, Auburn LSD, Edelbrock headers, 2.5" true duals with crossover, MSD Superconductors, APS Plenum Kit, Level10 Trans kit, Trans-Go shift kit, 2-4 BellTech Drop, SS/T rims, Toyo Proxes ST 285-60-17's, Sir Michaels Roll Pan and tailgate handle relocator, Keystone bumper cover with light openings, PIAA fogs, painted grille shell, painted Street Scene Speed Grille Inserts, SCT XCAL-2, Alpine head unit, Infinity Components front, Infinity Coaxials back, Infinity 500W 4 channel amp, Infinity Basslink, new dash, steering wheel, and guage bezel.
1996 Dodge Ram 1500 Club Cab, 5.9 Auto, 4.10's, Detroit Locker, Race Truck Trends Nascar Bumper, Painted SS/T Stripes, Alpine HU, Alpine Sound Field Processor, MTX Thunderform. 5.9L bored .030 over, Sealed Power coated pistons, balanced and polished crank, Comp 210 Cam, MP Timing Chain tensioner, Melling HV oil pump, 1.92 oversized valves and mild porting, Pacesetter Longtube Headers, FMS 24lb Injectors, Level10 Transmission kit, Trans-Go shift kit, 5 gear OD Planetary. Way more to come.
RamThis is offline
post #9 of 16 Old 10-21-2009, 05:39 PM
97black_ram
*Update* Got my mechanical in and it reads 25 psi in park at normal operating temps and 40+ when at 2,000 rpms. Not sure what to think yet. Will have another update tomorrow after I drive it more.
post #10 of 16 Old 10-21-2009, 06:02 PM
dustermaniac
Senior Moparologist
dustermaniac's Avatar
That is good oil pressure. Hopefully it was just the sending unit.
1973 Plymouth Duster, 340, 727 Auto, Bored.030, Race pro Cam, Pistons, Edelbrock Performer Manifold, Edelbrock 750CFM, Accel Ignition,Denso Plugs, Accel Wires, K&N Air Filter, Mopar Orange Box Spark Control, 3 Core Radiator. B&M Shift Kit, Low Gear kit with Deep Oil Pan, 8 3/4 Rear End, Hooker Headers with Cherry Bomb Duals.Royal Purple Oil, Kenwood 400 Watt Cd Player /w Sirius Satellite.Too many new parts overall to list. I continue to replace any old parts with brand new ones as $ permits.
dustermaniac is offline
post #11 of 16 Old 10-21-2009, 07:00 PM
Gregs RAM
Gregs RAM's Avatar
97black, agreed, I don't see any problems there.
Good deal!
1997 Dodge Ram 2500 Series, (8,800 GVW), 4x4, AT, 360, Reg. Cab
-Prodigy Electric Brake Control
Gregs RAM is offline
post #12 of 16 Old 10-22-2009, 07:21 AM
97black_ram
Cool thanks guys.
post #13 of 16 Old 10-22-2009, 10:36 AM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
I sounds like a blockage at the oil sending unit. How big is the orrafice at the meter u have vs. the orrafice for the oem sending unit. IIRC the sending unit is tiny.
dizzyD is offline
post #14 of 16 Old 10-22-2009, 10:47 AM
97black_ram
If your referring to me there both 1/8".
post #15 of 16 Old 10-24-2009, 08:05 PM
Rayza76
Rayza76's Avatar
Whats up fellas? I've had my ram for 8 or so years and i've fought the oil lamp/ pressure drop for years. 2 engines, 2 oil pumps and maybe 3 oil pressure sending units. Best cure i found was a 160 degree tstat. I don't know what the deal is, but if my truck reaches 180-190 degrees, @ idle, the light will come on and the gauge will go up and down, and eventually stay down. Give it a little gas, it would come right back up. Never did i hear a change in the engine or suffer bad performance. Once i figured out it was temp related, i got the 160 tstat and never saw the light again.
Rayza from the Jersey Shore!
Me: Computer tech/ swimming pool builder
Her: 2 tone geen '97 ram 1500 4x4, 360 on 33's
244k on the bod and 36k on the engine and trans
air raid intake, hypertech programmer III, 160tstat, 2" skyjackers(front)
2000 watts across New infinity highs and polk 10"(x2) lows
flow tech shorties, 3" cat back to 3"in/2.5"x2out flowmaster
hughes plenum/ cut runners/ red injectors
She loves it dirty and rough....
Rayza76 is offline
post #16 of 16 Old 10-24-2009, 09:51 PM
doodlebug
doodlebug's Avatar
You simply cannot accurately tell what your oil pressure is doing by depending on the idiot light on the dash. Like has already been said, you need to connect a "good" mechanical gauge in order to be certain.
Current recommendation from most authorities is at least 10 PSI per thousand RPM. Anything less and its time to start getting concerned.
1987 Dodge Power Ram W100, 4X4, 5.2L, 727, Short Bed
"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm."
doodlebug is offline
    '05 Oil Pressure Light. On, then restart engine, goes off. Belrix Dodge Caravan General Talk 3 10-28-2008 01:22 PM
    Low Oil Pressure Engine Wrecked GrayD 1G Dodge Durango - Drivetrain Talk 9 06-08-2006 12:19 PM
    Need help locating the Oil Pressure Switch on a 2.4 DOHC Engine tmbrian 2G Dodge Stratus - General Talk 1 08-14-2005 05:09 PM
    98 durango engine oil pressure probs and then the fix EMF_VIRUS 1G Dodge Durango General Talk 2 05-18-2005 01:14 PM
    Oil Pressure Gauge Hemi Engine Stephan28 3G Dodge RAM - Drivetrain Talk 2 09-21-2004 09:01 AM
