Temperature fluctuation - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 09-02-2009, 01:52 PM Thread Starter
emil2112
RUSHFAN2112
emil2112's Avatar
Have noticed over the last few days my temp has been fluctuating a bit. I have an '05 1500 hemi 5.7. Normally the temp stays just below the center line however now it goes just past the center, then back down...it does this the whole time I'm driving. I'm thinking t-stat but was wondering if anyone had another idea....the coolant level is fine btw.
If it is the t-stat, I would like to replace it with a 180deg one. Any concerns or possible problems I might encounter from this? Thanks guys.
emil2112 is offline
post #2 of 14 Old 09-03-2009, 05:01 PM
04_rammer
04_rammer's Avatar
I had the same problem. Check the coolant. Both the reservoir and the radiator. Sometime the radiator has a pocket of air in there. Just slowly add coolant and let it "slurp" it down and keep adding until it wont slurp anymore. I know u said u checked the coolant and all is well but i dont know if u checked the radiator.
04_rammer is offline
post #3 of 14 Old 09-03-2009, 05:04 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 56 Post(s)
Kinda sounds like the 'stat is trying to stick open.
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #4 of 14 Old 09-03-2009, 05:09 PM Thread Starter
emil2112
RUSHFAN2112
emil2112's Avatar
Yeah, both of those were my thoughts....if it is the stat going bad, is that a pain to change out? doesn't seem like it would be...
emil2112 is offline
post #5 of 14 Old 09-03-2009, 05:25 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
you have the green or red coolant.
How many miles?
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #6 of 14 Old 09-03-2009, 05:33 PM
patriotblueram
patriotblueram's Avatar
Quoted: 4 Post(s)
no the t-stat is real easy to change out, just a little messy. i would think its an air pocket in the lines. its the trick for that to put it on an incline and let the engine run with the cap off for a while?
2005 dodge ram hemi QC
performance-Pacesetter LT headers, cutouts, flowmasters 50, x-pipe, SCT tuned by HEMIFEVER, comp 268, 6.1 pushrods and springs, Dyno Jet Wideband, Rancho R55000,180* stat, BFI intake,Taylor shortie blue plug wires, Fastman ported throttle body, Summit 25% UD pulley
visual- leather, Infinity system, 2 10" infinity subs, alpine amp, 20% tint front two limo tint on back two and back window, rhino liner, Dodge sidesteps, 20" rims, Hankook Ventus tires, Viper 5701 alarm and remote start, Taylor Shorties, 6000K heads and fogs by TWIGGY, Alzhemi light bar KC Daylighters behind grill,srt-10 guage pod, blue interior, blue speedo guages, Belltech 2" drop shacles w/ overload removed, Sir Michels rollpan, Recon led tinted tails
patriotblueram is offline
post #7 of 14 Old 09-03-2009, 05:52 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
I'm just hoping he doesn't have green intermixed with the red that should be to only stuff used in the hemi's coolant system.
dizzyD is offline
post #8 of 14 Old 09-03-2009, 06:03 PM
patriotblueram
Quoted: 4 Post(s)
ya, the Mopar brand from the dealer is the only stuff i buy, dont feel like risking it just because its cheaper
post #9 of 14 Old 09-03-2009, 06:33 PM
BigHemiTex
Tex
BigHemiTex's Avatar
mine starting doing that a while back with the stock stat, so i changed it to a 180 and it still does it, usually the first drive out in the morning after sitting all night. it goes past where it normally sits for a few seconds and then settles
2003 Hemi + Mods
BigHemiTex is offline
post #10 of 14 Old 09-03-2009, 06:42 PM
patriotblueram
Quoted: 4 Post(s)
mine does too, still havnt figured it out yet
post #11 of 14 Old 09-03-2009, 06:47 PM
BigHemiTex
Tex
BigHemiTex's Avatar
mine didnt used to but nothing bad ever happens because it does this so im not concerned, my truck has never been close to overheating, not even hauling a full sized chevy up up a hilly country road with the ac on
2003 Hemi + Mods
post #12 of 14 Old 09-03-2009, 06:53 PM Thread Starter
emil2112
RUSHFAN2112
emil2112's Avatar
I do not use the green coolant...only the recommended coolant. She has about 71k on her.
emil2112 is offline
post #13 of 14 Old 09-03-2009, 07:09 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
I'd keep an eye on the guages. if it desides to get up to the 3/4's mark, more concern is needed. Some have not solved the irratic temps with just a thermo change, as mention, which leads me to either a flow issue, an air bubble or radiator or water pump. A clogged passage around the temp sender, a loose electrical conn or faulty temp sender are all the possabilities.
dizzyD is offline
post #14 of 14 Old 09-04-2009, 05:45 AM Thread Starter
emil2112
RUSHFAN2112
emil2112's Avatar
I'm thinking I might drain and flush and add fresh coolant as well as putting in a 180 and see what happens.
emil2112 is offline
    rpm fluctuation omeeomy 1G Dodge Durango General Talk 10 05-05-2008 01:11 PM
    DC voltage fluctuation... Devil Dog 3G Dodge RAM Diesel Talk 11 12-31-2007 04:25 PM
    Temperature Gage Fluctuation tufhemi 3G Dodge RAM - General Talk 0 12-13-2007 06:20 PM
    5.7L oil fluctuation? Riceman 3G Dodge Ram Performance Talk 5 12-11-2007 12:08 PM
