04 Durango - Vibration under acceleration - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 10-14-2009, 09:45 PM Thread Starter
dcwdurango
I just purchased my 04 limited a couple of weeks ago & it has a wicked vibration only when travelling between 100-130km/h (60-80mp/h) under acceleration/load. As soon as i take my foot off the gas the vibration goes away.
The vibration is not in the steering wheel so this leads me to believe its coming from somewhere in the driveline - possibly a u-joint or tranny/motor mount. I had the truck into the local midas shop & they could not find anything.......
Any feedback is greatly appreciated!
dcwdurango is offline
post #2 of 12 Old 10-15-2009, 10:11 AM
KC_Metal
Mopar Rules!!!!!!!!!!!!!!
KC_Metal's Avatar
It could be that the tires are out of balance. Mine did the same thing and with these big rims and tires if they get out of blance they will vibrate like crazy. I would check that first as it's the easiest. Also make sure all the lugs are tight maybe you have a rim coming loose or something. Deeper it could be coming from the axle, transmission or transfer case? If it only has the vibration when you acclerate then maybe it is joint related. Did you check to see if there is any slop in the u-joints.
Good Luck!
2006 Chrysler 300 HEMI C 5.7L V8: (Summer Car)
- Hurst Comp stick kit & badge, Windows Tinted 15%.
2010 Avalanche LT 5.3L V8: (Wife's Truck)
- Windows Tinted 15%, 8 Bar 20's from California
2008 Chrysler 300 AWD Touring 3.5L V6: (Winter Car)
- Hurst Comp stick kit & badge, Windows Tinted 15% (soon)
Fu*k Toyota, Honda, Mitsubishi, Lexus and all that other Jap crap!
KC_Metal is offline
post #3 of 12 Old 10-15-2009, 08:26 PM
rangoneer
Power Aficionado
rangoneer's Avatar
If you drove through mud and left it park overnight, the mud or even ice/snow will cause it to be out of balance.
Driveshaft is another possibility. If they have done differential work on it they may not have aligned the driveshaft up correctly with the differential key.
Being you can't feel it in the steering wheel then I'd check the rear wheels first. go underneath the D and look at the rear rims and see if there is anything accumulated on there. Also it would be worth to put a wrench on your lugs and make sure they are tight.
Then check if they've done any work to it. Or if you got it from a certified dealer, PM me your VIN and I'll tell you if they've done Axle work.
Good Luck and keep us posted.
05 LTD Black HEMI ...loaded with the basics
I NEED MORE POWER!! ...and to lose some weight!
rangoneer is offline
post #4 of 12 Old 10-15-2009, 09:02 PM
AK1
What! Me Worry?
AK1's Avatar
Quoted: 2 Post(s)
Check tire balance first, then work from there.
BLACK '04 Durango LTD
"Yeah, it's got a HEMI"
SPEED HAS NEVER KILLED ANYONE, SUDDENLY BECOMING STATIONARY, THAT'S WHAT GETS YOU!
Black Truck Club member #153 | DT Durango Club member #72|Hemi Club member #102
AK1 is offline
post #5 of 12 Old 10-17-2009, 07:16 PM
mopar nut
I had a similar problem with mine and it was that the ujoints were shot, all changed all good now.
mopar nut is offline
post #6 of 12 Old 10-17-2009, 08:18 PM
matted2thefloor
matted2thefloor's Avatar
I would agree on the u-joints/driveshaft causing the vibration.
04 D 5.7 SLT AWD (hers)(gone 3/12)
99 Cobra (mine) SOLD
00 Toyota Camry
06 Toyota Avalon Limited (hers)
matted2thefloor is offline
post #7 of 12 Old 10-18-2009, 12:12 AM
Gold5th
Gold5th's Avatar
Quoted: 24 Post(s)
But start with checking the tires/cleaning the back sides of the wheels.. cheapest and easiest fix.
|LED/DASH Light Conversion Member #4|Dodgetalk.com Durango Club Member #68 | Hemi Owners Club Member #28.5
2012 Ram 1500 Laramie - 5.7L Hemi with 6spd, LSD, auto 4x4, aFe CAI, Bullydog GT for Hemi
02 Chrysler Neon R/T - 2.0L HO 1/2 a Hemi - Hers - AEM CAI, 4300K HID, 3200K HID in fogs
Gold5th is offline
post #8 of 12 Old 10-18-2009, 08:24 PM
matted2thefloor
It is not likely a wheel/tire imbalance issue. If it was, the vibration would still be there regardless of throttle input.
00 Toyota Camry
post #9 of 12 Old 10-19-2009, 10:02 AM
rangoneer
Power Aficionado
rangoneer's Avatar
not neccessarily. Depending on where the imbalance is the centrifugal force is noticeable at certain rpm/speed/throttle input. Hence the vibration at a certain Speed. If the imbalance is off more toward the center then you would have to travel at a faster speed than if it was on the outside of the rim.
It is easy to test Ujoint vs balance. Get to the speed that produces the vibration the worst and turn on your cruise control. Then push your tow/haul button and when the rpms increase notice if the vibration changes. If it does then it is a ujoint or driveshaft issue. If it doesn't change then I say tire/wheel balance issue.
post #10 of 12 Old 10-19-2009, 10:04 AM
KC_Metal
KC_Metal's Avatar
Interesting and good to know.
KC_Metal is offline
post #11 of 12 Old 10-20-2009, 09:41 PM
sims76
I just bought a used 2004 Limited 5.7L. I am having the same problem. I took my pry bar out there and poked around and found that there is a bolt that holds the top of the front diff to a mount. Mine is missing allowing the front diff to wiggle.
Probably not your problem, but get under there with a pry bar and check things out.
Good luck,
Sims
sims76 is offline
post #12 of 12 Old 10-21-2009, 08:44 AM
KC_Metal
KC_Metal's Avatar
Good luck,
Sims
Good job finding the issue.
KC_Metal is offline
    03 Acceleration Vibration (5-15mph) lv2bunderwater 3G Dodge RAM Diesel Talk 6 10-03-2008 06:35 PM
    07 Megacab Vibration at acceleration megacabby 3G Dodge RAM - Drivetrain Talk 1 06-05-2008 03:02 PM
    Significant Vibration on Acceleration Magnum5.9 3G Dodge RAM - General Talk 12 03-08-2008 09:32 AM
    Vibration on acceleration from stop codys2500 3G Dodge RAM Diesel Talk 3 05-09-2006 09:15 AM
    4X4 Noise / Vibration Under heavy acceleration labjr1 3G Dodge RAM - Drivetrain Talk 24 02-04-2006 04:34 PM
