Thread Tools |
Post #1
I have a rebuilt PCM coming for my 2006 Dodge Ram 4.7 as the old one has a faulty injector driver circuit and have a few questions, I'd be grateful for any advice that can be offered.
1) From what I can see, the new PCM will need to be programmed with the vehicles VIN and current mileage, is this correct? 2) Would the ECU also need flashing with software? 3) Am I stuck with going to the dealer for the above and being subject to them rubbing their hands together in glee with $ signs in their eyes or is there an alternative? I bought the rebuilt ECU from AutoSource Modules, normally they would perform VIN and mileage programming but stated in this case it had to be performed while the PCM was in the vehicle. The $375 I spent on the replacement PCM was a wallet buster for me and I'm dreading having to now find the extra money to get the unit programmed. Thanks in advance for any input. Russ.
2006 Dodge Ram 1500 Quad Cab SLT 4x4 |
| Sponsored Links | |
Advertisement |
Posted: 10-13-2009, 10:32 AM
Post #2
Wow, any chance you can return it and get your money back? You way over-paid for it IMO. I checked car-part.com and found one as low as $50. There are several for a 2006 4.7 Auto Trans non-flex fuel from $50-$200.
2005 Ram 1500 SLT Sport 4.7L 4x4 QC/SB Performance: FM TB | Air Ram Jet Stream | S&B CAI | Gibson Headers | 3" SI/2.5" DO | 4.56's | Detroit Truetrac | Hemifever SCT | Aeroforce WBO2 | Bilstein 5100s Appearance: N-Fab Nerf-Steps (Line-X'd) | Leveled (TBs Cranked) | 2" Blocks | KMC XD Addict 17x9 w/BFG AT 315/70-17 | Unique Coatings Tails | Black Magic Behind the Grille | BedRug | Century Royal Cap | SRT-10 A-pillar w/Aeroforce Interceptor | PML Diff Cover | Fenderwell Liners Awaiting Install: FM 206 Cams, FLX-180 Fan 2000 Durango SLT 4.7L 4x4 FM TB | Superchips | FLX-180 Fan | T/S Lift | PML Trans Pan |
Posted: 10-13-2009, 10:53 AM
Post #3
Only problem I can see with those is that they are straight from salvage, in which case they won't work without undergoing a rebuild. Once the VIN and miles are inserted into an ECU for the 06, it's useless in another Ram without being rebuilt.
I shopped around a lot when looking for mine and this was the best price I found, the worst was over $600! Still better than going to the dealer for an OEM which is in the thousands ![]()
Posted: 10-13-2009, 11:08 AM
Post #4
Wait, why would those not work for your truck if they are flashed with the correct VIN and miles? Are you sure this wouldn't work?
Anyway, as for your original question, sorry, I'm not sure, but you will definitely need the dealer or someone with the correct scanner (DRB-III I believe) to flash it for you.
Posted: 10-13-2009, 11:36 AM
Post #5
The Dodge Ram PCM's from 06 onward are 'flash once and thats it', according to the service manual. Once they've been paired with a particular truck they cannot be re-flashed with the VIN of another truck, you either have to get a new one from Dodge (ouch!) or a rebuilt one.
Posted: 10-13-2009, 09:02 PM
Post #6
I'm not sure what service manual you are reading. The replacement PCM as long as it's the correct type for the truck can be flashed to work with your truck. Installing a replacement one is more involved than just updating software. Yes it can & will have to be done at a dealer with a Starscan diagnostic tool. they will need the Personal Identification Number to access the vehicles security. This # is on the new truck invoice or they can get the # from Chrysler's keycode database. At that point they will enter in the VIN & the mileage which will be confirmed by the instrument cluster. The dealer will also have to download the latest engine/transmission flash file for your truck to load into the replacement module. The new module will then need to learn the ETC (electronic throttle body) positions and the transmission will need to be run thru a quick learn process. Finally they will place an "Authorized modification" label on the module as it will always keep the original vehicles VIN# recorded in the background for legal reasons.
Posted: 10-13-2009, 09:40 PM
Post #7
Thanks for the information, hemimech, I just wish I'd known this sooner ![]() Russ.
| Thread Tools | |
| replacing speakers on an 89 ram 50 help | 89ramd50 | Dodge Ram Truck 1st Gen (88 - 93) Forum | 0 | 12-11-2007 05:01 PM |
| Replacing pcm | Vader1978 | 3G Dodge RAM - General Talk | 2 | 10-04-2007 04:36 PM |
| Replacing The Pcm On A 2002 Neon | JB AUTO | Dodge Neon - General Talk | 3 | 11-05-2006 01:30 AM |
| Pcm Needs Replacing | 99DODGEDRIVER | 1G Dodge Durango General Talk | 5 | 04-08-2004 01:27 PM |
| Replacing the 6X9's in a Ram | Polar_Bus | Mobile Audio & Electronics Talk | 2 | 10-29-2003 12:12 PM |
Privacy Statement | |
