Replacing Water Pump 1997 Ram - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 17 Old 09-24-2009, 12:14 AM Thread Starter
DODGE DIVISION
How hard is to replace the water pump on a 1997 Dodge Ram Pick Up? It has the 5.9 V-8 with A/C. I have done it before on the 318 from the 70's. Does the A/C compressor have to be moved on this year? Is it about the same amount of work?
DODGE DIVISION is offline
post #2 of 17 Old 09-24-2009, 08:48 AM
rich_kildow
rich_kildow's Avatar
H2O Pump
Yes, the AC compressor has to be moved, but it is a fairly easy job. Everything down to the water pump had to come off when I did the intake plenum, and it was less than an hour worth of work to get down to the front of the water pump. While you're in there, make sure you replace the bypass hose. Everything has to come back off if that splits.
1998 Dodge Ram 4x4 360...bone stock and it's gonna stay that way. Used to haul my 19' bass boat.
rich_kildow is offline
post #3 of 17 Old 09-24-2009, 10:44 PM
redheadhunter21
redheadhunter21's Avatar
I know when I did my water pump on my 96 I did not have to take off AC compressor all I took out was the belt, fan shroud and fan then unbolted the water pump did my friends sst and we took the radiator out just for the extra space but it did not need it I think his is a 97
1996 Dodge Ram Ext. 2wd Sport with a 360
Ebay intake, Custum true dual 2.5" exhaust, 2500 brake calipers and pads, 3500 rear cylinders, Pioneer CD Player, Infinity Kappa 6x9's and reference 6 1/2's, Tint, Excalibur alarm with remote start, 2.5" lift coils and 3" doetsch spindles in front, 1.75" lift shackles and 2" blocks rear, Cragar soft 8's(285/75/16 Dakota M/T), Cragar super sport(33x12.5x15 timberland A/t), SCT by Hemifever, below rails toolbox with alarm hooked up to it, Mossy Oak seat covers and headliner
Wanted: KRC 210x, Shift kit and trans rebuild, 4.10s, locker, oh yea more money
redheadhunter21 is offline
post #4 of 17 Old 09-24-2009, 10:58 PM
troyledet
troyledet's Avatar
the a/c does have to come off if you change the by pass hose which i would recommend doing while you have the water pump off
Nekid Truck Club #25, LA Mopar Mafia, Sinister Customs
2007 Dodge Ram 1500 Quad Cab
4/6 McGaughys drop
panasonic cd player 6.5" MB Quarts components front doors, 5.25" MB Quarts compenents rear doors, 2 10"JL w3v2 in a Car Audio Factory box 500x1 JL for bass and 600x1 Autotex street machine for highs
24" Incubus rims with 255/30r24 tires
troyledet is offline
post #5 of 17 Old 09-25-2009, 01:11 AM
dakotas ram
take your fan and clutch off b4 removing your belt
1995 1500 2wd auto
short ram intake----DIY ported TB----DIY ported and polished heads
egr delete----pacesetter shorty headers----3" single IMCO turbo side exhaust
Mark VIII efan----accel coil----3923 plugs----180 tstat----transgo jr shift kit
debadged----billet grille----euro heads and tails----3-5" drop soon----moroso 8.5mm wires
dakotas ram is offline
post #6 of 17 Old 09-25-2009, 06:49 PM
Ram15002ndgen
Don't Fear the Reaper
Ram15002ndgen's Avatar
Wait, let's clarify, the A/C does NOT need to come off, it can be moved to the side gently. DO NOT remove your A/C, just move it over. I know how literal some people can be. The entire job is really easy. I replaced my pump a few years back and it was no big deal. The biggest amount of work is just getting the bracket and all the parts off (or moved out of the way). It's a couple of hours work if you take your time and have a few beers.
Ram15002ndgen is offline
post #7 of 17 Old 09-25-2009, 09:16 PM
spun360
spun360's Avatar
Quoted: 149 Post(s)
i have a spare pump if you need it. PM me for a deal?
spun360 is offline
post #8 of 17 Old 09-26-2009, 12:01 AM
chizzle1
REDNECK SPACESTATION
chizzle1's Avatar
Quoted: 18 Post(s)
I have changed mine in about 30 minutes, nothing needs to be removed other than the fan & shroud.
It's not like the LA setup, where everything is attached to the water pump. The pump will come off without removing any of the accessories.
A good excuse to switch over to e-fans is plenty of room to work
01 Ram 5.9 Sport QC 4x4 - 175k, current build project - SCT Stage1 custom tune via Hemifever, Harland Sharp 1.7:1 roller rockers, Modded Kegger, Edelbrock ProFlow,52mm TB,180* t-stat,e-fans, pacesetter long tube headers, true duals with spun cats, Jones full-boar mufflers, 34x11 Falken ATs on 3rd gen Dodge 20"s, 3"TC lift, rebuilt 46RE w/HD internals, PML Deep Pan,SunPro Tranny Temp gauge,Rebuilt 231D,TSC Diamond Box, Sony head unit
10 Dodge Challenger R/T in Brilliant black - 392 cam,AFR shaker, MyGig 730N w/ navi,dvd,HD,u-connect & rear cam, 6 spd, Track Pak, SRT8 shorties & mids, DS Predator, Jet 180*, BBK 85mm tb, SLP line locks, de-badged, resonators removed, DRL enabled, skip shift eliminator, mopar hood struts, functional hood vents, 392 chin spoiler
09 Suzuki 1255S Bandit Metallic Blue on black, 1255cc I-4, 6 spd, Yoshi can, Givi screen, K&N, Bags Connection tank bag, TPX fuzz buster, Techmount GPS holder, Suzuki center stand, World Performance Seat
2013 Dart Limited Pitch black, fully loaded, hers
SOLD 06 Hemi Durango 4x4 Limited in Atlantic Blue Pearl
SOLD 97 Ram 1500 SLT Laramie in DuPont Frost White Pearl
chizzle1 is offline
post #9 of 17 Old 09-26-2009, 12:33 AM
Ram15002ndgen
An E-fan would be a nice mod, but they are kinda pricey. Probably makes the A/C work better too.
post #10 of 17 Old 09-26-2009, 02:25 AM
dakotas ram
messing up my clutch and stock fan changing my water pump was my excuse for the efan
1995 1500 2wd auto
post #11 of 17 Old 09-26-2009, 05:38 AM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
My redneck-delux setup was about $200. Not as fancy as the all in one kits, but works good.
And yes, the A/C works great even at idle.
chizzle1 is offline
post #12 of 17 Old 09-26-2009, 07:54 PM
Ram15002ndgen
The 4rth gens now come with Efans. I wonder if that set up could just be swapped over to ours? If so, that would be a great set up to get cheap at a Junk Yard, when they wind up there. Wont be too long, the way most people drive. I know this is a V6 but it may work just fine for a V8.
post #13 of 17 Old 09-27-2009, 12:24 AM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
you'd be surprised how much people are charging for those at salvage yards.
I sourced a fan from a Taurus V6 (similar to the one pictured above) and he wanted $80. Shit, I can buy a new fan for that.
Only problem with the above is there isn't an easy way to fabricate brackets for the overflow and windshield washer fluid tank.
With the universal aluminum shroud I bought from summit, i just cut tabs & used bolts to hang them near the stock location.
I have heard of people butchering the stock shroud to accomplish the same thing.
The wife's Durango has both, main clutch fan is belt driven and the secondary fan for the A/C & tranny cooler is electric. Don't know if that's standard equipment or an add-on with the severe duty towing package.
chizzle1 is offline
post #14 of 17 Old 09-27-2009, 12:59 AM
Ram15002ndgen
Yea, that is a stock set up for Durangos. Kinda funky set up, but I remember reading on another forum a guy with a Durango having an over heating issue and not knowing which fan was the cause.
That is really expensive a salvage yard charging that much. They have figured out how many people are holding on to older cars and want to stick it to ya. I agree with you that I would get the shroud from Summit and not destroy my OEM.
You know on the 4rth gen Rams I found out looking at online pics that the grill is stationary. So if you need to do some work on the front end, there is more tear down. I like the way out grill lifts out of the way, easy access.
post #15 of 17 Old 09-27-2009, 01:07 AM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
very true, makes working on the front end a lot easier.
chizzle1 is offline
post #16 of 17 Old 09-27-2009, 02:41 AM
dakotas ram
i got my markviii for $40, butchered shroud for now......chizzle, you got pics of your brackets you made?
1995 1500 2wd auto
post #17 of 17 Old 09-27-2009, 03:35 AM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
only pics of them mounted.
let me find the pics.
chizzle1 is offline
    1995 Ram Water Pump Install MightyDR 2G Dodge RAM - General Talk 3 01-05-2008 09:35 PM
    Water pump issues. Water and oil? Neil F. 1G Dodge Durango General Talk 0 12-17-2007 03:51 PM
    Need Help replacing water pump yamaha_yz125 2G Dodge RAM - General Talk 7 06-28-2007 09:17 PM
    I'm replacing the water pump, anything else? MonsterStyleCom 1G Dodge Durango General Talk 15 04-09-2007 08:46 PM
    95 RAM Water Pump HELP!!! Ram96SRT 2G Dodge RAM - General Talk 2 05-12-2004 02:38 PM
