front end rattle - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 37 Old 09-18-2009, 07:38 AM Thread Starter
Josh Brown
Josh Brown's Avatar
front end rattle
i have a rattle/clunk that I can here when the front tires hit a bump at lower speeds under 40. it's hard to pinpoint where the noise is coming from. It doesn't do it at 60-70. checked ball joints, tie rods etc. If I hit the bar that mounts to the pitman with the palm of my hand i get a noise that sounds like could be it but my friends does the same thing when I hit his but he doesn't have the sound I have while driving. It is getting annoying and I don't want to throw money at parts.
06 2500 QC SB 4x4 CTD Auto Mineral Gray Big Horn.
295/70/18 Nitto Trail Grapplers on Ultra Predators on stock suspension. A few performance mods.
Josh Brown is offline
post #2 of 37 Old 09-18-2009, 02:22 PM
mitchgmace
mitchgmace's Avatar
Did you jack it up and get the weight off the front tires? Then shake the front tires and all the parts.
2006 Ram 2500 5.9 CUMMINS TURBO DIESEL (325/610-stock
) 4x4 Standard Cab Long Bed 6-Speed - [SIZE=1]
Westin bed extender, LINE-X, Neopene seat covers
ATS Exhaust manifold/header
Muffler, Silencer ring, & Cat MIA, striaght pipe/stack
S&B CAI =Moe's, Byrd's Intake horn, Fass Fuel System
75hp injectors
Diablosport Predator Stacked with MP8 = Ton of HP
Dual disc clutch
Kore Recon lift 34" Swamper LTB's, Garmin Nav system
572hp/1077tq
Trucks and Guns Club #127
I spend my money on my truck and not my girlfriend, because I'll have it longer and less people have been in it! "
mitchgmace is offline
post #3 of 37 Old 09-18-2009, 03:47 PM Thread Starter
Josh Brown
Josh Brown's Avatar
Yes
post #4 of 37 Old 09-19-2009, 02:55 AM
mitchgmace
mitchgmace's Avatar
I got a recall #H46 for front end. you might check into it.
75hp injectors
Dual disc clutch
572hp/1077tq
post #5 of 37 Old 09-20-2009, 09:51 AM
gbrockjr
I believe that recall is for the steering linkage. I had mine in the shop for a trans service (which I will do myself next time) and they found the recall. I also remember a descussion on the forum about this rattle before and the finding was related to the steering knuckle. Since i'm not a young stud anymore the memory appears to be the second thing to go so you might want to do a search to verify.
2006 Ram 2500 CTD QC SB Patriot Blue 4X4
Line-X bedliner, AFE Air intake, Raptor Step bars, Air Lift Ride Control air bags. B&W Hitch, Access bed cover
gbrockjr is offline
post #6 of 37 Old 09-20-2009, 02:30 PM Thread Starter
Josh Brown
Josh Brown's Avatar
Well I adjusted the steering box and the pitman play is gone but I still had the noise while driving. After two alignment shop inspections that said it was all good I did my own inspection and found I need all 4 ball joints, very little play but enough to make some noise. What fun that will be. I guess every 50,000 miles I'll be doing this?
post #7 of 37 Old 09-20-2009, 09:20 PM
Skyd Ram
DodgeTalk Sponsor
Skyd Ram's Avatar
If you put in stock ball joints or stock like replacements. If you plan to keep the truck for a long time you may want to consider some Carli or Dynatrac ball joints. The Carli uppers are available now and the lowers should be out in a few months. Dynatrac is expecting to ship their uppers and lowers in a few weeks.
[/SIGPIC]2014 CCSB 2500 Laramie 6.7 Cummins
Pure Performance/BMF/Toyo Equipped
2005 RCLB Power Wagon 5.7 Hemi
Bilstein/Toyo
Official DodgeTalk Supporter
Authorized Dealer for:
Carli Suspension/Pure Performance Suspension/Bilstein Shocks
Dynatrac Products/BMF Wheels/MBRP Exhaust/AFE intakes and Exhaust/Smarty tuners
/H&S Performance/Flo Pro Exhaust/Edge Products
Call us Toll Free at: 888-886-2480
Skyd Ram is offline
post #8 of 37 Old 09-21-2009, 12:26 AM Thread Starter
Josh Brown
Josh Brown's Avatar
I looked at those and Carli is just too much money for me and they aren't guaranteed from what I can tell so I could spend big money and if they fail I'm SOL. The Dynatrac price is confusing, looks like $599 for all 4 but not sure.
post #9 of 37 Old 09-21-2009, 12:53 PM
mitchgmace
mitchgmace's Avatar
I just hit 50K on my truck and will be looking into those.
75hp injectors
Dual disc clutch
572hp/1077tq
post #10 of 37 Old 09-22-2009, 02:43 AM Thread Starter
Josh Brown
Josh Brown's Avatar
I just can't see spending the big money on Carli units, I am going to do XRF brand, should be much better then stock but much less of a joint then Carli.
post #11 of 37 Old 09-22-2009, 04:21 AM
MeenGreen5.2
i'm blue :D
MeenGreen5.2's Avatar
Quoted: 1 Post(s)
check your upper shock mounts... the rubber bushings wear out and the shock just moves freely up and down w/o dampening the bumps.
2010 dodge ram 5.7 sport
deep water blue pearl
BLUE
24"verde rims
stock
BLUE TRUCK CLUB MEMBER #249
Trucks and Guns member #164
MeenGreen5.2 is offline
post #12 of 37 Old 09-23-2009, 01:11 PM Thread Starter
Josh Brown
Josh Brown's Avatar
Shocks are fairly new they seem to be tight, ball joints have 1/16-1/8 of play.
post #13 of 37 Old 11-20-2009, 08:17 PM
snatchngears
If you have not found your problem, check the wheel bearings. I have a 2003 1500 quad 5.7l and I would hear a rattle sound at low speeds up til about 40. Thought it was the brake pad shields. Took the wheel off and turned the hub by hand...rough. Replaced the bearing assy (hub unit) and no more rattle.
snatchngears is offline
post #14 of 37 Old 11-20-2009, 11:43 PM
stringerbead81
Im glad I found this subject, I have just started hearing that noise from my front end. I used to have an 04 ram 1500 and that same noise happend to that truck to when I took it to the dealer they told me that one of my axles was loose. I didnt know at the time if they were full of crap or not but maybe there is a difference in heavy duty trucks front ends and halfton frontends.
07.5 ram 2500 QC 4x4 6.7 ctd sport pkg:current mods- AFE stage II mega cannon CAI, 5" tbe, EGR/EGR cooler deleted, smarty tunner. mods yet to come- AFE intercooler, new intake horn.
stringerbead81 is offline
post #15 of 37 Old 11-20-2009, 11:47 PM
s38638i
Boom goes the dynamite
s38638i's Avatar
i would check your sway bar end links, i have seen those go out quite a bit i would even go as far as removing the sway bar completely and drive it to see if the noise goes away
s38638i is offline
post #16 of 37 Old 11-21-2009, 12:39 AM Thread Starter
Josh Brown
Josh Brown's Avatar
The 1500 and 2500 are so different that noises on a 1500 rarely would be the same problem on a 2500. My problem is the ball joints for sure. I am waiting for xrf lowers but may buy spicer joints soon if xrf doesn't come through.
post #17 of 37 Old 11-21-2009, 03:37 PM
#2MILLERTIME
just had my ball joints done got 64,000 outta them.
also needed u-joint on left side
its costly, but ya gotta do it.......
#2MILLERTIME is offline
post #18 of 37 Old 11-22-2009, 12:12 PM
NickBeek
Ok before you drop big money on new ball joints. I have 118K miles on my truck. At about 36K I noticed while rotating the tires that I had up and down pay in the wheels while there was no weight on them. I took it to the dealer who diagnosed it as unit bearings and replaced them under warranty. When the tech put the wheels back on the truck I tried them and the same play was still there. I did a little digging and found out that the stock ball joints are allowed to have .060 on one and .090" on the other play in them. I had the tech check them and they were within specs. Fast forward to a week ago, I heard a clunking noise while riding in rush hour traffic beside the concrete barrier. I got home and found a u-joint on the drivers side front axle was shot. I replaced the u-joint and while taking the axle apart I found I still have the same amount of play in the ball joints that I had at 36K miles, now at 118K miles.
What I say is my own opinion, Take it or Leave it.
Nick-
2006 Ram 2500 SLT Cummins 4x4 LWB 6 Speed, High Idle, Smarty S06, 6" Grand Rock miter cut stacks, silencer ring mia, torque tube gutted, CFM+ horn, SB Con OFe.
NickBeek is offline
post #19 of 37 Old 11-23-2009, 04:01 PM
mastertech
your ball joint are not going to clunk, there hold up all the weight off your truck. new they will move op and down almost an 1/8th inch. if you can grab the top and bottom of the wtire and move it in and out than there shot but still wont clunck. id look int other things. i just replaced a shock that was causing the same issure your haveing, i found that with a set a chassis ears. save your money and get it diagnost right and not just throw parts at it.
mastertech is offline
post #20 of 37 Old 11-23-2009, 08:54 PM
Farm Boy
My '05 3500 had the same clunk. It was under warranty, I took it in and they threw some parts at it, and said it was done. I went and picked it up, and as I left the stealer ship I hit a little bump going out the drive. The clunk (or pop) was still there. Turned around and told them to try again. Picked it up the second time, and it was gone. I was told it was the cross member poping when the frame would twist. Chrisler's fix (or my stealer ship's) was to lube the cross member so it wouldn't pop. It would have a little give. I have drove it another 150k and I just started hearing it again. Take it for what it's worth.
'12 Ram 3500 4x4 crew 6.7CTD auto
'05 RAM 3500 4x4 4dr CTD 6spd
'03 RAM 2500 4x4 4dr CTD auto sold
Farm Boy is offline
    Front End Rattle? ramthis06 3G Dodge RAM - General Talk 13 12-19-2008 12:22 PM
    07 front end rattle revo33 3G Dodge RAM - General Talk 0 11-08-2008 06:50 PM
    Front end rattle on '03 GC Houstondb Dodge Caravan General Talk 4 11-05-2008 10:53 PM
    Front-end Rattle 98 D Sawyer87 1G Dodge Durango - Tire/Wheel/Susp Talk 1 08-01-2006 01:18 PM
