P 2110 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 08-30-2009, 05:48 PM Thread Starter
Coyotepride361
If Ur not first your last
Coyotepride361's Avatar
P 2110
The code p 2110 keeps on coming up when i do the dodge key dance. Even after multiple pcm resets(fuse pull trick) it keeps on coming back. Truck is surging and stalling. Any clue what it could be?
2003 Ram 1500 QC 4x4 5.7l HEMI
Black Truck Club Member #166/DONT touch my truck! club member#31
MODS
K&N FIPK C.A.I,Single in dual out glasspacks, chrome tips,Leveling kit,Nasta nerf bars, 325/60/R20 Pirelli Scorpion ATRs, Chrome brush guard,Black tool box,Tint
Coyotepride361 is offline
post #2 of 13 Old 08-30-2009, 07:29 PM
STL HEMI
The 2110 is a TB code. Was it a brand new OEM MOPAR unit you installed?
STL HEMI is offline
post #3 of 13 Old 08-31-2009, 04:53 PM Thread Starter
Coyotepride361
Yes sir it was. I dont need to get it reprogrammed or anything do i? since i did the install myself and all
MODS
post #4 of 13 Old 08-31-2009, 08:29 PM
STL HEMI
No reprogram needed.
STL HEMI is offline
post #5 of 13 Old 08-31-2009, 08:32 PM
hemi1569
All Around Great Guy
hemi1569's Avatar
I could be wrong but i think there is a flash for the computer which involved replacing the throttle body and updating software in the computer. I will try and find some more info
Names' Kevin
9/26/09 htc rally, best run 4880lbs, full street trim minus tailgate
14.31 @ 93.52
6.1 cam and pushrods
Ramhammer intake
Doug's headers(mids) with factory cats
catback
My 6500rpm superchip shift 0 to 60mph video
Knock retard limitations by the pcm on a stock tune, it can pull:
15.0 degrees at low RPM's
5.0 degrees at 6000 RPM
9.0 degrees at 4800 RPM's.
hemi1569 is offline
post #6 of 13 Old 08-31-2009, 08:40 PM
Palmentech766
^GM Goodwrench Certified^
Palmentech766's Avatar
P2110-ELECTRONIC THROTTLE CONTROL - FORCED LIMIT RPM
When Monitored: Ignition on and ETC is working.
Set Condition: When the PCM requests to limit engine speed if PWM is too high for 20.5
seconds and before P2118 sets. One trip fault. ETC light is illuminated.
Possible causes:
GOOD TRIP EQUAL TO ZERO
THROTTLE PLATE STUCK
(F888) ETC POSITIVE CIRCUIT OPEN
(F885) ETC NEGATIVE CIRCUIT OPEN
(F888) ETC POSITIVE CIRCUIT SHORTED TO GROUND
(F885) ETC NEGATIVE CIRCUIT SHORTED TO GROUND
ETC MOTOR
PCM
Test 1
Ignition on, engine not running.
With the DRBIIIt read DTCs and record the related Freeze Frame data.
In the Freeze Frame data, look at the temperature at which the fault occurred. If it
occurred in extreme cold temperatures, Icing of the throttle body may have caused
this code to set.
Is the Good Trip Counter displayed and equal to zero?
Yes - Go To 2
No - Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
Perform (NGC) POWERTRAIN VERIFICATION TEST VER - 5.
Test 2
Turn the ignition off.
Remove the Air Cleaner Assembly from the Throttle Body.
Check for any signs of a foreign material (ice or dirt) causing the Throttle to stick.
Manually open and close the throttle plate using your hands.
Does the Throttle Plate move?
Yes - Go To 3
No - Remove the debris if possible or replace the Throttle Body
Assembly. Disconnect the Battery when replacing the Throttle
Body Assembly. After installation is complete, with the DRBIIIt
under the Misc. Menu select LEARN ETC.
Test 3 involves probing the PCM, and requres a special break out box.
2013 Ram 1500 Outdoorsman Mineral Gray
1978 AMC Matador Wagon Morocco Buff
1967 AMC Ambassador Convertible Matador Red
Palmentech766 is offline
post #7 of 13 Old 08-31-2009, 11:44 PM Thread Starter
Coyotepride361
Well the whole ETC is brand spanking new. Does that mean it would be my pcm??
MODS
post #8 of 13 Old 09-01-2009, 08:33 AM
hemi1569
hemi1569's Avatar
Possible causes:
ETC MOTOR
PCM
Test 1
this code to set.
Yes - Go To 2
Procedure).
Test 2
Yes - Go To 3
That could be it?
Names' Kevin
14.31 @ 93.52
Ramhammer intake
catback
hemi1569 is offline
post #9 of 13 Old 09-01-2009, 08:51 AM Thread Starter
Coyotepride361
Woahhh totally didnt read that. Looks like a relearn is needed huh?
MODS
post #10 of 13 Old 09-01-2009, 08:53 AM
SilsHemi
Dodge Fanatic!
TSB 14-002-05
Inactive Throttle Body In Cold Ambient Temperatures
http://dodgeram.info/tsb/2005/14-002-05.htm
Date: March 17, 2005
Models: 2003 - 2005 (DR) Ram Truck
Overview:
This bulletin involves replacing the throttle body.
Symptom/Condition:
Customers may experience any of the following Electronic Throttle Control (ETC) system symptoms at start up in extreme cold ambient temperatures (Below 0 F (minus 18C)):
Partial Return From Cold Start Fast Idle
No RPM Increase When Accelerator Pedal Is Moved
Diagnostic Trouble Code 2110 - Throttle Actuator Control System - Forced Limited RPM
Diagnostic Trouble Code 2118 - Throttle Actuator Control Motor - Current Range/Performance
Diagnosis:
If a customer indicates that they have experienced the condition, perform the Repair Procedure.
Parts Required:
Qty. Part No. Description
1 05161805AA Throttle Body - 2003/2004
1 05174079AA Throttle Body - 2005
Repair Procedure:
1. Using the procedures outlined on TechCONNECT, remove the throttle body and install the appropriate throttle body listed in the Parts Required section.
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: Description Amount
14-30-01-95 Replace Throttle Body 0.3 Hrs.
Failure Code: P8
New Part
Not sure if this is the problem, but I would make sure that the part number above is what's listed on your new TB.
Sil
SilsHemi is offline
post #11 of 13 Old 09-01-2009, 09:01 AM Thread Starter
Coyotepride361
Just went and checked and its the correct one.
MODS
post #12 of 13 Old 09-01-2009, 07:04 PM
Palmentech766
You'd know if it was the incorrect one, the plugs are different
post #13 of 13 Old 10-23-2009, 03:46 PM
truckin151
Any idea how to fix this yet? Did you take the truck down to have the ETC Relearned? I am getting the same P2110 code with similar symtoms after installing a new ported throttle body. After I removed the ported TB and put the stocker back on cleared the code and everything is perfectly fine.
truckin151 is offline
    Error Code P 2110 mb190e 3G Dodge RAM - General Talk 0 01-15-2004 11:45 AM
