Squealing Sound
- Posted: 08-06-2002, 03:49 PM
Post #1
On my dad's 1998 Voyager, 3.3L, on the passenger side, you can hear the engine emit a squealing sound. I put my ear as close as possible it sounds like it is coming from a pulley (water pump ?).
Anyone experience anything similiar ?
1995 Dakota 4x4 Club Cab 5.2L, 3:55 rear end, 46RH tranny Mods : M1, NGK zfr6f11s, 180 t-stat, Bilstein shocks, Roadmaster Active Suspension, Mopar Valve Covers, Mopar 3 inch cat back, relocated IAT, FMS/Bosch Design 2 #21 injectors, TransGo Shift kit (tfod-hd2), 8mm Taylor Spiro Pro wires |
| Sponsored Links |
Posted: 08-12-2002, 12:58 AM
Post #2
there's a high picked squealing sound on my van too, but i think mine is coming from the driver's side wheel area. does the caravan make a high pitched noise when the car needs new brakes?
2000 Dodge Grand Caravan SE FWD Mods: APC Exhaust, Altezza Euro Tail lights, 5% Tints Front, 5% Limo Tints Back, Eibach Pro-Kit Lowering Springs, Rear entertainment System, Bosch 4+ Plugs, Carbon Fiber Dash Kit, Blue Underbody Kit Lights, Custom K/N Cold Air Intake, Tornado Air Product, Focal Utopia 136 W, JL Audio XR-570, JL Audio VR-690, 2 JL Audio 12W6 V2 in Customer Sealed Enclosure, MTX Thunder 8100D Amp, MTX Thunder 6304 Amp, Alpine IVA-801, Alpine CHA-S634, Alpine DHA-S680, 5.6'' Headrest LCD Screens, APC Side Markers, Flowmaster 40 Series, Viper Alarm System 500 Series w/ Glass Breakage Sensor, StarTech DE Projection Headlights, Eagle Ultra-Grip Winter Tires, Silver Grill, Magnecor 8.5mm Spark Plug Wires, Hella Micro-De HID Fog Lights, 7000K Hella HID H7 Driving Lights. Future Mods: Alpine Navigation System, 18' Tenzo Racing Rims & Performance Tires, Turn Signal Mirrors, Brembo Brake System, Hood Scoop, 56mm TB, Koni Shocks and struts. |
Posted: 08-12-2002, 01:32 PM
Post #3
No, only when the engine is running. It is predominantly on the passenger side.
Funny thing is, the squeal has gone since the cooler wet weather has disappeared. I've always thought that when a vehicle needs new brakes, you could hear a loud metal grinding metal sound.
Posted: 08-14-2002, 12:11 AM
Post #4
i'm going to bring it to a dealership and get it checked, thanks..
Posted: 08-28-2002, 12:40 AM
Post #5
1: The squealing when driving is the brakes. The caravans have a wear indicator that let's you know it's time for brakes. 2: The problem with squealing when running is either an idler pulley, or the belt. Check the belt for cracks. If present, change belt. If it still squeals, change the pulley as well.
Posted: 08-28-2002, 12:09 PM
Post #6
We took it in and it was the water pump.
I can't believe, only 82 000 km and the water pump goes south.
Posted: 08-28-2002, 01:27 PM
Post #7
MOST COMMON THINGS WE SEE HERE AT THE DODGE DEALER IS WATER PUMP,BELT TENSIONER, IDLER PULLEY AND SERP BELT. YOUR NUMBERS FOR 96-00 APPLICATIONS ARE 5010898AA WP, 4694474 SEAL,4612894AE TENSIONER,4792112 IDLER, 5086140AA BELT. THESE ARE FOR 3.3 & 3.8'S.
Posted: 08-28-2002, 04:27 PM
Post #8
Thanks for the part numbers !
We did get it replaced at the dealer, and they were able to get it done quite quickly.
Posted: 08-28-2002, 10:09 PM
Post #9
got the brakes and rotors changed, sound went away.. thanks
Posted: 02-25-2003, 10:46 PM
Post #10
I am getting a squealing sound as well. I've got 213K miles on my 91 and it runs smooth as anything. Original tranny as well! Anyway...The sound is a very high pitch chirp, chirp, chirp that fades out when I put on a little power and comes back when I back off on the gas, while cruising in town 35-45ish Not road speed dependent. In general it is more likely to do it ater 15-20 min of around town driving and much less likely to do it at all when cold.
Sounds like pass side but that is my guess when driving. What do you think? Thanks. Ken
'91 GC 230K on original 3.3 and trans. Best car we've ever owned, but about ready to upgrade to an '01
Posted: 02-27-2003, 11:11 PM
Post #11
Sounds like a (belt, tensioner, water pump, idler pulley). All, or none, or one?
| Thread Tools | |
| question about engine sound | 2003bluebeast | 3G RAM - General Talk | 21 | 11-15-2003 12:06 AM |
| Squealing sound only on wet days!!! | gizmo321 | Caravan Talk | 2 | 09-08-2003 09:34 PM |
| Sound System Needs Help! | Metalgeez | Mobile Audio & Electronics Talk | 8 | 04-17-2003 09:52 PM |
| Hemi clicking sound | Josh Brown | 3G RAM - General Talk | 5 | 02-19-2003 02:04 PM |
| front end popping sound | boogiemn | 1G Durango General Talk | 4 | 02-07-2003 11:46 PM |
| Sponsored Links |
