No TMR delete for my 03? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 09-11-2009, 01:55 PM Thread Starter
mike_ct
Quoted: 1 Post(s)
build date on door is 10/02; and its a 4.7 - felt ambitious today, and went to snoop around and do a TMR delete; and i see my PCM on the firewall has "4 plugs". Isn't this the new style? I also did not see the TCM i've seen on the other trucks and writeups for doing the TMR wire delete.
Any idea what this means for me? Also as a note, I tried to use a superchips a while back, and it would not work correctly - it was unable to read my stock configuration - I went back and forth with superchips tech a few times, and eventually gave up on the idea and just left it alone.
Now I cant figure out whats up with my truck - did it have something changed or updated at some point where the TCM and old 3-plug PCM removed and changed over to a 4-plug? or were some early 2003 trucks produced without separate TCM (and thus unable to do the TMR delete mod).
Any input appreciated..As of now I'm bummed out; no TMR delete and can't run the superchips either.
2011 Ram 2500 Laramie CC Sweet freakin sweet truck is all I have to say.
2010 Ram 1500 TRX4 5.7 CC145k Daily Driver..Rancho 4" lift with Bilsteins
mike_ct is offline
post #2 of 6 Old 01-14-2010, 05:14 PM
OfcBanks
OfcBanks's Avatar
what is the tcm wire cut mod and what does it do?
Current2007 QCSB black Dodge Ram 2500 4x4 5.9 CTD
Current Mods:
TGC 2.5 in leveling kit, Toyo M/t 35's, Brushguard, N-Fab steps, Bilstein steering stabilizer, Bilstein 5100's up front, RSD 5in TBE exhaust, Edge with Attitude *hot unlock* with dash mount, Pusher intake elbow, AFE Stage 2 Mega Cannon, Truxedo tonneau cover, B&W gooseneck ball, Line-x bed
Future Mods: Color matched sport grill, Hella 1000's, Amp research steps (I hope)
Past:
2003 QCSB white Dodge Ram 1500 Laramie 4x4 5.7L Hemi Lots of mods
1986 Toyota 4x4 with custom flatbed
1990 Chevrolet 1500 4X4 3xx,000 miles and still running strong
OfcBanks is offline
post #3 of 6 Old 01-14-2010, 06:46 PM
BigHemiTex
Tex
BigHemiTex's Avatar
on the 2003 i think you can cut the tcm wire and get rid of tq managment for harder shifts
2003 Hemi + Mods
BigHemiTex is offline
post #4 of 6 Old 01-14-2010, 07:46 PM
crasher76
Im wired!!!
crasher76's Avatar
on those four plugs you have on the firewall to your pcm its the bottom one yellow with green stripe.
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, 260 cam, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstar ultras, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Rebuilt front suspension, Ditched Sway Bar, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
crasher76 is offline
post #5 of 6 Old 01-15-2010, 12:09 AM
darell_n
Boost, you say!?
darell_n's Avatar
Regardless of how many connectors, you still have a TCM mounted on the passenger fender with the same wires as every other '03 Ram. Cut the wire there instead as it's more accessible.
Cheap. Fast. Reliable. (Pick 2)
darell_n is offline
post #6 of 6 Old 01-15-2010, 06:48 AM
TrouttDOG
TrouttDOG's Avatar
will this work on the 03 2500 4x4 with the hemi its a heavy duty....hope it doesn't make a diffrence mine shifts like its slips into 2nd and 3rd at wot
TrouttDOG"S DODGE
2003 2500 HEMI QC
TrouttDOG is offline
    03 TMR delete mod. LPGHemi 3G Dodge Ram Performance Talk 84 01-17-2010 09:18 AM
    Cat Delete or Muff Delete? Sparks07CTD 3G Dodge RAM Diesel Talk 19 07-08-2007 08:49 PM
    how to tmr? Jack Arse 3G Dodge Ram Performance Talk 0 03-29-2007 05:25 PM
    03 Tmr ? pegasus 3G Dodge Ram Performance Talk 10 02-02-2007 07:46 PM
    TMR - I know (again) MiniCwik 3G Dodge RAM - Drivetrain Talk 19 11-13-2006 08:04 AM
